Check Engine w/code P0136
Discussion in 'Technical Chat' started by Jay536, Mar 20, 2010.
  1. Mar 20, 2010 at 9:54 AM
    Jay536
    Jay536 [OP] New Member
    Michigan
    03 PreRunner SR5
    I have a '03 Toyota Tacoma and the check engine light is on. I pulled the code and received P0136, which is Heated oxygen sensor - bank 1 sensor 2 (H02s12) circuit fault. Could someone tell me what the problem would be and how do I go about fixing it.
  2. Mar 20, 2010 at 9:55 AM
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Change the o2 sensor!
  3. Apr 17, 2015 at 2:23 AM
    taco4tim
    taco4tim New Member
    Phoenix, AZ
    '00 Tacoma 2.4L
    I have the same problem. Check engine light is on with a P0136 code. I replaced both O2 Sensors, ran a drive cycle and got the same code. What else could it be? I've replaced the EGR valve and EGR vacuum modulator 2 years ago because of similar, if not same, codes. Help!
