Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. May 9, 2020 at 5:44 PM
    #361
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    2020 TRD OR coming out of Mexico on 02/20. 3 of 4 bolts on each side were not up to spec (a little odd); 4th bolt was at 52 lb-ft. They were not super loose, maybe 1/8-1/4 turn each.
    It's almost like whoever installed them gave just a few more ugga-duggas to the first bolt on each side than all the others. Or maybe they had to run their impacts off of pancake compressors that day. Anywho, all torqued to spec now. That's at least 20hp more.
    Nunya Bizness likes this.
  2. Aug 30, 2020 at 11:15 AM
    #362
    ihatemytruck
    ihatemytruck Smartass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB
    What size socket do they take......I gotta pick up a deep socket for it. Thanks
  3. Sep 1, 2020 at 10:13 AM
    #363
    ihatemytruck
    Dave
    Southern California
    Do you remember what size the bolt is?
  4. Sep 1, 2020 at 10:17 AM
    #364
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I think it is 19mm? Wait on verification though.
    I would say to pick up the deep impact socket from HF? The full set is something like $20 and they're good and fit tight. :cheers:
    ihatemytruck[QUOTED] likes this.
  5. Sep 1, 2020 at 10:46 AM
    #365
    ihatemytruck
    Dave
    Southern California
    Good call......for $20 it would be good to have more options! Gonna head there to pick up a new floor jack anyways. Thanks
    tonered[QUOTED] likes this.
  6. Sep 1, 2020 at 10:48 AM
    #366
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    Yeah. They have worked great for normal ratchet use and with my corded impact driver.
    :hattip:
  7. Sep 1, 2020 at 1:27 PM
    #367
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Well i just checked my 2020 ac built in texas for those loose U bolt nuts. I can tell you they were all very tight cranked down to at least 75 ft.lbs. when i put my 1/2 matco torque wrench on them. Not one nut even gave a hint of moving.
  8. Sep 1, 2020 at 4:48 PM
    #368
    Smacky2020
    Bristol, VA
    @tonered right on the money, 19mm or 3/4" if you're in a pinch.
    tonered and zoo truck like this.
  9. Sep 1, 2020 at 8:41 PM
    #369
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Thanks for the confirmation!
    :cheers:
  10. Sep 3, 2020 at 10:33 AM
    #370
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    As was said, M14x1.5 thread with a 19mm hex. :cheers:
    Jeff
    ihatemytruck and tonered like this.
  11. Sep 3, 2020 at 10:38 AM
    #371
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hey, Jeff.
    You might be more in tune with this. Any idea what the situation is with the loose U bolts? This is my first leaf spring vehicle since HS, and then, we never touched them. Of course back then, torque wrenches were as furrin' as the cars. :D
    Within about 500mi of new, mine were loose enough to be heard and felt with slack throttle in the upper gears. I check them every 10k or so now and they are still as solid as I left them.
    :hattip:
  12. Sep 13, 2020 at 5:05 PM
    #372
    Unab8dLy4m
    Unab8dLy4m Active Member
    Louisiana, USA
    2020 Super White Tacoma Utility Package
    Thanks for this! I torqued my 2020 SR's U-bolts to 52 ft-lbs. They were probably at 37 ft-lbs before.
    zoo truck likes this.
  13. Sep 13, 2020 at 5:30 PM
    #373
    zoo truck
    None
    Its about what i checked mine at after seeing the dia.size u-bolts...i set my torque wrench at 55 ft. lbs. in which they had been torqued to at least that at the factory.
    Unab8dLy4m[QUOTED] likes this.
  14. Sep 14, 2020 at 10:04 AM
    #374
    ihatemytruck
    Dave
    Southern California
    Torqued mine to 73 ft/lbs. Some where definitely not even close.
  15. Sep 14, 2020 at 10:46 AM
    #375
    zoo truck
    None
    Imo, i think 73 ft. lbs. was too much. After thinking about it, i double checked, and set mine to 55 ft.lbs. Their still plenty tight. Don't know if they need be as tight as you would torque tire lug nuts.
  16. Sep 14, 2020 at 12:34 PM
    #376
    ihatemytruck
    Dave
    Southern California
    I dunno. A lot of people are doing 73 because the service manual has it at 37...... probably as a typo, so I went with 73.
  17. Sep 16, 2020 at 11:16 AM
    #377
    Kaptain_02
    Kaptain_02 2019 OR
    Started at 25lbs and increased it to 5lb increments until I got to 60lbs, none of them required any additional torque.
    A Texas torque wrench must have been used at the Texas factory on mine
  18. Sep 23, 2020 at 11:09 AM
    #378
    Blackfoot
    Blackfoot Well-Known Member
    2020 TRD Sport Midnight Black 4X4
    If you have not checked yours yet - GET YOUR ASS UNDER THERE AND CHECK...
    Mine is a 2020 TRD Sport built 06/20 and has 1,170 miles on it. I have not been off road yet, but it took between 2 full turns and 2-1/2 full turns to bring it up to 55 ft. Lbs. on every single nut. “WTF”
    I should have dialed back the torque wrench to see what they were set at, but not much comes to mind.
    Are there any other bolts I need to be checking?
    This isn’t an inconvenience - this is a safety issue
  19. Sep 23, 2020 at 11:12 AM
    #379
    jruiz555
    jruiz555 Well-Known Member
    2019 8k miles 6 out of 8 bolts had to be retorque to 52ft lbs
    Not by a lot of it did move a bit
    Smacky2020 likes this.
  20. Sep 23, 2020 at 11:41 AM
    #380
    zoo truck
    None
    I checked mine, they were so tight i initially couldn't move them. I ended up getting a 1/2'' breaker bar, and loosening them then re-torqueing to 55 lbs. Figured that should be safe.
