Check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95greentaco, Sep 23, 2022.
  1. Sep 23, 2022 at 7:39 AM
    95greentaco
    95greentaco [OP] Member
    1995 Tacoma base 4x4
    3.4 1996 runs fine with check engine light on no codes. Check engine lights goes off then comes back on with truck misfiring at intake power loss over 2000 rpm. Changed camshaft position sensor, crankshaft position sensor, new spark plugs, new coil packs, new fuel pump with pressure regulator. I’ve seen that everyone is saying MAF sensor but everyone changes it with no change. Not sure where to go from here.
  2. Sep 23, 2022 at 8:26 AM
    95greentaco
    If you let it cool down it usually goes back to normal operating conditions with the check engine light on.
  3. Sep 23, 2022 at 8:56 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Cool down as from it over heating?
    I’d at least clean the mass air flow sensor they have specific cleaners for it. Could also be injectors. Throttle position sensor. Low compression. A dirty fuel filter. Bad head gasket. Vacuum loss. Spark wires. What codes did you pull?
  4. Sep 23, 2022 at 9:05 AM
    Smokestacks
    BayArea
    Wait? the check engine light comes on but does not have any codes?
  5. Sep 23, 2022 at 9:23 AM
    95greentaco
    Cooling down as from normal operating temp. No codes show up with light on.
  6. Sep 23, 2022 at 9:57 AM
    Smokestacks
    BayArea
    Ahh wow that’s odd. I’m sure someone with more knowledge will chime in soon good luck. Can you make a code pop up by unplugging something?
  7. Sep 23, 2022 at 11:51 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Odd, took the Tacoma to get lunch just now and on the way it stumbled, check engine light came on and now I have about 50% power.
    Looks like I’ll be pulling out the code reader when I get home.
    Mines a 99’ 3RZ though.
  8. Sep 23, 2022 at 10:39 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    Stock
    Update: So after lunch I drove to the dealer to pick up a new gas cap, just had a feeling.
    $42 dollars later :frusty: I install the new gas cap in the parking lot, start it up, check engine light still on, still can tell power is limited. Pull out on the road, check engine light goes off and engine power restored.
    I’m having a hard time believing the gas cap was causing the stumble, loss of power and the check engine light to come on. But the whole way home all was good :confused:
    I still need to check for soft codes.
  9. Sep 24, 2022 at 2:25 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've seen one car that the fuel cap was not letting fresh air into the tank so the fuel pump was having a hard time pulling fuel.
    This was a while ago, no codes although it was stumbling, but no check engine light.
  10. Sep 24, 2022 at 4:22 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I'm going with Injectors. Pull the codes anyway.
  11. Oct 10, 2022 at 5:08 PM
    TicTacToy99
    TicTacToy99 Active Member
    Lea Renee
    Gresham, Oregon
    1999 Tacoma, Standard Cab RWD AT, white/blue-grey int Factory/Stock
    Swapped double sided clamshell crossbody toolbox for 2nd hand canopy- replaced its T-handle locks. Added multifunction multicolor customizable led cab lighting. Replaced OEM tape deck stereo w/removeable face stereo/CD/Bluetooth unit. Replaced front bumper with chrome strip and chrome plastic grill with matte black aftermarkets. Replaced rear chrome step bumper w/steel matte black aftermarket. Replaced OEM headlights, corners, and tail lights w/aftermarkets. Replaced aftermarket headlamps with FREAKIN WHITE leds. Replaced OEM floor mats with aftermarket deepISH dish all-weather ones. Replaced OEM tailgate handle w/one that LOCKS. Windshield cracked, had it replaced. Replaced OEM washer fluid reservoir w/aftermarket-now the sprayer bits don’t wanna work... Added clip-over-OEM style rear view mirror/monitor with rear view parking assist and incident recording front and rear views. Added a suicide knob to steering wheel.
    I’m gonna put my money on a p0171 or p0172 code coming outta this one… unless ur fuel pumps on the fritz..
