Check your U-Bolts!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jerrfylube, Apr 17, 2018.
  1. Apr 17, 2018 at 6:16 AM
    Jerrfylube
    Jerrfylube [OP] Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    This is a thread in response to a recent manual transmission thread about clunky drivetrains... specifically to post #70 of this thread: https://www.tacomaworld.com/threads/manual-transmission-1st-2nd-gear.448567/page-4#post-17631671
    I've had my '17 DCSB OR for almost a year and it's never had what I would call a "smooth" drivetrain--especially compared to my '04 Taco. When crawling around in 1st gear through parking lots, over speed bumps, small off-road obstacles, or when shifting from 1st to 2nd, it's always had a bit of a clunky noise/feeling coming from the middle/rear section of the truck. I had the dealer look at it a few months back and got the standard response... "It's normal".
    After reading the above thread, I saw a post about the u-bolt nuts being loose. I crawled under mine with a 19mm socket and a torque wrench and sure enough, they were unbelievably loose! At best, they were at 20-25 ft lbs.
    After torquing them to 52 ft lbs (I got nearly a full rotation before the torque wrench broke away!) last night I was really astonished on my drive to work this morning. About 75% of the clunky noise/feeling is gone and the transition from 1st to 2nd feels a good bit smoother! Makes me think there is more loose hardware somewhere that is causing the rest of the noise. I will be hitting every single fastener I can get my hands on and verifying proper torque--there is no doubt in my mind that I will find more.
    Shame on you, Toyota! :mad:
  2. Apr 17, 2018 at 6:18 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Mine's pretty clunky too. I'll check them tonight.
    And mine's clunky even when in gear or coasting. Not just shifting. The first thing that popped into my head was those u-bolts but I keep forgetting to check them.
    Modesto Tacoma likes this.
  3. Apr 17, 2018 at 6:32 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Yeah... funny story here. I took my truck into the dealer and was complaining about how the truck was hitting every bump in the road so hard it was really starting to legitimately hurt my back. Like I would get to the point of tensing up before a bump in the road knowing it was about to shoot up my spine. Asked the dealer to check torque... said all was good. I got home and pulled out my torque wrench and I'd be shocked if they were over 20... Tightened them up and all was good and nice and soft like I expected.
    I mentioned this to the dealer on my next visit and their response... "if anything looser u-bolts should make it ride smoother..." and from then on it was clear the only maintenance I could get done reliably would be by my own hands.
  4. Apr 17, 2018 at 6:34 AM
    Jerrfylube
    CA
    Oddly enough, I have an appointment this afternoon to get the TSB done for the rear end whine... I'll be double checking all their work.:rolleyes:
    AdventureKid likes this.
  5. Apr 17, 2018 at 6:40 AM
    ExGunner
    ExGunner Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    i have an appointment this Thursday to get 1" spacers installed and a set of Sumo springs at the dealership. I'l definitely be making sure they document the torque spec has been set correctly.
    I do not let the dealers away with anything and demand they specify what spec they torqued things to and check when i get home if i can . That way if it was done incorrectly and causes damage i have proof they lied.
    Julian and awdvkd115 like this.
  6. Apr 17, 2018 at 6:48 AM
    ChukarBob
    ChukarBob Well-Known Member
    Bob
    Seattle
    2017 TRD Sport DC LB 4WD AT; preceded by '15 Subaru Outback & 2007 Tacoma SR5 DC LB 4WD AT
    OK, first a confession -- I have the mechanical aptitude of a trained chimpanzee.
    I would like to check my U-bolts. I have a torque wrench, 1/2 and 3/8 ratchets, assorted sockets and extenders. I know how to use these tools. Once I get my creaky 68 year old body under the truck, will it be self-evident what I'm looking for and need to do?
  7. Apr 17, 2018 at 6:51 AM
    Jerrfylube
    CA
    Yes. Find the u-bolts attached to the rear axle ... the nuts will be staring you right in the face when you crawl underneath the rear. There's a total of eight 19mm nuts you will need to tighten--4 on the left, 4 on the right.
    Spare Parts likes this.
  8. Apr 17, 2018 at 6:51 AM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    I'm always a little suspicious when people say they know what a bolt was torqued to - just because it took 28 ft-lbs to back a bolt out doesn't mean that it was torqued to 28 when it went in
  9. Apr 17, 2018 at 6:54 AM
    commbubba19
    '23 TRD PRO
    True, but if you get 1/2 a turn before it clicks at 50 ft lb's, it was no where near torqued to spec.
    over60 likes this.
  10. Apr 17, 2018 at 6:54 AM
    Jerrfylube
    CA
    I didn't back it out--set the wrench to 52 and torqued.
    I can't give you a specific number of what they were torqued to, but I've been a military equipment/aircraft mechanic for longer than many here have been alive and am very familiar with what 20-30 foot pounds feels like--it was NOWHERE near 50 ft lbs.
    rmepilot likes this.
  11. Apr 17, 2018 at 6:58 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Let us know how that goes for ya! Respond to one of the howl/diff threads with your results if you can.
  12. Apr 17, 2018 at 7:00 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Time to hit a different dealership! They don't deserve your business...
    shakerhood and Dirty Harry like this.
  13. Apr 17, 2018 at 7:06 AM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Jerrfylube[OP] likes this.
  14. Apr 17, 2018 at 7:08 AM
    Jerrfylube
    CA
    I didn't know you could tag people... I'm not that tech-savvy. :oops:
    But I do appreciate your advice! :headbang:
    '16goingon'17[QUOTED] likes this.
  15. Apr 17, 2018 at 7:09 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Also check that the spare tire is cranked up tight :thumbsup:
    rmepilot and tonered like this.
  16. Apr 17, 2018 at 7:31 AM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    @remgu2000 Looks like this has been an issue from the factory. Yours should be good and tight.
    remgu2000 likes this.
  17. Apr 17, 2018 at 8:29 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    U-bolts torque is 75lb.
  18. Apr 17, 2018 at 8:30 AM
    VoodooBlueATL
    2007 FJ Cruiser
    This...
  19. Apr 17, 2018 at 8:31 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Never forget! :bananadead:
  20. Apr 17, 2018 at 8:34 AM
    VoodooBlueATL
    2007 FJ Cruiser
    That will go down in history!
    Dirty Harry[QUOTED] and tonered like this.
