*Check your spindle gussets for cracks with B/S talk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyProof, Feb 9, 2017.
  1. Feb 10, 2017 at 8:44 PM
    #181
    1MK
    1MK Desert Explorer
    Southern California
    Maybe 15k? I believe it was sometime early last year that they were installed.
    Had a wet rag over the CV boot, abs wire/sensor and tie rod for both grinding and welding. But great idea to spread the message to those that plan on doing this to theirs.
    99.9% of Tacoma's out there will never see this happen.
    TacoSuprise likes this.
  2. Feb 10, 2017 at 8:46 PM
    #182
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    stairgod likes this.
  3. Feb 10, 2017 at 9:32 PM
    #183
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    IMG_1183.jpg After reading all of this I'm going to check mine first thing tomorrow. I did the all pro with the sway bar. Maybe now it wasn't the best decision but at the time I was thinking something was better than nothing. On a positive note when my fabricator friend welded them for me I asked him to add an additional gusset to the steering knuckle. Without knowing any of this, it may help offset a poor decision. If they're not cracked yet then time will tell. Thanks to all who have shared their failures and successes.
    SonnyBones and MonkeyProof[OP] like this.
  4. Feb 11, 2017 at 12:07 PM
    #184
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I disassembled my front suspension. I'll have detailed photos of the spindles tomorrow. @Mach375 if you are in Fontana any time soon we can set something up to grab your spindle, or I can drive out to you Monday or Tuesday.
    IMG_20170211_114952.jpg IMG_20170211_115003.jpg IMG_20170211_114936.jpg IMG_20170211_115020.jpg
    1MK likes this.
  5. Feb 11, 2017 at 12:09 PM
    #185
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
    What inner boots are those?
  6. Feb 11, 2017 at 12:13 PM
    #186
    Anteupp
    Anteupp Mega Member
    mine are cracked in the exact same spot, I've got TC non sway bar gussets.
    1MK and tetten like this.
  7. Feb 11, 2017 at 12:19 PM
    #187
    tetten
    Andy
    Socal
    Those are CVJ remanufactured axles with their optional silicone boots, I don't know who manufactures the boot though.
  8. Feb 11, 2017 at 6:33 PM
    #188
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I only get through Fontucky when I'm headed to the dez.
    I do expect to be headed somewhere this coming weekend, haven't yet decided where.
  9. Feb 13, 2017 at 2:42 PM
    #189
    tetten
    Andy
    Socal
    Some photos of the fuck ups...
    I tried to take measurements and compare the new spindles to my intact passenger side, but I can't find any significant differences, most I can tell, if it is bent, it is by less than a 1/16 of an inch. No idea why the fit up on the gussets was so shitty, unless they came that was from TC.
  10. Feb 13, 2017 at 2:55 PM
    #190
    MonkeyProof
    SoCal- SGV
    Is that rust or dirt at the start of the failure?
  11. Feb 13, 2017 at 2:58 PM
    #191
    tetten
    Andy
    Socal
    At the shear of the spindle it is just dirt. If you are asking out of curiosity of if the shear was sudden or gradual(as evidenced with rust) it appears to be sudden (or very recently that the crack started).
  12. Feb 13, 2017 at 6:40 PM
    #192
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    This stuff is getting scientific. Nice work documenting it so far tetten, I'm learning a lot.
    How do you determine where the crack started?
  13. Feb 13, 2017 at 7:29 PM
    #193
    tetten
    Andy
    Socal
    I'm just going off where the start of the weld is in the vertical riser. That's where the shear occurred. Its hard to see in the photos but there is a flatish/smoothish (the weld bead) area where the shear started. After that the roughish grain area of the forged steel in the spindle is visible.
  14. Feb 13, 2017 at 8:14 PM
    #194
    Mudman
    Cerritos
    08 4X4 TRD Sport
    very interesting. I almost feel like this thread might have a small section where metallurgy discussion is heavy. :D
    Coot83 likes this.
  15. Feb 18, 2017 at 3:12 PM
    #195
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I've never been a big fan of the non-swaybar gussets but have offered them with an added gusset when I couldn't convince the buyer to run the swaybar version. I generally keep a few sets of gusseted spindles in stock and ready to ship as soon as the order comes in. I had this set spindles sitting on my shelf and decided to add an internal gusset to it to help strengthen the failure point
    PB FAB, 4x4Taco09, Whitecloud and 6 others like this.
  16. Feb 18, 2017 at 3:19 PM
    #196
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Do you have to remove the cv dust seal when welding the gussets on ?? Off the truck ?
  17. Feb 18, 2017 at 3:22 PM
    #197
    glorifiedwelder
    jason
    Santa Clarita, ca
    Most definetly on the newer style and of you're preheating for the older style. Takes about 30 seconds with a hammer and drift pin. I haven't damaged any yet while removing them. You'd be more likely to damage them putting them back in, but I haven't had any problems their either
    anthony250f likes this.
  18. Feb 18, 2017 at 6:05 PM
    #198
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I use, I think, a 1" black pipe flange to drive those seals. Might be 1.5", but I think either a large enough.
  19. Feb 24, 2017 at 9:40 AM
    #199
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    20170224_123709.jpg 20170224_123759.jpg Checked my tc non sway version. Cracked on one side indeed. Added the steering gussett outta 3/16". Cooled in a bucket of heated sand over night.
    tetten likes this.
  20. Feb 25, 2017 at 7:44 PM
    #200
    anthony250f
    Anthony
    San Diego, CA
    Will I be able to clear the sway bar tc gussets with 4.75 bs with 35s ? Or should I go with the non sway bar ones
