Check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scouterdad, Jun 7, 2023.
  1. Jun 7, 2023 at 8:18 PM
    Scouterdad
    Scouterdad [OP] Well-Known Member
    Sandpoint ID
    1996 white Tacoma
    Hey friends !
    Just changed PS,Alt,and AC belts. Would that have anything to do with a check engine light ?
    did do I something wrong ?
    Got over 200k, and I've never had a check engine light go on in any of my Yotas.
    Although I know it can happen.....
  2. Jun 7, 2023 at 8:19 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Did you run the code? If so, what is it?
    HondaGM likes this.
  3. Jun 7, 2023 at 8:22 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Belts wouldn't do it (that I know of.) Hook up the OBD meter and look for codes. Most likely it will be something emissions related. Right after I bought mine it came on and it was one of the O2 sensors, changed them both and voila.
    It could also be the fuel cap is loose/leaking, I had a Nissan that did this. Re-tighten and drove for 20 miles and it went away.
    HondaGM likes this.
  4. Jun 7, 2023 at 8:25 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Maybe you hit the cam or crank sensors plugs when working on the belts.
    they get ever so brittle with age.
    Did you disconnected anything while changing the belts?
    Yes indeed what is the code?
    HondaGM and TnShooter like this.
  5. Jun 7, 2023 at 8:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Unlikely, but possible.
    Pull the codes and report back to us.
    We can help you further after you do this:thumbsup:
    HondaGM and Bivouac like this.
  6. Jun 7, 2023 at 10:04 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Yeah, I have not run the code yet.
    I just wanted to see what you guys had experience with I'm not too tech savvy, but my buddy with the computer is going to look at it.
    No I didn't unplug anything, I loosened the dipstick mounting bracket that's about it.
  7. Jun 10, 2023 at 4:52 PM
    Angel707
    Angel707 Well-Known Member
    Angel
    did you ever end up getting them
  8. Jun 20, 2023 at 7:15 PM
    Scouterdad
    Sandpoint ID
    1996 white Tacoma
    Hey gang !
    sooo, it turned out to be a MAF code, (mass air flow sensor)
    Just_A_Guy likes this.
