Check Engline Light, Code P0135
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongEnoughCrazy, Jun 23, 2024.
  1. Jun 23, 2024 at 5:45 AM
    LongEnoughCrazy
    LongEnoughCrazy [OP] Active Member
  2. Jun 23, 2024 at 5:54 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Replace O2 sensor (upper)
  3. Jun 23, 2024 at 5:58 AM
    Robnik
    Rob
    Greenacres, Florida
    They usually run okay, but waste gas.
  4. Jun 23, 2024 at 6:37 AM
    LongEnoughCrazy
  5. Jun 23, 2024 at 6:41 AM
    Robnik
    Rob
    Greenacres, Florida
    JustADriver likes this.
  6. Jun 23, 2024 at 6:48 AM
    Robnik
    Rob
    Greenacres, Florida
    Upstream are always more expensive than downstream. Downstream is usually the one that goes bad.
    Exposed more to the elements. Good Luck :)
  7. Jun 23, 2024 at 6:50 AM
    LongEnoughCrazy
    Thanks.
    This seller has a "Denso" for $99 + shipping. Any reason to think that these could be knockoffs?
  8. Jun 23, 2024 at 7:45 AM
    Robnik
    Rob
    Greenacres, Florida
    Pictures look legit, what they send you might not be. I never deal fleabay. Lots of "shady" sellers on there.
    RockAuto has it for $127.00 I think. I deal with them all the time. Never had a problem. Fast shipping. :thumbsup:
  9. Jun 29, 2024 at 9:57 AM
    LongEnoughCrazy
    Robnik,
    I was about to buy this on RA and saw this message at checkout:
    Manufacturers recommend replacing O2 sensors in pairs (both Upstream or both Downstream). And older, slower sensor can cause an imbalance in the engine management system, leading to poor fuel economy and possible damage to the catalytic converter.
    Guessing this doesn't apply here since there is only one upstream sensor?
    Robnik[QUOTED] likes this.
  10. Jun 29, 2024 at 5:35 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    ^^^Sounds like a service writer at a dealership
    sure, would be better to RR both
    but
    If there is no code tripping for the second O2 sensor, it’s working
    Black97v6MT, Robnik and Truckstop13 like this.
  11. Jun 29, 2024 at 5:49 PM
    jonylawless
    jonylawless Member
    johnathan
    2012 TRD sport 4x4
    Robnik likes this.
  12. Jun 30, 2024 at 6:37 AM
    LongEnoughCrazy
    Are there two upstream sensors on these 1st gen Tacomas? The bold text I pasted above seems to be saying I should replace BOTH upstream sensors or BOTH downstream sensors, but I thought there's only one of each?
    Robnik likes this.
  13. Jun 30, 2024 at 6:58 AM
    Robnik
    Rob
    Greenacres, Florida
  14. Jun 30, 2024 at 7:02 AM
    Robnik
    Rob
    Greenacres, Florida
    One up, one down.
  15. Jun 30, 2024 at 7:38 AM
    Black97v6MT
    Black97v6MT 360k on the 0D0 ... 5VZFE R150F 4WD
    27+ years of livin' Gen1 TacoLife...
    ... have read or whatever somewhere sometime that these O2 sensors May Be 'Working' but with Age they might not be working Efficiently :notsure:
    i took a peeky at the upstream on under my rig and I have absolutely NO CLUE how that is ever going to be coming out for replacement after 27+ years original
    Robnik and LongEnoughCrazy[OP] like this.
  16. Jun 30, 2024 at 11:34 AM
    ControlCar
    Steven
    Sugar Land TX
    When I “decided “ to RR my sensor
    I started spraying PB…….every day……for a week prior to install!
    Wasn’t too bad
    Robnik and Black97v6MT[QUOTED] like this.
  17. Jun 30, 2024 at 11:51 AM
    Black97v6MT
    Those nuts on mine look QUITE weathered
    Robnik likes this.
  18. Jun 30, 2024 at 6:04 PM
    Robnik
    Rob
    Greenacres, Florida
  19. Jul 28, 2024 at 12:17 PM
    LongEnoughCrazy
    How am I supposed to remove this? Is there a nut/bolt to remove?
    Black97v6MT[QUOTED] likes this.
  20. Jul 28, 2024 at 1:14 PM
    Black97v6MT
    I've seen a method using a torch and careful air chisel to chip at it and still save the stud threads
