Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. Oct 27, 2015 at 12:33 PM
    #41
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What is the torque value set at?
  2. Oct 27, 2015 at 12:36 PM
    #42
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    So Angela, how long have you been on the line of production where the torquing takes place ?
  3. Oct 27, 2015 at 12:38 PM
    #43
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Didn't know that the nuts and bolts have to be re-torqued at 30,000 miles, but I'm not even at 30,000 kms and the bolts were loose over a year ago.
  4. Oct 27, 2015 at 12:41 PM
    #44
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    :rofl:
    Low blow
  5. Oct 27, 2015 at 12:44 PM
    #45
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    I think it was caused by these being under-torqued,
    ...also re-torqued the cab mounts though.
    Giborim likes this.
  6. Oct 27, 2015 at 12:53 PM
    #46
    TMMIgirl
    TMMIgirl Well-Known Member
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    This is not just for u bolts, it's for any critical, federally related torque. Even sometimes on a non critical joint if it's prone to being forgotten or covered up before inspection can check it.
    If I remember its around 90. I'll verify for sure when I go back.
    You should check the u bolts with each tire rotation and loctite them.
    tonered likes this.
  7. Oct 27, 2015 at 12:55 PM
    #47
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What's with Toyota... they want me to bring my truck in every 8,000kms to re-torgue the propeller shaft bolts as part of the reg. mtce...
    Why wouldn't they just drill the bolt end and put in a wire to secure it, or a washer with the "bend-up_ flange ,....
    I think they just put that crap on the mtce. schedule to make it look like they do a lot for you...!!
    I never torqued my '06's nuts.... Oh well..
    TMMIgirl likes this.
  8. Oct 27, 2015 at 1:56 PM
    #48
    TMMIgirl
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    Is this a test?
    Sienna is a unibody and has coil springs that are compressed on chassis line.
  9. Oct 27, 2015 at 2:11 PM
    #49
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    What did you end up torquing them to?
  10. Oct 27, 2015 at 2:14 PM
    #50
    Markc1024
    Markc1024 Well-Known Member
  11. Oct 27, 2015 at 2:22 PM
    #51
    TMMIgirl
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    Are they standard? As far as I knew every bolt used was metric with the exception of the seatbelt bolts.
  12. Oct 27, 2015 at 2:30 PM
    #52
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No it's not a test, in you're first post , you explained the process on the assem. line with torque gun & alarms, I was wondering what was up with torque values on Tacoma U bolts...
  13. Oct 27, 2015 at 2:35 PM
    #53
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The recommended torque for the U-bolts on the 2016 is 52 ft-lbs.
    The recommended torque for the U-bolts on the 2015 is 37 ft-lbs.
    They are the same hardware for both.
    Jeff
  14. Oct 27, 2015 at 2:37 PM
    #54
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    In case you missed it : 1st gen/2nd gen/3rd gen all use same hardware... Up to 2004 (end of 1st gens) Torque value was 90ft.lbs, in 2005 (first production year for 2nd gen) FSM states 37ft.lbs
  15. Oct 27, 2015 at 2:46 PM
    #55
    Markc1024
    Good to know Jeff, thanks. Considering everything read, I'm going with 55 ft lbs and calling it good; they were below 40 upon checking. I will check again in a few months.
    0uTkAsT likes this.
  16. Oct 27, 2015 at 3:08 PM
    #56
    TMMIgirl
    Angela
    Haubstadt Indiana
    TRD off road DC SB
    Im just saying the bolts didn't leave the factory loose, what ever the torques are supposed to be.
    The springs just settled after some miles. I plan on checking mine too. Wonder if they check them with the scheduled oil changes/ maintenance?
    Robozoo likes this.
  17. Oct 27, 2015 at 3:13 PM
    #57
    DrFunker
    DrFunker Well-Known Member
    FIFY
    :D
  18. Oct 27, 2015 at 3:18 PM
    #58
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yes, quoted myself, you guys can tighten them to whatever you think is safe,if you believe Toyota's spec to be correct more power to you, myself , I stand by what I've said all along & I'll leave it at that...
    DrFunker likes this.
  19. Oct 27, 2015 at 3:21 PM
    #59
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Just checked mine on my 2015, they were all about 37ft.lbs - 40ft.lbs. I tightened them all to around 60ft.lbs.
  20. Oct 27, 2015 at 3:23 PM
    #60
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & I'm saying I've been under about 200 of your Tacomas (2nd gens) some brand spanking new & literally all had extremely loose nuts, a lot of them not even 37ft.lbs, watch that short vid i posted , that wasn't BS, they were that loose...It HAD to leave the assem. line that way
