Check your plugs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DesertSandMica, Jan 18, 2024.
  1. Jan 18, 2024 at 7:45 PM
    DesertSandMica
    DesertSandMica [OP] Member
    Chico CA
    17 SR5 4x4 LB 3.5 05 SR5 Prerunner 4.0
    Century Hi-C Snugtop Cab Hi Total chaos bed stiffeners
    Been reading over some posts about loose plugs from factory
    Decided to do my spark plugs today at 72k miles (have only owned it since 68k)
    Cylinder 5 completely loose no resistance :confused:
    Cylinder 6 slighty loose little resistance
    The rest were tight enough, some felt tighter than others.
    All plugs looked decent and uniformish
    Check your plugs
  2. Jan 18, 2024 at 7:51 PM
    Bishop84
    Bishop84 Well-Known Member
    Spark plugs are due every 60,000 miles, its early by modern standards but they were ready to be replaced.
    I usually dont see loose plugs on 2gr early or late so its not typical.
    Doesnt hurt to check though, the drivers side is a bit of a pain.
  3. Jan 19, 2024 at 2:51 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Been seeing a lot of these loose plugs threads … wondering if it’s a block issue or part issue on these trucks that’s causing the problem . How loose are u finding these plugs . They shouldn’t be tight just snug to create a seal .wondering also if people are assuming they are loose . The ones that are tight are just lacking anti seize grease .
  4. Jan 19, 2024 at 7:32 AM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    I saw a few Toyota techs in a Facebook group saying that their dealers “quietly” recommend plugs every 30k to help prevent burnt valves (p11ee etc). I was under the impression that ended up being a manufacturing defect with the valve seats that seems to mostly be resolved after 2020.
  5. Jan 19, 2024 at 7:40 AM
    Bishop84
    we saw it briefly but it was never explained to us and we reverted back to 60k
    it’s crazy how they never resolved the 2019s
  6. Jan 19, 2024 at 9:47 AM
    Russ68
    Russ68 Member
    Wisconsin
    2021 TRD Off Road
    I did my ‘21 OR at 60k. Had one plug loose from the factory.
  7. Jan 19, 2024 at 10:07 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Side note for this topic…..what plug brand do you recommend?
    @Bishop84
  8. Jan 19, 2024 at 10:23 AM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    Denso
  9. Jan 19, 2024 at 10:33 AM
    scocar
    scocar Patron of the Farts
    FYI Denso and NGK specify no antiseize.
  10. Jan 19, 2024 at 11:00 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I'm still a relatively new Tacoma owner with 16k miles on mine. This thread prompted me to research and I learned the factory plugs are copper; which for 60K miles isn't bad.
    I used to replace plugs at 30K miles on my old Hondas, but they for FWD I4's so it was a 10 minute job at most.
  11. Jan 19, 2024 at 11:01 AM
    Bishop84
    ngk or denso, pretty much the same
    I use a dab of anti seize but that’s me.
    faawrenchbndr likes this.
  12. Jan 19, 2024 at 11:06 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Thanks Bishop’
  13. Jan 19, 2024 at 11:16 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    So not to belittle this issue, because they should all be torqued to spec when built. But I see these posts saying they found a loose plug after 60, 000 miles of driving!
    They must have been tight enough to not cause any issues or throw any codes for 60K hard miles , right?
    cfarley, michael roberts, BMH and 2 others like this.
  14. Jan 19, 2024 at 11:21 AM
    MGMDesertTaco
    I've posted this a few times already, but I did all mine at 18k (7 years old at the time). All three passenger side plugs were extremely loose not even finger tight and a couple of the drivers side were loose, but not as bad.
    cfarley likes this.
  15. Jan 19, 2024 at 11:35 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Let’s say you were not a tech. Would you actually torque the plugs of go by feel?
    I never torqued a plug in my life yet.
    Never had an issue.
    My father has a Husqvarna string trimmer that will loose up once a season. He even had me “check” to make sure it just wasn’t him not getting it tight enough. Nope, he had that plug in there TIGHT. Still came loose. That’s the only time I’ve seen a plug come loose.
    ClassyTacos and golfindia like this.
  16. Jan 19, 2024 at 11:47 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    The first time I did plugs I used torque wrench, and got a decent feel for what 15 ft/lbs feels like. Now I just use a couple of fingers on the socket and half an ugaduga. I also use just a bit of anti seize.
  17. Jan 19, 2024 at 11:54 AM
    DesertSandMica
    Chico CA
    How loose? Well I have been doing many spark plugs replacements on many vehicles throughout my life and when I say loose, I mean loose as in just unscrewing by extension without a ratchet attached. Never have I encountered such a scenario before.
  18. Jan 19, 2024 at 12:01 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Conveniently Denso also specs an angle for tightening.
    https://am.denso.com/plug-global/basic/torque/
    I replaced my plugs at 70k. Could have gone to at least 90k. None of mine were loose.
    I wonder if people aren't just mis-judging how tight they were with all the extensions that are necessary. 13 ftlb is not a lot of torque.
  19. Jan 19, 2024 at 12:47 PM
    TnShooter
    Deogee
    STOCK
    Extension don't affect torque. Not if the ratchet head and extension stay inline with the bolt head.
    Binding of the extensions and ratchet head can, but the extensions themself do not.
    As does choking up on the ratchet. Choke up = Less torque.
    Torque In = Torque Out.
    davidstacoma likes this.
  20. Jan 19, 2024 at 12:54 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Just so we're clear... this does not apply to a torque wrench. The head is going to click at the designated torque, regardless of where you're holding it or if you put a 10' breaker pipe on it.
