Check your drum brakes!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Dec 30, 2009.
  1. Dec 31, 2009 at 7:00 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Yep, this is just the way it is. It's a simple fact-- The front pads wear out faster than the rear shoes because a lot of the vehicle's weight is shifted forward while braking. This takes more energy (& pressure) from the front brakes to stop. :) If someone's rear brakes are wearing out sooner than the fronts, there's a problem.
  2. Dec 31, 2009 at 7:23 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    I just got brand new brakes in the front but tyhe braking still is horrible ... i am sure rear brakes have something major to do with this ... why? Why ? why couldnt toyota charge me an extra couple of hundred bucks but give me rear disk brakes on the Taco
  3. Dec 31, 2009 at 7:52 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "As they do wear more quickly than the front." Something is whack here. I been driving and working on veehickels since B 4 your daddy was a glint in your grand daddy's and always went thru 2 to 4 sets of front pads to back shoes. Yeh definitely whack. :confused:
  4. Dec 31, 2009 at 8:30 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Roughly 80% of your braking comes from the front wheels.
  5. Dec 31, 2009 at 8:35 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Yes, that is the general rule but Toyota drum brakes are different as they put the adjusters on top with a solid pivot on the bottom. For this reason the way to self adjust is by using the parking brake. You can do each brake by crawling under the back and pulling on each parking brake cable. Does not help if the adjusters get sticky.
  6. Dec 31, 2009 at 8:40 AM
    scully
    scully Well-Known Member
    San Diego, CA
    06 TRD Doublecab
    Rear TSB FJ Cruiser TRD anthracite wheels Bilstein 5100's allround Tint
    So some of you are saying having the ABS kick in can effect the way the rear drums wear? Its been snow and ice most of Dec. in NV and the ABS kicks in daily. When will Toyota switch to rear discs - that was the one negative when comparing to the Nssan Frontier!
  7. Dec 31, 2009 at 8:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No.... the amount of time the ABS kicks in should not have any affect on how the drums wear.
  8. Dec 31, 2009 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Though the Nissan has Rear Disk brakes, note in the comparisons, it STILL doesnt stop as short as the Toyota
  9. Dec 31, 2009 at 8:52 AM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    strange, my truck has less than 20k miles and my front brake pads have 20-30% left
  10. Dec 31, 2009 at 11:24 AM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Well for me. After reading this, Its sounds like everyone has different situations occuring. I was basing this off of my truck and a few others that I've heard about
    I went in for a synthetic oil change. They had a coupon and I took advantage of it. I told them to check my drum brakes as they had alot of play. They just readjusted everything and put new shoes on without charging me.
    And my truck is WAYY over the warranty ;)
    I cleaned the drum as best as I could with the given pressure washer. It was one of those self serve car washes. I kept on spraying it until no grains or bit of mud was coming out of the mud.
    Most of the mud I was in was very slimy, not like mud puddles.
    And I use my ebrake all the time, even on level ground. Its just a habit. I dont like that extra lunge that the truck takes when you put it into P, turn truck off, and then take your foot off the brake.
  11. Dec 31, 2009 at 11:33 AM
    JKD
    JKD Well-Known Member
    That's why I usually ask people what specific deficiency/deficiencies switching to rear disc brakes will solve? They tend to be heavier and they tend to use less effective and reliable parking brake mechanisms (since drums are self-energizing). The one place that rear disc brakes really seem to help is in high heat-soak conditions, such as repeatedly braking from very high speeds (far more than you ever do on streets).
    In most applications there is just no performance to be gained by just switching to rear discs.
  12. Dec 31, 2009 at 11:34 AM
    JNL
    JNL Well-Known Member
    Jamie
    Atlanta
    08 DC Prerunner TRD Sport
    Both times I had to replace pads and rotors on my G35, the rear ones were way worse than the front.......but I also think I may have cooked them at the track cause after every session the rear rotors were much hotter than the fronts cause the smaller rotors couldn't dissipate the heat as well.
  13. Dec 31, 2009 at 11:48 AM
    JDMcQ
    I was not aware of this. I am a notoriously bad parking brake user, laziness I suppose. I will start using it more if for no other reason than to help keep the rear brakes adjusted. Thanks for the info.
  14. Dec 31, 2009 at 11:57 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2... Proportioning valve is out of whack.
  15. Dec 31, 2009 at 12:30 PM
    #35
    Janster
    Jandy
    Lancaster, PA
    I'm not talking about power washing them from the outside...
    When mud is involved - spraying them from the outside isn't gonna clean them. You have to take the wheel off and take the drum off. Spray the internals where the shoes are.... the mud cakes up inside.
  16. Dec 31, 2009 at 12:34 PM
    #36
    Lentsnh
    Thats all I did. I didnt take off the wheels and drums. I wasn't doing a Jamie.
    It was just very slimy Alabama clay. Like the top was soaked but not enough to get everywhere.
    And I'm not trying to argue, Promise:)
  17. Dec 31, 2009 at 2:44 PM
    #37
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    on normaliish braking to firm the front does 60-75% of the braking or so... the rear would just lock up if it did 50%.... i wonder if yours is dragging on dirt or the pads.
  18. Dec 31, 2009 at 4:49 PM
    #38
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    For all of the people that use the two front change to one rear change just take into consideration with the new EBD and VSC systems the rear brakes are used alot more than they normally would be in a conventional system. When I had my '08 Accord many owners complained at how fast they were going through the rear pads. Just some food for thought.
  19. Dec 31, 2009 at 4:54 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. BUT, A car has a more centered CG than a truck. Given the front weight bias at a stand still, and the height of the CG, much more weight is transfered tward the front when braking. EBD is going to distribute brake force where needed, which would be to the front. Why would you want more power to the rear, if there is less weight, thus less traction back there?
  20. Dec 31, 2009 at 5:04 PM
    #40
    dexterdog
    Oly WA
    2012 F150
    Sure, that the distribution percentage is greater to the front but the EBD system helps eliminate the nosedive effect which would essentially shift more braking to the rear than in a normal system. I would assume during the braking procedure the system would sense traction loss and would either activate ABS and or distribute more braking force to the tires with traction .
    Also, how are you to 42,000 posts? Is someone selling posts somewhere? Is there a post purchasing store on the internet I don't know about?
