Check Engine + Trac Off Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoleo, Dec 22, 2023.
  1. Dec 22, 2023 at 4:29 PM
    Tacoleo
    Tacoleo [OP] Member
    Leonardo
    2017 White Tacoma TRD Sport 4x4
    Stock
    So my 2017 4x4 Sport's check engine and trac off dashlights come on after it rains lol
    Any idea on what could be getting wet or what the problem could be
    Thanks for any help
  2. Dec 22, 2023 at 4:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Did you recently fill with fuel?
    If so, remove and reinstall your gas cap.
  3. Dec 22, 2023 at 4:47 PM
    Tacoleo
    Tacoleo [OP] Member
    Leonardo
    Stock
    i pumped gas on 12/17
  4. Dec 22, 2023 at 4:50 PM
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    I had the same thing after I got a locking gas cap. It's probably the same thing. Get it scanned at auto zone. I bet it would be related to your evap system.
  5. Jan 23, 2024 at 10:17 AM
    DJ Westsideeddy
    DJ Westsideeddy New Member
    Ed
    2013Tacoma
    Added 3000watt inverter with 2 extra deep cycle batteries.
    My Check engine and Trac off lights came on. Checked online. Said to disconnect the pos on battery for 3 minutes and clean the gas cap and spout with a cloth and rubbing alcohol. Lights went out but back on the next morning. ( vehicle has low power to get up to speed. Had to shop. Code is (I think) injection blower. Said there is a kit to bypass. Anybody do this?
  6. Jan 23, 2024 at 10:33 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'd get it to a good tech, online search is a guessing game, in hopes of a "free" fix.
    welcome BTW!
    RIX TUX likes this.
  7. Jan 23, 2024 at 10:41 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    A code reader would help.
    Those two lights are most likely a small leak in the evap system.
    That small leak is most likely the gas cap.
  8. Jan 23, 2024 at 11:00 AM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    You should read the codes.
    But mine also goes off in the winter. On mine particularly the charcoal emissions check fails when its wet outside. Its a peice of crap check in my opinion. Mine clears once there is about a week of warmer/drier weather.
    Isnt it nice how when the car flags something its like, no, you cant have anti slip (under 32mph). Id rather you get in a wreck, and no, you cant use cruise control. Id rather you get cramps holding down the pedal for an hour. That will teach you for owning a semi modern vehicle!
  9. Jan 23, 2024 at 11:53 AM
    spamy
    spamy Truck guy
    NorCal
    Wouldnt it be entertaining to find that its just the battery come age and needs to be replaced. Voltage is a bit low in the winter to get the results out of the emissions test it wants.
    Probably not, but its worth entertaining. People on here have have had a multitude of issues from a low voltage battery. New charcoal unit is around $500 or more. Battery, much cheaper and mines already 7 years old!
    By the way OP, thats just my situation, you really ought to read the codes.
  10. Jan 23, 2024 at 5:37 PM
    Tacoleo
    Tacoleo [OP] Member
    Leonardo
    Stock
    Thanks for all the info guys
    Supposedly its the Canister thing between the gas tank and the truck bed.
    Will probably just replace it and hopefully that fixes it
  11. Jan 23, 2024 at 5:52 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    When my gas was not sealing I would get a solid Check Engine Light with an intermittent Trac Off light. It would eventually clear itself once sealed or I could use my scanner to clear it.
  12. Jan 26, 2024 at 6:11 AM
    DJ Westsideeddy
    Ed
    2013Tacoma
    Has anyone else reported this issue to Transport Canada or other authorities to press for a recall. i did yesterday but only one other person has apparently made the call. ( Probably because I was on hold for 45 minutes before getting through) I feel it’s a safety issue because I managed to get onto a 100 series highway before I discoverered I had no power to get up to speed.
    Make the call if you have time.
