Check Engine Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awoit, May 7, 2010.
  1. May 7, 2010 at 12:43 PM
    awoit
    awoit [OP] Well-Known Member
    San Jose, CA
    08 TRD, SR5, Debadged
    URD CAI, Flowmaster super 40, Debadged, 15% Tint all around, 12" sub, amp, and upgraded kenwood headunit,
    My check engine light came on today sometime either while i was driving to or from dirt biking...
    only got 42xxx miles on it do i need to make an appointment with the dealer or could it be something casual? My buddies got one of those code things for diagnostics so i was wondering if i could just use this to tell me what is wrong??
    Also should i NOT be driving my truck a lot or can i still drive it as i normally do until i figure out whats wrong?? BTW most recent mod is short tube headers which i put on about 3 months ago if that makes any difference
  2. May 7, 2010 at 5:28 PM
    awoit
    San Jose, CA
    So a buddy of mine brought his gear over and when we plugged in for diagnostics it read mass volume air flow circuit performance does anyone know what that means?
  3. May 7, 2010 at 5:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Can you post the actual code?
  4. May 7, 2010 at 6:10 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    Do you have an intake?
  5. May 7, 2010 at 6:25 PM
    1980 Well-Known Member
    The Dust Bowl
    First, I'd see if my air filter was clogged up. Secondly, I would Google the error code (I just did and there are about a hundred relevant posts about it, most with service .pdf files attached). Thirdly, I'd take a trip to the dealer as there is a good chance that it's covered under the emissions warranty.
    Edit: Emissions equipment is required by Federal law to be covered for five years or 50,000 miles so you should still be under warranty if the parts in question are covered.
  6. May 7, 2010 at 6:28 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    try pulling the maf sensor, spraying it carefully with some maf cleaner (not brake cleaner, carpet cleaner, or jim beam), let it dry very well, use the code reader to reset the code and see if it comes back
  7. May 8, 2010 at 3:31 PM
    awoit
    San Jose, CA
    I have the URD CAI and i took apart the solder job that is required.. they looked good so i just unplugged the sensor cleaned it put it back and the code went away thx for the help guys :)
