Check Stability Control System light after installing Bilsteins
Discussion in 'Technical Chat' started by Adam F, May 1, 2020.
  1. May 1, 2020 at 5:29 AM
    Adam F
    Adam F [OP] New Member
    Adam
    04 4Runner
    None
    Installed some bilsteins, set them at 2". Steering wheel was off center. Drove it to have an alignment done, and the "check stability control system" light went off in the dash. I was hoping the alignment would fix it and it would go away, but it didn't. No other lights are on besides this. I tried the zero point, twice, no change. Reset battery, no change. Is there another way to recalibrate the system? Dealer?
  2. May 1, 2020 at 6:22 AM
    stefanlg55
    stefanlg55 Toyota Master Technician
    2008 Tacoma TRD OffRoad
    You might have damaged the speed sensor harness, Whats the codes?
  3. May 1, 2020 at 6:58 AM
    Adam F
    Adam
    04 4Runner
    None
    My scanner only went up to 2014 and wouldn't read anything beyond basic OBDII, so I can't pull codes.
    However, I tried the zero point for a 3rd time, and it worked. Light went off, all is good.
    I used the zero hero from KC Murphy on facebook. It's a little plastic box he made with a simple toggle switch and button that takes places of the jumper wire or paper clips. Makes the process much easier.
