check your ball joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rmodel65, May 20, 2015.
  1. May 20, 2015 at 9:34 AM
    Rmodel65
    Rmodel65 [OP] Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    On the way to work this am a tacoma was flipped over because of a lower ball joint failure...
  2. May 20, 2015 at 12:01 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    07 Lexus GX470
    this is what saving a few dollars and not buying OEM balljoints gets you.
  3. May 20, 2015 at 12:06 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    2001-2004 Tacoma's are eligible for free lower ball joint replacement through the 50J Technical Service Bulletin. Mine's at the stealership getting this done as we speak.
  4. May 20, 2015 at 12:07 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Only certain VINs are eligible for free replacement
  5. May 20, 2015 at 12:15 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Correct, only a certain vin range. Of course, mine wasn't included :annoyed:
  6. May 20, 2015 at 1:37 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    so where do you go to check if your vin is listed?
    plus on my 99 the lower ball joint have no movement and no play but if you jacked it off the ground it had 1/4" of movement straight up and down and had I not found it, it would have popped out on me one day. it was a genuine oem Toyota ball joint too so its not just because its cheap aftermarket, its because the entire weight of the truck is supported by the ball.
    the entire front end should be replaced every 100k miles, you cant ask for or expect it to last longer then that. plus the whole front end (both sides) can be replaced for only $150 in parts
  7. May 20, 2015 at 6:27 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Some of us play with fire. Myself included. I'm at 173xxx on original bjs. Think about it almost every time take a drive. Hopefully I can get some income and swap them out soon. For whatever it's worth I've seen some 200k + Tacomas with original ball joints still driving around. On the flipside I've read about people with less than 80k having a ball joint pop.
  8. May 20, 2015 at 6:32 PM
    a.smo
    a.smo Well-Known Member
    Aaron
    PHX, Az
    '99 Trd Xtra Cab 4x4 5sp
    To my knowledge(via the PO who said he never did them, owned the truck for about 200k miles), my truck lasted about 221k miles before I replaced them.
  9. May 20, 2015 at 6:45 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    If you go to www.toyotaownersonline.com you can create an account. There it will list all recalls and dealer service history. That or call a dealer with your vin and ask
    ChemDawg likes this.
  10. May 20, 2015 at 6:49 PM
    n0ms
    Angel
    San Diego
    You replaced them because they dropped out on you or because they were past due? The thing is some people drive their trucks hard off road and that will definitely wear them down quicker than the guy hauling around his gardening stuff (not to say that's you). Some of it might just be down to luck.
  11. May 20, 2015 at 7:46 PM
    a.smo
    Aaron
    PHX, Az
    The PO just drove freeway with about 500 feet on dirt to his house. I changed them because I was scared they were going to drop. Just had my gf's 4runner drop hers prior so I did them as well.
  12. May 20, 2015 at 7:52 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    I replaced mine after I brought it in for an alignment and the shop tech came out and told me to come back in to the shop.
    Driver side LBJ had well over a 1/4" of vertical play in it and was a ticking time bomb :eek: Luckily there was a NAPA directly across the street, and my house about two miles from there. Put in a set of 555 LBJ's until I could get a set of OEM's.
  13. May 20, 2015 at 7:55 PM
    AK Taco
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    To add, my truck has 225k on the clock and I have no idea if they had ever been replaced before. Didn't really look too close when I pulled the old ones off
  14. May 21, 2015 at 1:02 AM
    n0ms
    Angel
    San Diego
    Thanks for the information. Definitely going to replace mine with oem as soon as I get some money. I know some 4runner parts are "weaker" than Tacoma parts. Don't know if the ball joints are.
  15. May 21, 2015 at 3:55 AM
    ToyoTaco02
    ToyoTaco02 Well-Known Member
    Scott
    Decatur,IL
    02 PreRunner DC 2.7L
    OME 881 1/4" top plate spacer OME Dakars OME Nitrochargers Light Racing UCA
    I think the 4Runner ball joints are a little bit smaller than the ones on a tacoma.
  16. May 21, 2015 at 4:18 AM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Holy shit I just picked up a 2000 4 banger with 280k. Its in the garage getting gutted. I was planning on doing the ball joints but now for freaking shure. IMG_20150520_161425295.jpg
  17. May 21, 2015 at 4:20 AM
    DukesTaco
    AZ
    Where did you get the front end parts for it for $150
    zjdietz likes this.
  18. May 21, 2015 at 4:31 AM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Yeah oem toyota stuff definitely isn't 150$ thru work it was still pricey even with the 30% off that we get
  19. May 21, 2015 at 9:04 AM
    a.smo
    Aaron
    PHX, Az
    My stuff picked up from Camelback Toyota was just under 200.
    Ryan_3TacosIn likes this.
  20. May 21, 2015 at 9:17 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Got mine done couple months back for free under the recall. New Lower ball joints and free alignment.
    Go to http://www.Toyota.com/recall and enter vin
