Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jan 11, 2016 at 3:54 PM
    #221
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Have you considered that maybe the transmission is low on fluid..?? My '06 was low and did the "thing" at the lights...ie: downshift rough..?? I checked at it was 1 1/4 liters LOW from the factory.... It fixed the issue for me.. Many others had low trannies also....
    I bet the 3rd gens are low also....!!
    kashtyaatsi and Buffy like this.
  2. Jan 11, 2016 at 4:19 PM
    #222
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    They supposedly checked my fluid the other day and it was fine. will bring this back up with them later.
  3. Jan 11, 2016 at 4:47 PM
    #223
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    You must steadily pump into zerk until squirting.
    alf and splitbolt[OP] like this.
  4. Jan 11, 2016 at 5:24 PM
    #224
    REB55
    REB55 Well-Known Member
    SE LA
    2011 SR5 Prerunner Access Cab
    Sold POS 2016 SR5 DCSB
    So us 2wd owners will just have to run our trucks until the u-joints squeal I guess? That is unless we want to do something goofy like replace ours before they go bad with some that have zerks. My son's 2wd, 2nd gen went 95,000 miles before we replaced his first one.
  5. Jan 11, 2016 at 9:03 PM
    #225
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    This or check your owners manual!
  6. Jan 12, 2016 at 12:04 PM
    #226
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You're late. We're talking about what grease to put in a sticky booted slip joint should it ever require service.
    There are 3 to choose from; lithium (Spicer spec), lithium w/moly(Toyota spec), or Ford XG-8(teflon).
    http://www.lowrangeoffroad.com/ptfe...-ford-motorcraft-xg-8-ml1167-31508-42027.html
    I'm thinking the Teflon lube is better on nylon coated splines.
  7. Jan 12, 2016 at 12:28 PM
    #227
    02TacoBro
    02TacoBro Well-Known Member
    Houston, TX
    2012 TRD SPORT 4WD, 6 SPD Manual, 3DR
    1.5" Suspension Lift Android Auto / Sound System GettaGrip Shifter
    Holy shit!! now I know what was wrong with my 4runner.... 3 years later. Fuck it, its not mine anymore.
  8. Jan 12, 2016 at 1:39 PM
    #228
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    This thread got me paranoid so I greased all the u joints. Only took 2-3 pumps for me. Either OP's grease gun is at fault or the assembly line is iffy. Also the grease coming out the u joints was black, so is the oem grease Molly based? As far as I know Molly greases are black
  9. Jan 12, 2016 at 2:57 PM
    #229
    splitbolt
    NW Arkansas
    My grease gun is fine.
    Besides, you can't compare just your experience vs mine.
    Your only about the second or third person that's been a 2-pump chump.
    Everyone else is on par with my experience.
    So, I'm going to go with iffy assembly line if those are the choices.
    The lithium complex I used was black...
    Lithium complex, lithium w/ moly and moly-base comes in all kinds of colors.
    Spicer ships u-joints with their calcium sulfonate grease to protect the needle bearings during shipping/storage; it's green.
    If Toyota adheres to their spec, they should be using lithium complex in the U-joints, during and after assembly. I'm of the mind they are not being lubed/purged after assembly at the least.
    Lithium w/ moly should be used in double cardan and slip yokes/joints, per Toyota.
    It's becoming apparent though, there are no double cardan or serviecable slip joints on the '16s
    How many miles do you have and what did your zerks look like?
  10. Jan 12, 2016 at 3:00 PM
    #230
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    I still say DELO ep2. After we switched to it our fleet failures went way down.
  11. Jan 12, 2016 at 4:04 PM
    #231
    Sep1911
    2016 Taco
    3.5k on the taco. Zerks seemed to have been painted over. Lol
  12. Jan 12, 2016 at 4:23 PM
    #232
    splitbolt
    NW Arkansas
    If your zerks were untouched, they were never properly lubed/purged from the factory.
    Toyotacare doesn't cover that until 15,000 miles.
  13. Jan 12, 2016 at 5:08 PM
    #233
    Ang graz
    Ang graz Active Member
    2016 DCLB SR5 4x4 BRM
    Tin cover I'm pretty sure used 12mm bolts on front drive shaft. If you spin the shaft by hand and point the zerk straight toward the passenger side, found its easiest to reach that fitting from there if you're laying on the ground underneath it
  14. Jan 12, 2016 at 5:26 PM
    #234
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Put it on a rack and you can just spin both shafts in neutral
  15. Jan 12, 2016 at 5:29 PM
    #235
    Ang graz
    Yea, but I'm going to guess that not everyone has a rack in their garage or driveway
  16. Jan 12, 2016 at 5:35 PM
    #236
    Aussiek2000
    2016 Offroad AC
    Sucks for them
  17. Jan 12, 2016 at 5:40 PM
    #237
    Ang graz
    You're my hero
  18. Jan 12, 2016 at 5:53 PM
    #238
    Aussiek2000
    2016 Offroad AC
    If you knew how often I heard that
  19. Jan 12, 2016 at 6:54 PM
    #239
    splitbolt
    NW Arkansas
    Lucky...
    Which skid is that?
  20. Jan 12, 2016 at 8:04 PM
    #240
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    In 2H the front shaft spins sitting on the ground. I jack my rear from under the pumpkin and place on jackstands to do the rear shaft. Don't forget to release the parking brake and place truck in neutral after it's on the jackstands. I've done the reposition truck until the angle is right route, but it's quicker to just put it on jackstands.
