Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. May 18, 2017 at 8:05 AM
    #301
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    Looking for the person that shared with me the torque specs for the suspension components. Please PM them to me again would ya! lol thanks!
  2. May 19, 2017 at 7:20 AM
    #302
    Chazmann
    Chazmann A/C TRD Sport V6 4x4 6-MT
    Checked mine last night.
    3 were in the spec or tighter > 52 ft.lbs.
    5 were lower than the spec < 52 ft.lbs.
    5 required anywhere from 1/4 to 1/2 turn to bring into the spec.
  3. Jul 25, 2017 at 4:15 PM
    #303
    cwolgy88
    cwolgy88 Well-Known Member
    Cody
    2017 Toyota Tacoma TRD Sport
    None as of yet
    Really glad I saw this thread. I've been expierencing odd vibrations throughout the truck/steering and a loose feeling (squirmy?) rear end.
    I just checked the rear leaf spring U Bolt Nuts on my 2017 TRD Sport 4WD Auto transmission with 4900 miles on the odometer and ALL 8 u bolt nuts were loose! None of them were at 52 ft lbs, I got 1/2 to 3/4 turn out of every single nut to hit 52ft lbs. I then put them all at 60ft lbs using a X pattern.
    Haven't driven it yet to see if anything has changed but I'm in shock all 8 nuts were loose.
  4. Jul 25, 2017 at 4:21 PM
    #304
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Pretty common - though in my case I was able to get several turns out of some of them. my dealer told me.... no lie... that if they were a little looser it should have softened my suspension vs. hardened impacts. ha... my hard hits from the rear ceased. I do notice they tend to loosen a bit over time so I get under there now every 2-3k miles (more if I've been offroad or driving on rougher fire roads)
    cwolgy88[QUOTED] likes this.
  5. Jul 25, 2017 at 4:34 PM
    #305
    cwolgy88
    Cody
    None as of yet
    Wow, that's quite crazy. Now that I think about it mine was probably closer to 1 1/4 turn on each to reach 52 ft lbs.
    I noticed my driver axle to be quite loose in the trans too, new thread coming...
    bshammer0[QUOTED] likes this.
  6. Aug 28, 2017 at 1:51 PM
    #306
    Six7
    Six7 Well-Known Member
    RVA
    '17 DCSB TRD Sport
    Good info here. It seems that a couple of mine were under torqued from the factory, though not grossly.
  7. Aug 28, 2017 at 3:16 PM
    #307
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    If you mean the driverside CV driveshaft into the front differential, it's the needle bearing...normal.
    ECGS bushing is the only fix.
  8. Aug 28, 2017 at 4:05 PM
    #308
    cwolgy88
    Cody
    None as of yet
    That's exactly what I was referring to, Dealer says it's normal and not the cause of my steering wheel/cab vibrations.
  9. Oct 6, 2017 at 8:49 AM
    #309
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Same here. I found my U-bolts loose and torqued them. The rear feels much better this morning and the clunk on and off the gas seems to be way better.
  10. Oct 6, 2017 at 9:48 AM
    #310
    20ravens52
    20ravens52 Well-Known Member
    Maryland
    2017 Toyota Tacoma TRD-Offroad DCLB in MGM
    So is this an issue on 2017's or was it just with the 2016's?
  11. Oct 6, 2017 at 9:57 AM
    #311
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    My two week old 2017, built in May in TX, were loose. It took about two full revs to torque. All eight were pretty freaking loose.
    I have almost 700mi on it. So, it could just be the springs settling in?
    20ravens52[QUOTED] likes this.
  12. Oct 6, 2017 at 9:59 AM
    #312
    splitbolt
    NW Arkansas
    2005-present...
    I will concede, new leaf springs do require re-torquing; usually at 500 miles. But with the amount of looseness and low mileage being reported, I think it's prudent to check earlier and periodically thereafter.
    Costs 5 minutes of my time.
    tonered and 20ravens52[QUOTED] like this.
  13. Oct 6, 2017 at 10:08 AM
    #313
    20ravens52
    Maryland
    Thanks guys, guess I'll be checking these this weekend.
  14. Oct 10, 2017 at 8:45 AM
    #314
    20ravens52
    Maryland
    I checked mine, and about 6-7 of the bolts were under the recommended 52 lbs. I tightened them up and the ride and handling is definitely better.
    tonered likes this.
  15. Oct 17, 2017 at 8:37 PM
    #315
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    I put the Wheelers AAL, their instal instructions say to torque 75-80 lbs. I don't know if the torque is higher because the AAL but I put mine at 75.
    tonered likes this.
  16. Apr 13, 2018 at 10:19 AM
    #316
    taco abbo
    taco abbo Well-Known Member
    rob
    Ellsworth,Ohio
    2018 tacoma trd off road
    TRD Pro Grille
    is it a 14mm or 19mm nut on the 18's?
  17. Apr 13, 2018 at 11:31 AM
    #317
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I agree. Mine have stayed at the set torque (70ft-lb) since the retorquing. The retorquing was a minor PITA, but checking takes no time at all.
  18. Apr 13, 2018 at 11:48 AM
    #318
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Thanks to this thread I realized my tacos bolts were under torquered. Tightened it to 52ft lbs and it’s been great so far .
    tonered likes this.
  19. Apr 13, 2018 at 10:31 PM
    #319
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    Both nuts on one of the u-bolts on each side were torqued to spec. The other u-bolt on each side required the nuts to be tightened further. If I had to guess, after torqueing the nuts on the second u-bolt on each side, the factory worker did not go back to check the torque on the nuts of the first u-bolt installed.
  20. Apr 14, 2018 at 6:12 PM
    #320
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    I just checked them on the ‘18 Taco. 1 out of 8 was only torqued to 52 ft lbs. The rest of them took like a full turn. Ya’ll sold me on self maintenance.
    tonered likes this.
