"Check oil level" warning light when off roading and oil recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mauctopa, Feb 7, 2022.
  1. Feb 7, 2022 at 1:41 PM
    mauctopa
    mauctopa [OP] Well-Known Member
    Often times when off roading the "check oil level" light comes on when going down steep hills and/or off camber situations. Would using
    Castrol GTX MAGNATEC 0W-20 Full Synthetic Motor Oil
    help any? I'm worried my main and rod bearing would take a shit before I even hit 50k miles.
  2. Feb 7, 2022 at 1:47 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Have you check your oil level?
    That light should only come on when the pressure falls below threshold meaning at a steep angle you're starving your pickup tube of oil meaning you probably need to add a quart.
    I would check your oil level first.
    And I wouldn't run an oil not specified in your owner manual for your climate, especially not a thinner oil.
    mquibble likes this.
  3. Feb 7, 2022 at 1:58 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If the incline is so steep that the oil light is coming on, the incline is too steep to be driving on. Changing to another oil won't make any difference. And I'm assuming you're full of oil.
  4. Feb 7, 2022 at 2:28 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Is your oil level showing on the stick AT THE FULL MARK or just within the safe range? There is a difference.
    I take my truck on >30 degree slopes, both on pitch and roll axis’ all the time and have never seen the low oil warning. The truck physically won’t do more than about 37-38 on the roll axis (and I’ve had it about there) as have many others in my group and never once saw the light so I doubt that’s the cause on its own.
    Also just curious, nothing to do with your original question but what surfaces are the trails (I assume) which you take your truck at these high angles?
  5. Feb 7, 2022 at 3:18 PM
    mauctopa
    The first time it happened it was on a desert trail in cali where you descent into a dry river bed and then go up a really steep hill to get out. Another time was on Holcomb creek trail near Big Bear CA which is lots of boulders and rock gardens
  6. Feb 7, 2022 at 3:20 PM
    mauctopa
    I was thinking the magnetic oil will stick to the inside of the engine more and not get starved as easily.
  7. Feb 7, 2022 at 3:23 PM
    mauctopa
    0w20 is what is specified for here so thats what I have been using. My question more pertains to if the magnetic oil will be more beneficial for trucks that off road.
  8. Feb 7, 2022 at 3:35 PM
    Key-Rei
    Key
    Florida
    Magnetic oil?
    Sounds like marketing wank. :jerkoff:
    Just run good oil, Amsoil, Mobil 1, Royal Purple, and make sure it's topped off on the dip stick.
    Me personally I wouldn't put anything "magnetic" in my engine oil.
  9. Feb 7, 2022 at 3:36 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Your engine is aluminum; no magnetic forces there. Pretty sure the Magnatec gimmic is about trapping/attracting contaminants and not sticking to (even magnetic) engine parts. If it comes on momentarily or only on incline then as others said, probably tad too low and/or too steep.
  10. Feb 7, 2022 at 4:09 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I think he believes the name of the Castro Magnatec oil is a reference to being magnetic.
    To the OP, no, that Castro oil will not stick any more than other motor oils because it is not magnetic. You haven't answered if you have checked that the oil level is at the proper fill level. I’ve gone on some steep hills and my oil light has never gone off. Maybe, your hills have been steeper.
    Key-Rei likes this.
  11. Feb 7, 2022 at 4:24 PM
    eurowner
    eurowner Duke Sky
    Scoty
    mauctopa[QUOTED][OP] likes this.
  12. Feb 7, 2022 at 4:25 PM
    Key-Rei
    Key
    Florida
    jmneill, Delta09, hiPSI and 1 other person like this.
  13. Feb 7, 2022 at 4:36 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    mauctopa[OP] likes this.
  14. Feb 7, 2022 at 5:34 PM
    mauctopa
    Yes I check the oil level often and it has never been low. The first time it happened the truck was still new with its factory oil in it.
  15. Feb 7, 2022 at 5:36 PM
    mauctopa
    I
    I run Amsoil 100% synthetic
  16. Feb 7, 2022 at 5:41 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Then them hills are very steep, or the low-oil sensor is faulty, or a 3rd gen endearing feature.
  17. Feb 7, 2022 at 5:42 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    It usually happens on nose up or down steep inclines for me.
    It’s because of where the sensor is on the pan.
    As a heads up. If your doing that often get the JLT or whomever catch can. Quite a few have flooded the engine of oil via the PCV system while at extreme angles.
    dfanonymous likes this.
  18. Feb 7, 2022 at 5:50 PM
    mauctopa
    Yes I'll look into it before the summer! Thats what happened to Warfab truck right?
  19. Feb 7, 2022 at 5:51 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Yup and quite a few others.
    I can run hells revenge in Moab and have to empty the can just from that simple trail.
  20. Feb 7, 2022 at 5:52 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    This^
