Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. Jan 4, 2017 at 6:22 PM
    #281
    SK bassin
    SK bassin Well-Known Member
    2016 Tacoma XP package
    Does tighting the u bolts apply to 4x2 owners
  2. Jan 4, 2017 at 6:43 PM
    #282
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Applies to all Tacomas with a rear axle.
  3. Jan 4, 2017 at 6:44 PM
    #283
    SK bassin
    I'm still confused on how to check them. I've read almost this whole thread. Can you dumb it down
  4. Jan 4, 2017 at 6:44 PM
    #284
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I think you're confusing the u-joints with 4x2 vs. 4x4.
    U-joints are on your driveshaft. 4x2 have non-greasable, whereas 4x4 do.
    U-bolts are what hold your leaf springs to the axle.
    Yes, it applies to 4x2s.
    It's commonly recommended by leafspring manufacturers to re-torque new u-bolts after 500 miles; after things have settled in.
    Omar RVA and SK bassin[QUOTED] like this.
  5. Jan 4, 2017 at 6:45 PM
    #285
    SK bassin
    Okay thanku. Do you think Toyota did this for my 5000 check
  6. Jan 4, 2017 at 6:57 PM
    #286
    filbert
    filbert Well-Known Member
    Chicago
    2016 Tacoma TRD OR DCSB V6 MT
    To check your u-bolts, get a torque wrench and set it to your desired torque (52 ft-lbs) and attempt to tighten the u-bolts lugs. if the Torque wrench clicks (assuming you have a click type wrench), then you're good. If the bolts turn, then turn them until they click, which will mean you've tightened them to the torque you set.
    Toyota may or may not have done it at your 5k check. Maybe your receipt will show if they performed the service, but it's easy to check them, only takes 5 minutes (most of which is getting your torque wrench and socket ready).
    SK bassin[QUOTED] likes this.
  7. Jan 4, 2017 at 7:07 PM
    #287
    splitbolt
    NW Arkansas
    No.
  8. Jan 4, 2017 at 7:08 PM
    #288
    J0mes
    J0mes Active Member
    James
    16' TRD Off Road
    You are going to need to buy a torque wrench, basically as you use the wrench it will tell you the amount of force you are applying to the nut or whatever, as it gets increasingly tight.
    As for the U bolts gonna need to get under the truck there are several pics these guys have posted as to the location man.
    It's all very simple. GL
  9. Jan 4, 2017 at 7:11 PM
    #289
    SK bassin
    Thanks bud. Also is it just 8 bolts ?
  10. Jan 27, 2017 at 6:25 AM
    #290
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    I wonder - is there any difference when torqueing the u-bolts whether the truck is on the wheels or lifted from the frame? If the spec is 52 lb-ft, wouldn't that have been done on assembly with the truck on a lift?
  11. Jan 27, 2017 at 9:49 AM
    #291
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Just checked the U bolts on my 17. I set a torque wrench at 52 foot pounds and all 8 nuts were tight. No movement. They were definitely torqued higher than 52. It appears Toyota finally got this issue corrected.
  12. Jan 27, 2017 at 2:52 PM
    #292
    sathump
    sathump Member
  13. Feb 4, 2017 at 7:10 AM
    #293
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    You kill me man. :rofl:
  14. Feb 4, 2017 at 2:42 PM
    #294
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    I wouldn't think it would matter,....... FWIW, I had 1 out of 8 that was less than 52 foot pounds, the truck had the wheels on the ground.
  15. Feb 11, 2017 at 8:13 PM
    #295
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Anyone have a factory torque spec sheet for the 3rd gen? Just got a lift but didn't torque down everything and want to do so before an alignment tomorrow.
  16. Mar 20, 2017 at 5:35 PM
    #296
    16coma
    16coma Member
    Orange, CA
    My 2017 4wd does not have zerks on the rear wheel drive shaft - only on the front wheel drive shaft. I think Toyota is using the same drive shat for 2wd and 4wd trucks. Makes sense to use as may common parts as possible.
  17. Mar 20, 2017 at 6:03 PM
    #297
    splitbolt
    NW Arkansas
    Correct; as of June/July 2016.
  18. Mar 20, 2017 at 6:29 PM
    #298
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Just like my rear wheel drive. Not a zerk to be found. I wonder at what mileage the u-joints will start whistling. I am guessing one week past the warranty.
  19. Mar 20, 2017 at 6:53 PM
    #299
    splitbolt
    NW Arkansas
    Depends how contaminated they become and it's angle of operation.
    There is the school of thought that non-greasable u-joints are stronger because they are solid and lack grease channels.
  20. May 18, 2017 at 6:07 AM
    #300
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Finally got around to checking my U bolt nuts last night. 3 of the 8 were loose. 2 were on the same U bolt. I got a good 1 to 1.5 turn on both of them. I had been hearing a clunk in the rear stopping. That's gone now. Guess I should have done this 8k miles ago.
    splitbolt[OP] likes this.
