Check Your Oil More Frequently
Discussion in '4th Gen. Tacomas (2024+)' started by rat107, Jun 25, 2024.
  1. Jun 25, 2024 at 10:21 PM
    rat107
    rat107 [OP] Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
    Be sure to check your oil more frequently because turbocharged engines consume more oil than naturally aspirated engines. Mine was a little below the full mark on the dipstick with 1,000 miles on the odometer. I topped it off when it was brand new.
  2. Jun 25, 2024 at 10:24 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    That bronz oxide color is sweet
    rat107[QUOTED][OP] likes this.
  3. Jun 25, 2024 at 10:51 PM
    Log Monster
    Log Monster Member
    I like Ice Cap, personally. Stormtrooper vibes.
  4. Jun 26, 2024 at 5:38 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    A modern turbo motor should not consume oil.
    Vitamins, Phlogiston, dneal and 4 others like this.
  5. Jun 26, 2024 at 5:40 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Some recommend entirely changing your oil at the 1k mark due to the break in period. Hard to truly gauge anything at that time.
  6. Jun 26, 2024 at 5:45 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Your oil consumption should settle down since it was breaking in but overall yes, theoretically boosted engines will burn a little more oil. Especially if you idle lots.
    RedWings44[QUOTED] likes this.
  7. Jun 26, 2024 at 6:46 AM
    fourfourone
    Why would the engine burn more oil of the truck idles a lot?
    2016Tacoman likes this.
  8. Jun 26, 2024 at 6:56 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    I noticed this also when I had my WRX, the turbo did use a litte oil. I checked it every weekend.
  9. Jun 26, 2024 at 7:05 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    My TT Tundra doesn't consume any oil at all, I haven't had to add a drop through 18,000 miles on the odo (only going 5k on a change)... however, the main bearings may fail at any moment.
  10. Jun 26, 2024 at 7:06 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If it’s be pushed hard the turbos will burn more oil. But normal use after break in oil should t be consumed faster than n/a
  11. Jun 26, 2024 at 8:06 AM
    rat107
    Kauai, HI
    i had a brand new Ford 3.5L Ecoboost work truck and it would consume more than 1 quart of oil between oil changes.
  12. Jun 26, 2024 at 8:09 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    I don't know why I ended up here but where is that road?
    Just looks similar to a road I took when I kipped up somewhere a little east of Tuscon.
  13. Jun 26, 2024 at 8:15 AM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    This is Pamo Rd in Ramona CA just before forest route 11S01
  14. Jun 26, 2024 at 8:17 AM
    GarlicFarts
    Lil Rhody
    Well, I was at least like, sort of in the same region of the world :rofl:
  15. Jun 26, 2024 at 8:29 AM
    joba27n
    Nolan
    Alberta
    The turbo is lubricated by engine oil and the seals of the turbo that keep the oil in the bearings of the turbo and out of he intake and exhaust work best when the engine is under boost. Idling the engine doesn't put enough pressure on the seals for them to work well so they'll wear out faster from extensive idling.
    It's good to hammer down on any engine every now and then but with turbo engines I'd say it's almost compulsory to walk on the gas pedal atleast once a week and not drive like grandma all the time. Also though after driving hard a guy should putt around for a few minutes or let the engine idle for a minute or two afterwards so the turbo can cool with oil (and possibly coolant) flow before shutting off the engine.
    We're presently in the process at my job of switching back to gas job service trucks because the diesels burn so much oil... my field truck isn't too bad, burns about a quart a week... our shop truck burns about 4.5 quarts a week and smokes heavy blue at this point. Especially when it idles for a bit then you take off. Both have around 60'000kms (37'000MI) and are 2019 & 2022 Powerstrokes that were bought new.
  16. Jun 26, 2024 at 8:55 AM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    run a higher viscosity oil and dont wait 10k miles, problem solved
    JB_TN likes this.
  17. Jun 26, 2024 at 10:28 AM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    Gotta give them the ol' Italian tune-up on a regular basis.
    Gmak621 and joba27n[QUOTED] like this.
  18. Jun 26, 2024 at 12:34 PM
    miqie
    miqie Well-Known Member
    I thought the point of the thinner oil was easier passage through the turbo and thus better lubrication.
  19. Jun 26, 2024 at 4:17 PM
    fourfourone
    The point of thinner oil is to increase mpg.
  20. Jun 26, 2024 at 4:42 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    I don’t have that issue .. straight six :anonymous:
