Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. Sep 30, 2021 at 2:15 PM
    #401
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    it hops pretty good kinda feels like those small and abrupt speed bumps in a parking garage.
  2. May 29, 2022 at 6:45 PM
    #402
    TACO-TY
    TACO-TY Not so well-known member
    Tyler
    Eastern WA
    '25 DCSB Sport
    Just check mine today. 1100 miles on it. Got 1½-2 turns a piece out of my ubolts. Torqued to 70ft lbs.
    tonered and cryptolime like this.
  3. May 29, 2022 at 7:19 PM
    #403
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine were at 32 ft./lbs when i checked them the first time....it felt pretty dang loose
    TACO-TY likes this.
  4. May 30, 2022 at 5:23 AM
    #404
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I guess if you have one of those rear ends that howl, its easy to loosen those u bolts when they need to replace it.
  5. May 31, 2022 at 9:16 AM
    #405
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    Torqued mine too 52 ft lbs. Each nut moved about 1/2 - 1 turns after tightening multiple times in a criss-cross pattern until they stopped moving.
    AZ Pete likes this.
  6. Jul 30, 2022 at 4:52 AM
    #406
    SkinnyT
    SkinnyT Member
    I've recently had a rattling sound coming the the rear of my 2016 dcsb off road and got under it yesterday to check the unbolts, thinking this might be causing the metal rattle when going over a bumpy road. All seem to be torqued to 70 ft lbs already.
    I purchased the truck from a guy here in the forums, so he may have already tightened them up, but now I'm stumped as to where the noise is coming from.
  7. Oct 8, 2022 at 3:48 PM
    #407
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    Felt compelled to check. About half were at least 52, the other half were somewhere between 42 and 52. 2 in particular needed at least half a turn. Doubt it was a problem, but worth putting to spec.
  8. Jul 16, 2023 at 2:01 PM
    #408
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Checked mine today. All needed to be tightened to 52 ft lbs. except for 1. 695 miles on the odo.
  9. Jul 17, 2023 at 6:12 PM
    #409
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
    Total dummy here guys but i just checked my 2022 utilty with a less that 1 year old harbor freight torque wrench and i set it for 55 lb lbs .So if they are already tight enough would the torque wrench immediately start clicking ?It never clicked and i was really horsing the wrench and im a pretty strong dude 200+lbs .I wasnt giving it all i had but they were turning and they felt pretty tight but didnt get any clicks on the wrench?Any insights ?Like i said total noob with torque wrenches but i assumed if they were already tight enough it would easily start slipping and clicking.(im paranoid my wrench is broke and im overtightening)Thx guys
  10. Feb 20, 2024 at 6:10 AM
    #410
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    My Proto 1/2 drive torque wrench settings are from 60ftb’s to 200ftb’s., so I guess I’ll go with the lowest setting of 60ftb’s and call it good. Also , I wish I knew somebody around me that could calibrate my wrench properly. I’ve seen some you tube videos on homemade ways to calibrate the wrench but that is about as accurate as throwing horseshoes.
