Check engine ,trac off, have lit up on dash. Truck misfiring . Ran a code check I got po303 po304 p
Discussion in 'General Tacoma Talk' started by Stone2coma13, Aug 16, 2024.
  1. Aug 16, 2024 at 9:33 PM
    Stone2coma13
    Stone2coma13 [OP] Member
    Stone
    2013 smoke grey 4x4 TRD. Double cab
    Truck all of a sudden started running like crap.it has very little power . Missing bad first check on code reader was po304 po705 I changed plug and coil pack in #4. Started it up for a minute it seemed to run better. Then back to mid firing . So I ran code reader again now it reading 303 and 304 still 705 . Has anyone had this
  2. Aug 18, 2024 at 11:37 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Switch #1 coil pack with #3.
    I’d have to pull some diagrams. But there are a couple things you can check at the coil pack too.
    Power feed….I don’t have diagrams handy at the moment. I will later when I get back home.
    A couple hours or so…..
    soundman98 likes this.
  3. Aug 18, 2024 at 2:02 PM
    TnShooter
    Deogee
    STOCK
    I looked at the diagrams.
    At the coil there should be a White/Red wire.
    With the key On. Engine Off. There should be 5v on that wire.
    You can check coils 3 and 4. Just to "see" if they have power to them.
    Superdave1.0 likes this.
  4. Aug 18, 2024 at 3:26 PM
    Stone2coma13
    Stone
    Ok this is crazy . I bought the truck a year ago . First thing I done was replace plugs and coil packs. Because of a studer on take off. Every one of those coil packs have gone bad one at a time with the exception of these two
  5. Aug 18, 2024 at 3:27 PM
    Stone2coma13
    Stone
    Lucky I never throw anything away so all the old coil packs are back in the truck.
  6. Aug 18, 2024 at 6:48 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    plugs and coils, always best to get oem. far too many issues with lower cost options at the voltages used.
