Check your Tacoma - Hairline Cracks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Mar 25, 2010.
  1. Mar 25, 2010 at 5:52 AM
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I've been reading several instances lately on other forums about members finding hairline cracks in the steel uprights in the rear of the bed. I checked mine a short time ago and sure enough, I have them too.
    The area in question is adjacent to the tailgate hinges near the bottom of the taillight. If you open your tailgate you should be able to see what I am talking about. I'll try and get some pics ASAP also.
  2. Mar 25, 2010 at 6:18 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    W/o starting a debate, do the same people with cracks leave their tailgate down ever or a lot? Mine is 2 yo and has no cracks ....yet, never leave gate down 'cept for a plywood load i did.
  3. Mar 25, 2010 at 6:24 AM
    98tacoma27
    Ben
    Not Beech Creek
  4. Mar 25, 2010 at 7:06 AM
    Toogrady
    Toogrady Active Member
    Tom
    Olympia, WA
  5. Mar 25, 2010 at 7:14 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have read about this issue before, but I am not sure if it was this forum where I read about it. I believe it was covered under waranty as it should be...
  6. Mar 25, 2010 at 7:15 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    2ng gen beds are very weak, if you look in your mirror while going over bumps or are ever driving behind another 2nd gen going over bumps you will c what im talking about. Our beds are very flexible, they twist and shake with every little bump. My guess is that any one with cracks has been driving on rough terrain.
  7. Mar 25, 2010 at 7:16 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  8. Mar 25, 2010 at 7:17 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I'd actually have to say that its more so of the overly stiff sh*tty stock suspension. Having a good suspension/lift will tone down all the twisting and 'shocks' the bed has to deal with.
  9. Mar 25, 2010 at 7:19 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    really i find the stock shocks to be the opposite of stiff, I installed 5100's and its a lots more stiff now.
  10. Mar 25, 2010 at 7:22 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I leave it down all the time for the bikes. Ill check if i have them tonight
  11. Mar 25, 2010 at 7:29 AM
    Fortech
    CANADA
    Tailgate is never down unless I carry something too long for the bed and requires the gate to be down - which is rare.
    Just posting this up as a FYI as this doesn't really bother me much unless it escalates into something more drastic as the truck is now 5 years old. Others who find this problem on a newer Tacoma might be concerned though and may have luck getting it fixed if they wish.
    Apparently what happens here is the two uprights begin to crack and "fall away" from each other, making the opening in the end of the bed larger (between the taillights). Some of the individuals who first noticed this have camper shells, and noticed after time that the rear hatch on the shell would no longer seal due to the bed spreading so far apart, also increasing the opening in the rear of the shell. I don't run a camper shell but I do have a fiberglass tonneau that is on the truck from spring until fall.
    Its hard to see in the pics but the majority of the crack is visible but it does extend a little more but isn't visible in the pics - maybe an inch long in total on both sides.
    Left Side
    Right Side
    Left side tailgate gap
    Right side tailgate gap
    Anyone who is anal enough about this may want to get it checked out if they so desire - but like I stated earlier I doubt I'll do anything about it as the truck is now 5 years old. It isn't something I wanted to find, but honestly I don't care much either. I do have an appointment at the dealer tomorrow to get a wheel bearing replaced under my extended warranty, so I may mention this in passing. If they want to do something fine, if not I don't really care.
  12. Mar 25, 2010 at 7:42 AM
    Razorecko
    If he has an AAL thats probally why the ride is still pretty stiff. When I got rid of my aal for a leaf pack it was like going from a track car to a cadillac.
  13. Mar 25, 2010 at 7:45 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    yup probably, but still i thought my stock shocks were very soft.
    I havent looked but im pretty sure mine are cracked, as I can tell from looking in my rear view that the box is widening, I can see a space between the box walls and the tail gate on both sides.
  14. Mar 25, 2010 at 7:53 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    hmmm... When Ed put his "new" tailgate on he was having problems with the gap on the left and right. I wonder...:popcorn:
  15. Mar 25, 2010 at 8:48 AM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    I think you will find that most trucks have those cracks. When I found my cracks I started looking at others that day, 3 in the parking lot at work all were cracked from a little to a lot. Mine still are and I think I will let it ride until I see it being a problem then weld it up and add a gusset in there somewhere.
  16. Mar 25, 2010 at 8:49 AM
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    I have an 06 with almost 100K on it. I know my truck has been used off road quite a bit (bought used) but nothing too gnarly. It appears I have a slight crack on the right side, nothing on the left. The crack hasn't really separated tho, and is way smaller than in the photos above. Just eyeballing the gaps on either side of the tailgate, they seem to be pretty even.
  17. Mar 25, 2010 at 8:51 AM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    I am glued to this post! The brake pedal thing doesn't concern me -people are idiots. The drive shaft and spring pack TSB - whatever. Bed cracks - hmmmmmm that sucks. I guess if it is just starting after 5 years that's not too bad, but it makes me wonder what will it look like in 10 years? I know people in my area that keep their Toyota trucks for 10+ years. From the looks of the pics it is minor. However, frequent heavy tailgate loads can quickly extend the cracks, I am interested to hear what the dealership says.
  18. Mar 25, 2010 at 9:00 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    subscribed
    OZ
  19. Mar 25, 2010 at 9:05 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
  20. Mar 25, 2010 at 9:10 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I have an '07 with no cracks. Also where the crack is stemming from... the 'curved cutout'... the diameter of my cutout appears to be much larger than yours. Just an observation.
