Check your Ignition key before its too late.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Jan 5, 2024.
  1. Jan 6, 2024 at 2:34 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I read the thread title so of course I had to check when I went out to my truck earlier. Doors still lock/unlock perfectly w/ the key. :101010:
    davidstacoma likes this.
  2. Jan 6, 2024 at 6:19 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    I like the feature on my 2014 where if you use the remote FOB to unlock the truck, it will re-lock the truck automatically if no door is opened within 30 seconds. I had the truck for about a year before I discovered this feature.
    I also rotate the two keys about every six months. I almost never use the key in the door to unlock the truck. When it takes more than one try to unlock the doors with the remote, or you have to be right near the door for it to work, I swap a new battery into the remote and it cures it every time.
  3. Jan 7, 2024 at 1:13 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Huh?
  4. Jan 7, 2024 at 6:44 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I have a valet key hidden because my doors lock automatically after about 45 seconds. The key will do everything except start the engine.
  5. Jan 7, 2024 at 7:30 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    My 14 came with a credit card key but I never got it cut.
    grizquad likes this.
  6. Jan 8, 2024 at 8:10 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    After I locked keys in this truck, had a $3. no chip key cut and hid it on truck to always have something to unlock door!
    BC Hunter, bgavin and 2015WhiteOR like this.
  7. Jan 8, 2024 at 8:21 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    That sounds like an absolute great idea.
    I had a hidden key under my 1977 Chevy van for exactly this reason.
    More than once, I wound up with the engine running and locked doors.
    I carry a spare key in my wallet for my 1991 truck, as it is thin.
    If I can get a fob-less key of similar thinness cut, I could keep that in my wallet.
    grizquad[QUOTED] likes this.
  8. Jan 8, 2024 at 8:27 AM
    1schoir
    1schoir Well-Known Member
    Freeport, NY
    2006 Red Tacoma SR5 Access Cab 5 speed..1995 Blue Tacoma Extra Cab 4 cyl 5 speed...
    I don't remember the explanation for this phenomenon, but it works. Try holding your key against the underside of your chin as you press the button on your remote and aim it at the truck. This trick will increase the range of your remote. No joke.
    Wessty likes this.
  9. Jan 8, 2024 at 9:51 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I recently had an unchipped key cut for my Tacoma just to open the door in case of an emergency. I noticed that the key turns the ignition fine (and not start of course), but has a difficult time turning in the door lock core. Maybe the tolerances in the ignition are more forgiving? Otherwise, I agree that it's good to check your daily key. Thanks @TnShooter
    TnShooter[OP] likes this.
  10. Jan 8, 2024 at 9:52 AM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    I have a non chip key in my wallet. I can run the truck with the non chipped key in the ignition if I use the remote start.
  11. Jan 8, 2024 at 11:26 AM
    Waasheem
    Waasheem
    2007 xrunner
    You would think a modern vehicle this wouldn’t happen. My 2015 ford will lock the doors if I jump out & close the door. So I always make sure to put a window down first.
    bgavin[QUOTED] likes this.
  12. Jan 8, 2024 at 12:36 PM
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    I got rid of the fob when I got my 2007. Just too bulky.
  13. Jan 8, 2024 at 3:39 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I always make copies and use those daily. When they start to wear out after 12-15 years, I make a couple more copies from the originals and use those. Always keep a fresh original key for copying. Too many times I see people with just one original key and when it wears down they have nothing to go on.
  14. Jan 8, 2024 at 4:05 PM
    Williston
    New England
    I can confirm this really works. My co-workers would play this game starting their vehicles in the winter to see who's had the longest range. I would usually win until they noticed I would hold the key on my forehead when I pushed the button. Then they kicked me out of the club. Babies.
    Wessty likes this.
  15. Jan 8, 2024 at 4:29 PM
    #35
    Waasheem
    Waasheem
    2007 xrunner
    I learned this trick from my alarm installer. I think it turns your body into an antenna.
    Williston likes this.
