check engine light
Discussion in 'Technical Chat' started by RustyYota, May 6, 2010.
  1. May 6, 2010 at 5:27 PM
    RustyYota
    RustyYota [OP] Active Member
    Dave
    Rust Belt, NY
    TRD Auto
    Toolbox in the summer tenau in the winter, 3in toytec lift, 33'' BFG muds, Tint
    Driving down the road going about 55mph then the old check engine light came on. Went to the nearest advance auto and read the code. It read as follows
    Evap Emission
    Control system purge
    Flow fault malfunction
    Control system vent
    Circuit Malf
    All I have for a manual is the hanes book for my old 2000 and the 2002 I thing is a little different system. I have checked all the hoses for holes and it looks good as well as the gas cap gasket. I assume my next job will be checking the purge solnoid thing. I someone knows anything let me know.
    Thanks a lot
    Dave
  2. May 6, 2010 at 5:28 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    Still running ok?
  3. May 6, 2010 at 5:50 PM
    RustyYota
    Dave
    Rust Belt, NY
    TRD Auto
    Yeah it runs mint if it wasnt for the light i would never had known
  4. May 7, 2010 at 9:16 AM
    Taco John
    Illinois
    4X4
    My dad aways suggested putting tape over it in that situation ;)
    An '02 so OBDII, right? Should have gotten some numeric codes with those descriptions. Best bet is googling those. They are standardized so you can cross reference a lot of different makes and models with similar controls.
    Sometimes those can be a pain to trace if it is a cracked or loos hose or a loose wire, etc.
  5. May 7, 2010 at 9:42 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    ck your purge control solenoid valve
  6. May 10, 2010 at 11:30 AM
    straightaxle
    straightaxle Well-Known Member
    Jordan
    jacksonville, FL
    beast
    alot
    where is this located on our trucks, also how can you tell if its faulty?
  7. May 10, 2010 at 11:44 AM
    DaCapt
    DaCapt Mad Fisherman
    Phil
    Reno, Nevada
    2013 Tacoma 4X4 SR5 DC
    Make sure your gas cap is tight!! Till it clicks. Had check eng. light happen to me. Gas cap fixed it.
  8. May 10, 2010 at 5:57 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
  9. May 10, 2010 at 5:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....first and easiest thing to check....then get the code number if it aint the gas cap.
  10. May 16, 2010 at 9:23 AM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    If it's code P0441, take a look at your charcoal canister for cracks. Becoming a common probelm on the '01 and '02 Taco's with the Evap canister under the hood.
  11. Oct 17, 2010 at 1:13 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    The Toyota stealership told me that the evap canister needs to be replaced. He informed me that it is under my truck bed and he needs to remove the whole bed to get at the canister. What do you think?
    I have an 03 reg cab 4x4.
  12. Oct 17, 2010 at 7:13 PM
    kevhogaz
    SR5 PreRunner
    I dont think the bed has to come off. The canisters usually just bolt to the frame. I'd get a second opinion.
  13. Oct 21, 2010 at 5:11 AM
    car78412
    Hudson Valley NY
    Now they told me that the frame needs to be replaced.
