CHECK ENGINE ON
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomonazul, Sep 11, 2012.
  1. Sep 11, 2012 at 10:04 PM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Ok so my check engine light turned on this morning :confused: so I got really scared. Went to Auto zone for the code detector, the code was that the engine was running too cold or the temperature sensor wasn't working any more. What should I do? :confused:
    This is the temperature sensor:
  2. Sep 11, 2012 at 10:32 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    BUMP ANYONE?
  3. Sep 11, 2012 at 10:35 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    We're in SoCal are you located I have a scanner and maybe we could meet up and I can help yeah out
  4. Sep 11, 2012 at 10:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    bobby
  5. Sep 11, 2012 at 10:37 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I went to autozone for the check engine light detector and the code said hat the engine was running too cold or the temperature sensor wasn't working any more.
  6. Sep 11, 2012 at 10:38 PM
    bjasper
    bjasper Well-Known Member
    Brian
    Carmel, CA
    06 TRD PreRunner
    Dad's truck, minor mods.. Saving for my own :)
    Give her a little rev here and there? Haha
  7. Sep 11, 2012 at 10:41 PM
    BAMFTACO
    Juan
    Kings bruh
    Mmm interesting
    Reason I say we could meet up is maybe we can do some trouble shooting. And how much is it to replace the sensor
  8. Sep 11, 2012 at 10:46 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I'm in El Centro
  9. Sep 11, 2012 at 10:52 PM
    BAMFTACO
    Juan
    Kings bruh
    Dang that's far
  10. Sep 11, 2012 at 10:53 PM
    BAMFTACO
    Juan
    Kings bruh
    There's a few things I've read quick google search on Ttora
  11. Sep 11, 2012 at 11:00 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    what's the actual CEL code?
  12. Sep 11, 2012 at 11:00 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    So what should I do, the guy on Auto zone said that the engine was running cold, what can I do with that?? Or that the temperature sensor wasn't working he said they work aprox 5 years, have you had any problems with yours?
  13. Sep 11, 2012 at 11:02 PM
    BAMFTACO
    Juan
    Kings bruh
    X2 what's the code better help for searching solution
  14. Sep 11, 2012 at 11:04 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Temp sensors don't fail often.
    Is your temp gauge behaving any differently?
    A thermostat is much more likely to go bad than the sensor.
    Is the coolant totally full? Check the radiator (cold) as well as the overflow tank.
    I would be interested in exactly what code you have. A code that indicates no signal from a sensor (sensor disconnected or dead) would be different from a code that just says temp reading stays below a certain temp too long (engine never warms up).
  15. Sep 11, 2012 at 11:07 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I call BS on that. I worked auto parts for three years, most sensors I sold were people chasing problems that they had no clue how to diagnose, or the vehicle was already quite old.
  16. Sep 11, 2012 at 11:07 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    the code is P0128 it says refrigerant temperature below temperature regulated by the thermostat.
  17. Sep 11, 2012 at 11:10 PM
    joes06tacoma
    Joe
    Central Coast, CA
    First make sure the coolant is topped off in the radiator itself, not just the overflow. If that's okay, I'd put a thermostat in it. Probably cheaper than the sensor, and sensors usually don't fail.
  18. Sep 11, 2012 at 11:12 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    is your temp gauge acting funny at all or is it dead center?
  19. Sep 11, 2012 at 11:13 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    +1, make sure your coolant level is good as stated. you might have sticking thermostat which can prevent the engine from getting to normal operating temp.
  20. Sep 11, 2012 at 11:15 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    It's working normal
