Check engine reader help
Discussion in '1st Gen. Tacomas (1995-2004)' started by KidWithATacoma, Mar 8, 2019.
  1. Mar 8, 2019 at 9:22 AM
    KidWithATacoma
    KidWithATacoma [OP] Taco and Tacos Lover
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    Hey TW,
    My check engine light on my 2003 Tacoma keeps turning on and off and i'm tired of bothering my friend for his check engine reader. What is a good one that will get the job done?
    Thanks,
    KidWithATacoman:smash:
  2. Mar 8, 2019 at 9:24 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Just about any one you can get from a parts store will work. I bought a Scangauge II so I can check lights as well as look at various other temps and even fuel mileage.
    wilcam47 likes this.
  3. Mar 8, 2019 at 9:30 AM
    eon_blue
    Azusa, CA
    I got one of these OBDII plug ins from Amazon for $20
    https://www.amazon.com/Interface-Sc...argid=aud-645589642778:pla-625356713193&psc=1
    Just plug that in the ECU of your truck (above your right knee under the steering wheel)...and you can connect it with the Torque App on your smart phone (there's a free version and a $5 version). Then you can read codes, clear them, check engine/trans temps, intake temps, fuel trims, etc. All for under $30.
    I eventually do want to get a Scangauge though, the disadvantage to using the Torque app is that it will drain your phone battery really quick. The Scangauge is something you can monitor while on the road.
  4. Mar 8, 2019 at 9:36 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    This one plus free "Torque Lite" download. I paid for the upgraded software, but you don't have to for the basics.
    https://tinyurl.com/y267mbyw
  5. Mar 8, 2019 at 9:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I have the bafx OBDII reader from Amazon ($20, bluetooth, basically the same thing @eon_blue mentioned) and Torque Pro. It's the $5 version of Torque lite (free version).
    So....
    I'm less concerned that you don't want to borrow your friend's code reader, and more concerned that you keep getting codes and don't seem to be fixing the issue. If you're just using the reader to reset/clear the codes, you're obviously not actually fixing anything.
    What is it saying when you borrowed your friend's reader? What is(are) the code(s)?
  6. Mar 8, 2019 at 1:02 PM
    KidWithATacoma
    Mac
    Arlington, VA
    2021 TRD Offroad
    Debt
    hey whats the point of the one with the switch? The "V2.1 with switch."
  7. Mar 8, 2019 at 1:05 PM
    eon_blue
    Azusa, CA
    I'm not sure...haven't heard of that before. Maybe it has an on/off switch so you can keep it plugged into your ECU port all the time?
    Mine I can't keep plugged in all the time because if I shut the truck off with it plugged in, it'll trigger my ABS light when I restart the engine for some weird reason lol. I just put it on when I want to use the Torque app and take it off when I'm done.
    Anyway yeah I dunno what the switch is about
  8. Mar 8, 2019 at 1:55 PM
    jbrandt
    Justin
    That's weird. Mine doesn't do that. I leave it plugged in all the time, and never noticed anything weird.
    I have this one and an extension wire so I can stash the read behind the dash so it doesn't stick out at my knees:
    https://www.amazon.com/BAFX-Product...082093&s=gateway&sprefix=obdii,aps,200&sr=8-5
    Taco critter likes this.
  9. Mar 8, 2019 at 2:07 PM
    eon_blue
    Azusa, CA
    yeah I think it has something to do with the specific brand one I got...I forget what it is but I read some reviews afterward of some people that experience the same thing. It just makes the ABS light flash if I leave it in, so I have turn the truck off, unplug it, and start it up again and all is well. Not the end of the world but kind of annoying, I only use it sparingly though so it's no big deal.
    I really want to get a Scangauge eventually anyhow so I don't have to mess with my phone to monitor numbers and codes
  10. Mar 8, 2019 at 2:16 PM
    jbrandt
    Justin
    do you get codes that often that you need to monitor them all the time? Maybe stop breaking it...:D
    I think my scanner has come in handy more often with other vehicles than my own. Once I was wheelin with some friends, and my buddy's jeep kept getting stuck in 2nd gear and throwing codes in a specific set of circumstances. I would plug it in to his, clear the codes, and he could drive again. Then my wife comes home freaking out that the check engine light was on. Ran the code and it turned out to be a loose gas cap. That one was funny, because I go inside and ask if she recently got gas, she thought I was stalking her or something because she did in fact, just get gas.
    The only time I've really "used" it is so I could check the emissions readiness before I had to get it smogged. I had just done my timing belt so all the emissions were not set yet, so I had to drive around until the tests were complete.
  11. Mar 8, 2019 at 2:24 PM
    eon_blue
    Azusa, CA
    lol no but I like to check it for 'pending' codes every once in awhile just to make sure everything is OK, since pending codes won't pop up as a CEL but they will show on the Torque App. I got alerted to my soon-to-fail rear O2 sensor that way. Also like to keep an eye on my intake and coolant temps every so often just to see that it's working as it should
    jbrandt[QUOTED] likes this.
  12. Mar 8, 2019 at 2:25 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    I got mine for $20 off Amazon and it has worked great
  13. Mar 8, 2019 at 2:36 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The down side to those fancy ones is having a Smart Phone
    Since I am not allowed to have one for work most places I go and no cell service at home.
    I like the Hard wired code readers I have the Actron CP9125 It works for my random use I keep one in each OBII vehicle
