Check Engine Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkthompson6, Feb 22, 2010.
  1. Feb 22, 2010 at 6:03 PM
    bkthompson6
    bkthompson6 [OP] Well-Known Member
    Brandon
    Oregon
    Hello All,
    I just completed the "remove the second air filter mod" and i can definately tell a difference in throttle response. I just popped a "main't req'd" light. I took the battery cable off for 5 minutes both after i did the mod and after the light came on. Funny thing is, i drove the truck for 150 miles before the light came on. My Cold Air Intake will be here tomorrow, so as of right now i am waiting untill i get that put on and then going to the toyota dealership to clear the light. What do you guys recommend? I dont want to clear it now then put the intake on and it pop again. Recomendations? Stories of it happening to you? Thanks guys
    Brandon
  2. Feb 22, 2010 at 6:17 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    you're not supposed to remove the second filter.
  3. Feb 22, 2010 at 6:19 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Many have done this mod but not to sure about the check engine light?:confused: I know there is some sort of sensor around there though.:rolleyes:
  4. Feb 22, 2010 at 6:21 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    wait is it the CEL or the Matience Required light
  5. Feb 22, 2010 at 6:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    A CHECK ENGINE light or a MAIN'T REQ'D LIGHT??
    MAIN'T REQ'D on solid indicates you are due for an oil change. Has it been blinking for the past...500 miles or so??
    If it's a check engine light- You need to get the code read somewhere (PepBoy, AutoZone, a friends garage, wherever) and let us know what it is.
  6. Feb 22, 2010 at 6:24 PM
    bkthompson6
    Brandon
    Oregon
    Sorry guys, it's the maintanance required light. I just changed my oil. Is there a way to clear it?
  7. Feb 22, 2010 at 6:25 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah hold down the odometer button and then turn the ignition on. You will see some lines and it will count down. Then just release the button when its done. Super easy!!!;)
  8. Feb 22, 2010 at 6:26 PM
    Brunes
    Brunes abides.
    Rotorhead
    ^That- Enjoy the better throttle kick-You are good to go brotha!!
  9. Feb 22, 2010 at 6:27 PM
    bkthompson6
    Brandon
    Oregon
    Come to think of it, yea it has been blinking 4 times each time i start the truck. Any advice? I know in my old Silverado after an oil change you just turn the key on and press the gas pedal to the floor 3 times and it would clear it, anything like that for this? Thanks
  10. Feb 22, 2010 at 6:28 PM
    bkthompson6
    Brandon
    Oregon
    Damn i can't keep up with your guys posts haha! thanks a bunch i will try that and then re-post. Thanks guys
  11. Feb 22, 2010 at 6:30 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    umm.. he just told you what to do. if not read your manual and it says in there also
  12. Feb 22, 2010 at 6:30 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah no problem. Yeah whem you reset the maint. light, it will show up again a little before your next 5K to remind you to change the oil again.;)
  13. Feb 22, 2010 at 6:30 PM
    Brunes
    Brunes abides.
    Rotorhead
    The blinking happens between 4500 and 5000 since last oil change as a reminder to set it up....@ 500 it goes solid on to tell you to change the oil already.
    Once you clear it....Good to go for another 4500.
  14. Feb 22, 2010 at 6:32 PM
    bkthompson6
    Brandon
    Oregon
    Hey thanks again. Do any of you guys have the second air filter mod? Wow i took that thing off and tried to blow air through it and couldnt even feel anything with my hand on the other side!!!
  15. Feb 22, 2010 at 6:34 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay cool. Yeah I wasnt sure exactly what durations the light went on at? But I do now!!!:D I honestly dont think I have ever seen mine light up.:rolleyes: Cause I normally dont wait until 5K to change mine.:cool:
  16. Feb 22, 2010 at 6:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Took mine off within days of buying the truck. I don't remember it being a HUGE difference- but each butt dyno is calibrated different.
    And the amount you blow is significantly less forceful than the engine sucks.
    Unless....naw....you wouldn't tell. =)
  17. Feb 22, 2010 at 9:30 PM
    bkthompson6
    Brandon
    Oregon
    Hey thanks guys, I just went outside and cleared it. I really appreciate all the help on this. So ive heard stories of CAI's popping CEL's, should i just unplug the negative battery cable to prevent this? Thanks again for the help on the maintanace required light.
    Brandon
  18. Feb 22, 2010 at 9:59 PM
    808matt
    hawaii
    15 crew cab
    i suggest making a new thread instead of asking new questions in i different titled thread. and no, unplugging the neg. battery cable doesnt prevent anything. it just resets your ecu.
