Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. Aug 3, 2016 at 2:48 PM
    #241
    REDNECKTEX
    REDNECKTEX Well-Known Member
    TX
    2017 Inferno TRD Sport
    Kevlar seat covers Fox Shocks.
    did anyone get compensation for time in the shop on repairs?
  2. Aug 3, 2016 at 2:51 PM
    #242
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Some have been awarded extended platinum warranties, some have had monthly payments paid by toyota corporate, others have had money awarded to buy accessories. So I would not rule out other "incentives"--it's like hush money.
    The hardest thing seems to be getting Toyota to simply FIX the issues.
    REDNECKTEX[QUOTED] likes this.
  3. Aug 3, 2016 at 9:47 PM
    #243
    REDNECKTEX
    TX
    so they well pay for the issues.. thank you that is
    great
  4. Aug 6, 2016 at 6:53 PM
    #244
    Bree
    Bree Active Member
    Bree
    So should I have the u bolts checked for grease to be sure?
  5. Aug 6, 2016 at 7:30 PM
    #245
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    There are U-Joints (part of the drive shaft assemblies) that need periodic grease addition and may be low on grease from the factory. Not all Tacoma's have grease fittings on the U-Joints.
    This thread is about the U-Bolts that hold the axle to the rear leaf-springs. The jury is still out on why (my opinion is normal relaxation) folks are checking how tight the nuts are (torque) and finding they turn some amount before they reach the specified torque. Mine turned a little, but not enough that I think there was a problem.
    Some folks on this thread are intentionally mixing the two subjects for comedic effect (well, I assume that was the intent). You may know all this stuff already, but with 23 posts I'm assuming you are new here and I hate to see someone confused by our banter.
    [Edit: There are other threads on the U-joints. I had mine checked and they took grease to fill. There's debate whether that indicates an issue or not, but better to be safe. Again, not all Tacoma's have fittings to grease the u-joints, so it may not apply to your truck)]
    REDNECKTEX likes this.
  6. Aug 7, 2016 at 5:56 AM
    #246
    Bree
    Bree Active Member
    Bree
    Thanks for explaining the difference. I go in Monday for the software update, and will ask if my u joints have grease fittings then. It helps to know what I'm talking about, so thanks again.
    P.S: I do get caught up in the banter sometimes. It can be pretty entertaining. Have a good one!
  7. Aug 7, 2016 at 1:12 PM
    #247
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
    It looks like you have the SR. I believe it's only the TRD Off-Road models that have zerk fittings on the u-joints to allow greasing (the other's are sealed). I'm not positive, but I wouldn't be surprised if they say you don't have zerks so they can't add grease.
  8. Aug 7, 2016 at 1:52 PM
    #248
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    2017 MGM Tacoma TRD Sport 4x4 DCSB Manual
    I have a TRD Sport 4x4 with serviceable u-joints.
  9. Aug 7, 2016 at 5:57 PM
    #249
    Bree
    Bree Active Member
    Bree
    You're right, I have the SR. Sounds like I don't have to worry about it. Thanks for the info!
  10. Aug 8, 2016 at 12:30 AM
    #250
    Qwntm
    Qwntm Well-Known Member
    Edward
    Boise, ID
    2016 Inferno TRD Off Road DCSB
    None...yet!
    I have a TRD Off Road and only found zerks on the front drive shaft u joints. I couldn't find any on the rear driveshaft U joints. Are they hidden or is that just the way it is?
  11. Aug 8, 2016 at 3:19 AM
    #251
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You're about the third person I seen mention lack of zerks on their 4x4 rear driveshaft.
    Apparently, Toyota has changed this recently.
  12. Aug 8, 2016 at 5:02 AM
    #252
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If you've rotated the driveshaft one complete time and don't see any, then they took them off. They will all be on the same side.
  13. Aug 8, 2016 at 5:52 AM
    #253
    gr0ver
    gr0ver Taco Supreme
    Charleston, SC
    Might need to move the truck forward or backwards some to get to the aft driveshafts zerks. Front easy since you can just rotate it by hand.
  14. Aug 8, 2016 at 6:09 AM
    #254
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    I have a 4x4 SR, and can confirm mine came with 5 zerks. Best way to know is crawl under it yourself and look.
    EDIT - Also need to get off my ass and check my u-bolts. Don't have a torque wrench (yet), but I imagine it's pretty easy to tell if it meets the German torque spec of 'gutentight' or not.
  15. Aug 8, 2016 at 6:15 AM
    #255
    TRDPro4x4
    TRDPro4x4 Well-Known Member
    Yay! Merica!
  16. Aug 8, 2016 at 8:27 AM
    #256
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    don't guess, wait until you have a torque wrench.
  17. Aug 13, 2016 at 8:40 PM
    #257
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Back to ubolts, installed Icon AAL with my stage4 today, forward ubolt both sides were loose, I mean loose, surprised they did not worked themselves off....aft ubolt were torqued. WTF? we were warned I was just too damn lazy to crawl under the truck until I had too.
  18. Sep 26, 2016 at 4:53 PM
    #258
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    Mine were at around 37... I did them up to 54 just to be safe. I used to have a clunk when I would go from a coast to acceleration and now its smooth. I think it was def loose from the factory. I even asked them to check the u joints and bolts when I had the TSB done for the Trans.
    tonered and REDNECKTEX like this.
  19. Sep 26, 2016 at 5:07 PM
    #259
    REDNECKTEX
    TX
    Well my goodness i do have torque wrench better check these and because the third member and transfer case have already been replaced in this truck it could be possible for a certified Toyota wrench to look at these bolts but i really cant confirm this.
  20. Sep 26, 2016 at 6:19 PM
    #260
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Does doing this apply to the SR5 models? If so what should they be torqued to?
