Check engine...P300, P302, P304, P306
Discussion in 'Technical Chat' started by redshift, Dec 29, 2009.
  1. Dec 29, 2009 at 12:36 PM
    redshift
    redshift [OP] New Member
    Hi everybody, my name is Michaël and I come from Quebec City, Canada.
    I drive a 97 tacoma V6 and the engine have some rattle at idle and they have no power over 2800 rpm. Over 2800 rpm or went I am WOT the cylinder 2, 4 and 6 cut.....
    The problem happen after a big snowstorm....I think they have some humidity in a part.
    I have change all sparks plugs.
    Does they have a part who control cylinder 2, 4 and 6??
    Thanks and excuse me for my English because I speak French....
  2. Dec 29, 2009 at 12:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Faulty spark plugs or wires
    Faulty coil (pack)
    Faulty oxygen sensor(s)
    Faulty fuel injector(s)
    Burned exhaust valve
    Faulty catalytic converter(s)
    Stuck/blocked EGR valve / passages
    Faulty camshaft position sensor
    Defective computer
  3. Dec 30, 2009 at 6:53 AM
    redshift
    Anythings else??
    It's very strange....P302, 304 and 306 at the same time.....
    The catalytic convecter is not block.
  4. Dec 30, 2009 at 7:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would start with the plug wires. Also check the vacuum lines.
  5. Dec 31, 2009 at 5:22 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    Did you install factory plugs, or aftermarket?
  6. Jan 2, 2010 at 2:16 PM
    redshift
    Yes twin electrode sparks plugs
