Check Your U-Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Oct 26, 2015.
  1. Oct 27, 2015 at 3:25 PM
    #61
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Big words, I like it, probably should've said " I haven't got the patients"...;)
    DrFunker[QUOTED] likes this.
  2. Oct 27, 2015 at 3:32 PM
    #62
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The 1st-generation did not use the same hardware. It is similarly sized, but not the exact same. The 2015 and 2016 are the exact same.
    Jeff
  3. Oct 27, 2015 at 3:43 PM
    #63
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Haha, oh really ?? How'd I get 2nd gen Ubolts on my 1st gen ?
    I really don't care what you've read or what part# corresponds with what, respectfully , you're wrong...
    JLee likes this.
  4. Oct 27, 2015 at 3:58 PM
    #64
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Why are we checking u-bolts? Is there an issue this is supposed to fix?
  5. Oct 27, 2015 at 3:58 PM
    #65
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Now the clamps/brackets that Ubolts go thru are different, but the Ubolts/nuts are virtually the same..
    I've put 2nd gen Ubolts on 1st gens & vice/versa
  6. Oct 27, 2015 at 4:00 PM
    #66
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    2nd gen Ubolts on 1st gen...
  7. Oct 27, 2015 at 4:04 PM
    #67
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    But I'm done , ya'll go with what you believe to be correct, I've spent too much time in the 3rd gen sec. trying to educate, trying to help, not typing to see my shit in print, just sharing my real world experience working on Tacomas ...
  8. Oct 27, 2015 at 4:17 PM
    #68
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Whatever you torque them to - how about adding some blue loctite...
    FirstTimeTaco2020 likes this.
  9. Oct 27, 2015 at 4:23 PM
    #69
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep, good idea Ding,you can lead them to water but you can't make them drink...
  10. Oct 27, 2015 at 4:36 PM
    #70
    Markc1024
    Markc1024 Well-Known Member
    Geez guys, just asking questions to understand and be informed. Who takes anything they read on the internet at face value without challenging it? I've been working in a tech support business for over 25 years. When we fix something, we want to understand why it requires fixing to start with and correct it there. With 10's of thousands of Tacoma's on the road with supposedly bad u-bolt torques coming from the factory, and no major failures/recalls related to this, I'd suspect that Toyota set those specs for a reason. Before I write off their logic, it makes sense to try and understand it first. With the 2016 spec now up'd to 52 ft-lbs, it appears to be a conscious decision.
  11. Oct 27, 2015 at 4:36 PM
    #71
    Jeff Lange
    Calgary, Canada
    I wasn't even arguing with you. My point was that even though they are the same size and (obviously) fit and work, they may not necessarily be the exact same grade hardware. It's possible the 1st gen had better hardware than the 2nd gen (and vice versa), while on the newer ones the parts are literally identical from the same factory and yet used different torque specifications.
    In any case, your information is not falling on deaf ears, the more accurate information the better. I've seen a lot of misinformation in Toyota truck forums (forums in general, really), and so do my best to provide the most accurate information possible. There are many reasons for a different part number and they may very well be identical just made at a different factory or from a different supplier. (Or 1mm longer or shorter or some other trivial thing)
    Jeff
    Markc1024 likes this.
  12. Oct 27, 2015 at 5:27 PM
    #72
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Toyota logic you say?
    No major recalls you say?
    :rofl:
    You're right, go do your own research.
  13. Oct 27, 2015 at 5:34 PM
    #73
    EWM
    EWM Active Member
    A while back I showed the Tacoma U-Bolt to my Machinist friend, and he stated that the 37 ft# was a believable value because the U-Bolt is a fine-pitched thread. He said with a fine-pitched thread that there is more total thread surface area that makes contact between the U-Bolt and nut, which would be the equivalent of more torque needed for a coarser thread. TIFWIW.
  14. Oct 27, 2015 at 6:57 PM
    #74
    Jeff Lange
    Calgary, Canada
    Finer thread can be torqued to a higher value.
    Japanese automakers love fine thread. :)
    Jeff
  15. Oct 28, 2015 at 8:14 AM
    #75
    EWM
    EWM Active Member
    Per boltscience's website:
    [​IMG]What are the benefits of fine threaded fasteners over coarse threaded fasteners?
    The potential benefits of fine threads are:
    1. Size for size a fine thread is stronger than a coarse thread . This is both in tension (because of the larger stress area) and shear (because of their larger minor diameter).
    2. Fine threads have also less tendency to loosen since the thread incline is smaller and hence so is the off torque.
    3. Because of the smaller pitch they allow finer adjustments in applications that need such a feature.
    4. Fine threads can be more easily tapped into hard materials and thin walled tubes.
    5. Fine threads require less torque to develop equivalent bolt preloads.
    On the negative side:
    1. Fine threads are more susceptible to galling than coarse threads.
    2. They need longer thread engagements and are more prone to damage and thread fouling.
    3. They are also less suitable for high speed assembly since they are more likely to seize when being tightened.
    Normally a coarse thread is specified unless there is an over-riding reason to specify a fine thread, certainly for metric fasteners, fine threads are more difficult to obtain.
  16. Oct 28, 2015 at 8:39 AM
    #76
    Jeff Lange
    Calgary, Canada
    Yup, they require less torque, but can also take a higher torque value as well.
    Jeff
  17. Oct 28, 2015 at 9:28 AM
    #77
    splitbolt
    NW Arkansas
    What is the T-rating?
  18. Oct 28, 2015 at 9:28 AM
    #78
    Jeff Lange
    Calgary, Canada
    What do you mean?
    Jeff
  19. Oct 28, 2015 at 9:36 AM
    #79
    splitbolt
    NW Arkansas
    Toyota's way of designating bolt strength.
  20. Oct 28, 2015 at 9:37 AM
    #80
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I would not trust a harbor freight torque wrench.
