Check engine on and off
Discussion in '1st Gen. Tacomas (1995-2004)' started by xxwarxxmachine, Mar 6, 2023.
  1. May 9, 2024 at 10:29 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You 'all kinda lucky Ole CC will go out there and take pics for you all....
    I dont know you all that well..............................
  2. May 19, 2024 at 8:27 AM
    xxwarxxmachine
    xxwarxxmachine [OP] Active Member
    Jeremy
    97 Toyota Tacoma 2.4 2RZ-FE
    Starting running good for a few days then back to having issues. It has to be electrical. When the check engine light comes on the AC will stop blowing cold. Then when it goes off the AC will blow cold again. Any suggestions?
  3. May 30, 2024 at 5:38 AM
    xxwarxxmachine
    Jeremy
    After all this time, I finally figured out the problem. It was a dirty mass air flow sensor. I took apart everything and the sensor had some kind of oily nasty stuff on the sensor. I cleaned it off and the connections with contact cleaner and it's ran good ever since
    Rougarou680 likes this.
  4. Jun 1, 2024 at 11:19 AM
    xxwarxxmachine
    Jeremy
    After 4 days of running fine, we had a bunch of rain and all of a sudden the problems came back.
  5. Jun 3, 2024 at 7:32 AM
    Glamisman
    Glamisman Well-Known Member
    Part of the strategy of OBDII is to store data that caused the CEL to illuminate, it is called freeze frame data. You will need to examine this as a starting point in order to diagnose this. This is done by using a scan tool.
  6. Jun 3, 2024 at 9:24 AM
    xxwarxxmachine
    Jeremy
    The scan tool will not connect when the check engine light comes on. Once the light goes off it connects but it doesn't throw me any codes. Previously however it did throw me a couple such as air temperature sensor, camshaft sensor, and igniter circuit malfunction. But the truck is going into limp mode. It bogs down and won't allow it to go over to 2 to 3,000 RPM. As soon as the like goes off power is restored and it runs fine. There are times where it comes and goes. Like on for 2 seconds off on for one second off. Been times were it stays on for the whole trip. And what's weird is it seems like when I go up a hill it goes off or when I come down a hill to a stop it'll go off
  7. Jun 3, 2024 at 11:55 AM
    Glamisman
    If you plan on fixing this yourself you are going to have to get a better scan tool... what is your current scan tool? The other option is to find an O'Reillys and they will scan it for you, if the CEL is on and their tool wont connect then that needs to be figured out too.
  8. Jun 3, 2024 at 12:28 PM
    xxwarxxmachine
    Jeremy
    We've tried 5 different scan tools. All the way from a cheap one to a Mac tools and snap on..
  9. Jun 3, 2024 at 3:43 PM
    xxwarxxmachine
    Jeremy
    Something else to add, it once my gas tank gets to a quarter of a tank and below it never messes up.
