Check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hotdog7, Feb 7, 2024.
  1. Feb 7, 2024 at 6:07 AM
    Hotdog7
    Hotdog7 [OP] Well-Known Member
    Fred
    1gen Tacoma
    Toytec 2.5-3" lift 2010 rims wheel spacers tundra brake upgrade
    I went to garage to get inspection he said check engine light doesn't work it won't light. Is this a fuse? My GMC is on cigarette lighter fuse
  2. Feb 7, 2024 at 7:18 AM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    I had the same problem. My lamp for CEL was actually burned out. I swapped mine with wiper fluid low lamp after diassembly. They do sell replacement lamps. Google TW THREADS dash lights for part numbers. This may or may not be your fix. Good luck
  3. Feb 7, 2024 at 4:45 PM
    Hotdog7
    Fred
    1gen Tacoma
    Thanks I didn't know there were bulbs that could be replaced
