Check Engine showing Cat converter problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaNJ, Sep 20, 2010.
  1. Sep 20, 2010 at 10:40 AM
    TacomaNJ
    TacomaNJ [OP] Well-Known Member
    Central Jersey
    2001 TRD SR5 Tacoma Ext.Cab
    So, I did a little mudding yesterday, and right when we were about to leave my check engine light flicked on....I had it taken to autozone and they ran a check on the codes and said that the first(front) catalytic converter was throwing an issue.
    Any thoughts? Would a big puddle cause that to happen? Should i just wash down the car and wait until it goes away, or is it just coincidence and I need a new cat.
    The symptoms of a bad cat, aka poor idle, rotten egg smell do not exist.
    Thanks for the help!
  2. Sep 20, 2010 at 5:40 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    possible an o2 sensor gone bad it doesnt sound like you have a bad cat if you dont have symptoms
  3. Sep 20, 2010 at 5:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try pressure washing the whole truck and letting it dry first. its possible a sensor got good and wet and tripped the cel for that code.
  4. Sep 20, 2010 at 5:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    They have no way of determining whether it's the front cat or rear one without removing them. What was the exact code?
  5. Sep 20, 2010 at 5:45 PM
    2000SIG
    2000SIG Well-Known Member
    Had the same issue last week.Erased the code and came back on the next day.I'm still covered under the emission warranty so the stealership will be replacing my cat Wednesday.
  6. Sep 20, 2010 at 6:41 PM
    Famouskmksrh26
    Famouskmksrh26 Active Member
    Sa, TX
    2003 4x4 TRD Limited
    TRD SuperCharged, Flomaster, Daystar 2 1/2" LVL kit
    Dude take it to a mech and have a full diganostic ran on it first before you spend any money on a new o2 sensor.. second they will tell u which one it is such lower bank O2 sensor but have it diganosed by a comp not a scaner because i was about to spend the money $180 on one sensor and found out it was just that it had gotten dirty due to muddin.....
  7. Sep 20, 2010 at 9:11 PM
    TacomaNJ
    Central Jersey
    ^^^ did you have to reset the ecu get the check engine light to go away or did you just wash it and it went away by itself ? I plan on getting a full diagnostic this weekend to figure this out before I drop any money
    Thanks for all the help so far!
  8. Sep 20, 2010 at 9:21 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    EDIT: I provided information concerning a Second Gen, not realizing that this was for first.
    Give the exhaust a good hosing down, then let it all dry out. If the problem persists, you can remove them to see if there are any underlying issues. A seal might have been bad and a little mud found its way through...
  9. Sep 21, 2010 at 4:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    This is a first gen we are talking about, not a second gen.
  10. Sep 21, 2010 at 5:39 AM
    memario1214
    Colton
    Missoula, MT
    Touche, I am sorry my bad. I was mistaken. Couldn't tell the type of vehicle from my phone and I assumed...
  11. Sep 23, 2010 at 5:50 PM
    Famouskmksrh26
    Sa, TX
    Ya i had it cleared but autozone wont do it
