Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jan 13, 2016 at 12:03 AM
    #241
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    I mean... that works... but you can also move the truck a few inches and the zerks all align downward. I got lucky in that mine were properly aligned when I squeezed my truck into my undersized garage. I'm just not a fan of jack stands if you can avoid them. I'm just paranoid, though.
  2. Jan 13, 2016 at 12:26 AM
    #242
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    Just chock one rear wheel and put your jack under the other side of the axle, u-bolts. Put the truck in neutral and lift that wheel off the ground. Spin that tire and you've got access to all the
    zerks. Totally safe.
  3. Jan 13, 2016 at 3:21 AM
    #243
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Pelfreybilt
    splitbolt[QUOTED][OP] likes this.
  4. Jan 13, 2016 at 4:31 AM
    #244
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    "Just chock one rear wheel and put your jack under the other side of the axle, u-bolts. Put the truck in neutral and lift that wheel off the ground. Spin that tire and you've got access to all the
    zerks. Totally safe."
    Seems simple, easy and safe. Thanks for this....................... Frank
  5. Jan 13, 2016 at 6:07 AM
    #245
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    What exactly do you mean by purged?
  6. Jan 13, 2016 at 7:37 AM
    #246
    Metalnut
    Adam
    North Alabama
    I believe in this case "purged" is defined as the grease pushing out of the u-joint to show that it's fully greased.
  7. Jan 14, 2016 at 4:39 PM
    #247
    mlm682577
    mlm682577 Well-Known Member
    Mark
    DFW, TX
    2016 Blazing Blue Tacoma TRD OR DCSB
    60+ mods and counting (mod-aholic)
    I stopped by Toyota of Irving (TX) to see if they would shoot some grease in the u-joints for me since it was on the way home. After 20 minutes at the service desk while the representative called to see if the service mgr could get me in, I was told the service mgr said that the 2016 tacomas 4X4s do not have grease fittings on the u-joints. Having seen them myself, I told the rep they were incorrect. He just shrugged his shoulders and said I must be mistaken....WTF?? I am not sure what's more embarrassing...the customer service or the fact they have no clue about my truck. Obviously it was useless to argue with a stiff so I stopped by Auto Zone and picked up a tube of Green Grease NLGI #2 and shot some grease in with a pneumatic gun. I stopped counting after 10 shots on each....sheesh!!
    splitbolt[OP] and 0uTkAsT like this.
  8. Jan 14, 2016 at 6:45 PM
    #248
    Metalnut
    Adam
    North Alabama
    Well, at least now you know which dealership to avoid :)
    SandyTaco4x4 likes this.
  9. Jan 17, 2016 at 12:36 PM
    #249
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    finally got under there. i had a bitch of a time finding the zerk behind the heat shield, but eventually got it. all 5 zerks took a good 6-7 pumps.
  10. Jan 17, 2016 at 4:24 PM
    #250
    007TRUCK
    007TRUCK Well-Known Member
    Did all 5. All took about 2-3 pumps. 1 hand pressed on the zerk and another pumped the grease. What purged was orangish color grease, not black grease that was injected into.
    For #2, just loosened the cover with adjustable wrench, couldnt get socket to fit there.
    Thank you.
  11. Jan 17, 2016 at 4:54 PM
    #251
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Yelp the story so more people are aware that this dealership sucks.
    Buffy likes this.
  12. Jan 17, 2016 at 6:16 PM
    #252
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
    Mine were all pretty good, only 2 pumps before starting to purge.
  13. Jan 17, 2016 at 6:33 PM
    #253
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    As long as you can get all 4 seals to purge.
    Nice and slow when pumping grease.
    You're not supposed to exceed 60 psi.
    69TACO16 likes this.
  14. Jan 18, 2016 at 6:54 AM
    #254
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    any suggestions on a Mobile 1 compatible grease?
  15. Jan 18, 2016 at 10:06 AM
    #255
    MapleTaco
    MapleTaco Member
    Toronto, Canada
    2016 Black SR5 DCLB 4x4
    Greased mine at about 2,600 km (1,600 miles) with Lucas oil red n tacky #2.
    They definitely seemed dry, some black substance came out but not to the extend you would expect at all - basically just enough to dirty the first bit if my grease to purge. Took well over 8 pumps for each joint.
    A good point I saw in an earlier post, the front shaft will rotate freely for better access if needed.
  16. Jan 18, 2016 at 1:34 PM
    #256
    mvusa
    mvusa Well-Known Member
    2016 Silver Tacoma TRD Off Road 4x4 Access Cab V6 Auto
    I would say, Mobil 1 Synthetic Grease.
    Certified to the NLGI GC-LB specifications and is NLGI Grade 2.
  17. Jan 21, 2016 at 3:58 PM
    #257
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Greased mine today, same story as others, several pumps.
    Also, for those of us who hate crawling back out from under your truck to grab a wrench/ratchet, you don't need to remove the shield to get to the joint on the t case side front drive shaft. Just reach from the top, or slightly bend the shield down towards you and it'll open enough to get the grease gun in there.
    I used Lucas heavy duty (green). Meets the same standards but is a little more water resistant.
  18. Jan 21, 2016 at 4:01 PM
    #258
    AFMurse2014
    Devin
    San Antonio
    Also, I've never had a truck with a carrier bearing/center bearing... Do we grease these or are the sealed units?
  19. Jan 21, 2016 at 4:06 PM
    #259
    Aussiek2000
    2016 Offroad AC
    All the ones I've ever seen are sealed
  20. Jan 21, 2016 at 4:08 PM
    #260
    splitbolt
    NW Arkansas
    They are sealed; non-servicable.
    AFMurse2014[QUOTED] likes this.
