*Check your spindle gussets for cracks with B/S talk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MonkeyProof, Feb 9, 2017.
  1. Feb 9, 2017 at 9:14 PM
    #141
    1MK
    1MK Desert Explorer
    Southern California
    What's crazy is since seeing these two spindle failures, I would have never gave a second thought to them being an issue. Especially with them gusseted.
    MonkeyProof[OP] and EDDO like this.
  2. Feb 9, 2017 at 9:17 PM
    #142
    MonkeyProof
    MonkeyProof [OP] Power Top
    SoCal- SGV
    And another one bites the dust, at least you caught it before a potential total failure happened. I would imagine that is fixable with a bigger bead and with the addition of an added gusset as mentioned before, which I think how I'll deal with mine.
    1MK[QUOTED] likes this.
  3. Feb 9, 2017 at 9:20 PM
    #143
    1MK
    1MK Desert Explorer
    Southern California
    I'm going to pull it apart tomorrow and give it a better look. What I can see right now is that it doesn't wrap all the way around to the upright portion, and if I can confirm that I'm just going to fix it. Take a carbide bit and grind out the crack, re-weld, then gusset it into the steering arm.
  4. Feb 9, 2017 at 9:24 PM
    #144
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    You may also want to drill a hole where the crack stops to help prevent it from continuing even after it's welded
  5. Feb 9, 2017 at 9:52 PM
    #145
    jgantzler
    jgantzler Well-Known Member
    Jeremy
    Solid advice here. If you can drill the end of the crack, it will definitely stop it from becoming an issue.
  6. Feb 10, 2017 at 12:43 AM
    #146
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Very interesting read so far, I am intrigued. While my truck is pretty much bone stock- learning about this is fun.
    I'm no expert on anything, but the behavior of the cracking seems similar to cast rather than forged. I'm not saying it's one or the other, because I genuinely don't know. But the time I was reading this thread, I keep thinking "cast".
    Very curious to see what other details surface. Keep it up guys, we got some damn detectives here! :thumbsup:
  7. Feb 10, 2017 at 4:07 AM
    #147
    98tacoma27
    Ben
    Not Beech Creek
    I didn't positively identify anything; I just said I wasn't convinced it's forged. I never said I was convinced it's cast; although I do see my posts might reflect that. And common sense tells me to trust but verify. That's all I'm doing. Aren't we here to share ideas and learn? I'm just thinking out loud and trying to catch up with the rest of the pack.
    tacomgee and IronPeak like this.
  8. Feb 10, 2017 at 4:44 AM
    #148
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Sub'd for all the great information being spread around with the exception of a few assclowns. I wasn't seeing their comments then I realized they were already blocked from previous jackassery. Any who, can anyone post pics of the drilling to alleviate further metal fatigue and rewelding process? I am trying to visualize the drilling location and understand this part but have never seen this technique before. Thanks.
  9. Feb 10, 2017 at 6:19 AM
    #149
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    How do I aquire these?
  10. Feb 10, 2017 at 6:55 AM
    #150
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Call the Truck Shop in San Diego. Like, actual phone call.
    They're a local outfit, and tend to deal locally. In this case, they do the work on customer parts (I did specifically ask).
    jberry813 likes this.
  11. Feb 10, 2017 at 6:57 AM
    #151
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I'll have to give em a call then. Maybe they wouldn't mind shipping the gussets. If they refuse, then I suppose next best would be TC with sway bar. Unless anyone can suggest otherwise.
  12. Feb 10, 2017 at 7:01 AM
    #152
    Mach375
    Common technique to stop crack travel. Just a small hole at the tip of the crack. The idea is to, if you'll pardon the phrase, "build a wall" in front of it. You want the crack to have to completely start over, which is more difficult when encountering a perpendicular surface (the wall of the far side of the drilled hole) than it is to continue uninterrupted down the same path.
    Make sure the hole encompasses the end of the crack. Don't drill just beyond (crack still has to travel to get to a stopping point), and don't drill short (crack will continue on anyway).
    zippsub9[QUOTED] and jberry813 like this.
  13. Feb 10, 2017 at 7:04 AM
    #153
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  14. Feb 10, 2017 at 7:05 AM
    #154
    Mach375
    You could always ask a San Diego TW member to relieve them in the mail, walk them down, then ship them back.
    tacomgee likes this.
  15. Feb 10, 2017 at 7:07 AM
    #155
    Mach375
  16. Feb 10, 2017 at 7:11 AM
    #156
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
  17. Feb 10, 2017 at 7:53 AM
    #157
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    FWIW, I did this to mine, and they just cracked again. I did not add another gusset to the steering arm though, just ground them out and re-welded.
  18. Feb 10, 2017 at 8:30 AM
    #158
    Wasatch
    Wasatch Well-Known Member
    Hi all,
    Check out this resource for some good insight on spindle gussets:
  19. Feb 10, 2017 at 9:46 AM
    #159
    MojaveMadman
    MojaveMadman Cali Raised LED
    Los Angeles, CA
    2010 Tacoma TRD OR
    All New Everything
    Ok so I just read this post. It is long but I feel like this individual is making some very reasonable points. Mainly about suspension binding and what causes a spindle to bend or get damaged in the first place. I know not all will agree but this is a good post!!! It covers a few additional subjects but these are things I think anyone doing suspension modification NEED to understand.
    For those that are lazy (like me a lot of the time) here is the text from user devinsixtyseven on TTORA:
  20. Feb 10, 2017 at 9:55 AM
    #160
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I have the swaybar-less TC spindle gussets on mine and Im considering seeing if I can box up the bottom portion of the spindle around the TC gusset. Anyone else considering doing this in the long term? I think my spindles will be ok in the interim as I just got these reinforced, but I think if I boxed up the TC gussets completely that might add some decent strength?
    Coot
