Check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04Toyoguy, Nov 27, 2022.
  1. Nov 27, 2022 at 2:22 PM
    04Toyoguy
    04Toyoguy [OP] OldTacoYotaLvr!
    James
    Fox Island WA
    04 Tacoma 3.4ltr V6 SR5 4x4 TRD Off Rd
    Bone stock
    None of the odometer obd II tricks seem to work for checking the code. Do they actually work?
    what’s the best code scanner to get?
  2. Nov 27, 2022 at 2:24 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    go to autozone its free or just buy one at auto zone or wallmart, they all work. you get the code and do a search here to see what others have done, gl
  3. Nov 27, 2022 at 2:26 PM
    eon_blue
    Azusa, CA
    You can get a cheap obdII dongle that plugs into the port and connects via WiFi or Bluetooth to your phone, the Torque app is free for the basic version and will read/clear codes.
    Amazon sells the dongles for ~25 bucks give or take
  4. Nov 27, 2022 at 4:58 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    BlueDriver if you have a smart phone.
  5. Nov 27, 2022 at 6:13 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    LOL, yeah, they work. The 'right one' depends on a few factors but these are simple trucks so pretty much any decent reader works.
  6. Nov 28, 2022 at 7:55 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Your trying to complete all the test cycles??
    Sometimes the the test short cuts work sometime not.
    I like my Actron CP125 because it also reads the CAN system which I needed as well as OBII
  7. Nov 28, 2022 at 3:33 PM
    04Toyoguy
    James
    Fox Island WA
    Bone stock
    What is the CAN system?
  8. Nov 28, 2022 at 3:59 PM
    Bivouac
    CAN is a diagnostic system used on Mid Size Trucks
    I think it was developed in Germany
  9. Nov 28, 2022 at 4:04 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
