Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jan 30, 2016 at 1:49 PM
    #361
    j102
    j102 Well-Known Member
    2016 Tacoma SR5 4x2 Double Cab Short Bed.
    I have a 2WD, I guess I don't have to worry about it. But, I will still check tomorrow morning. ;)
  2. Jan 30, 2016 at 1:51 PM
    #362
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    FWIW, happened on one of mine, too.
    Spicer recommends you do not exceed 60 psi.
    The Lincoln 1133 grease gun mentioned in this thread can develop 7,500 psi.
  3. Jan 30, 2016 at 2:01 PM
    #363
    j102
    I kept reading the thread and no need to worry on the 2WDs.
  4. Jan 30, 2016 at 8:15 PM
    #364
    j102
    What's the factory torque spec (or recommended) for the bolts on the U-Joints?
  5. Jan 31, 2016 at 6:01 AM
    #365
    3rdGenDCOR
    3rdGenDCOR Well-Known Member
    TX
    16 OR DCSB
    Crap - now is this something I need to worry about? I don't know how to check this after pumping to ensure not over pressurized? I waited for a seal or two to push through. I always had a slight backfill of grease after removing fitting from the zero but was a normal amount from back when I was younger and when removing coupler from the zerk fitting.
  6. Jan 31, 2016 at 8:43 AM
    #366
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    Back pressure does not close the ball. It it spring loaded. If it leaks out the ball, you need to change the zerk or it will sling the grease out while driving. Press on the ball of a new zerk, you will feel the spring. The ball can get dirt under it, keeping it from seating. Always wipe off the zerk before greasing,this will make the coupler last longer too.
  7. Jan 31, 2016 at 9:44 AM
    #367
    Metalnut
    Metalnut It's a clown world
    Adam
    North Alabama
    2016 Tacoma DCLB 4x4 TRD OR
    BP-51s, UCAs, BAMF sliders, SCS Stealth 6, 285 Wildpeaks, HIDs, LEDs, custom grille, hard top.
    For documentation's sake, is there a good howto on replacing zerks on our trucks?
  8. Jan 31, 2016 at 6:40 PM
    #368
    splitbolt
    NW Arkansas
    Probably the paint the zerks were covered with.
  9. Feb 1, 2016 at 12:15 PM
    #369
    retired mech
    Tom
    St louis,Mo.
    Poke around on the ball with an o ring pick or something pointy and see if you can get it to seat again.
  10. Feb 1, 2016 at 3:42 PM
    #370
    el_zorro1
    el_zorro1 Well-Known Member
    Zorro
    Northern Virginia
    Thanks OP and everyone else: bolts and grease....check√
  11. Feb 2, 2016 at 5:33 PM
    #371
    mello03
    mello03 Dr. Dirty
    Greensboro, NC
    2020 F250 6.7
    I finally talked my dealership into trying to fix my slip yoke bump. Rode with the shop foreman etc.
    He ended up taking the shaft off and putting the Motorcraft XG8 ptfe on it. Immediately the clunk is gone. We'll see how long it stays gone, but at least I know for sure where it's coming from. I'll push for a new shaft if it comes back. He at least is contacting Toyota about my issue, so that's good I guess.
    They initially said they drove another truck on the lot and it did it too. I talked to the service manager and said "I know they don't all do it" so we took another one. No clunk....
    splitbolt[QUOTED][OP] likes this.
  12. Feb 2, 2016 at 6:00 PM
    #372
    barberjd
    barberjd Member
    Warm, Sunny... Ohio
    04 TRD, 05 TRD, 94 Toyota 4x4, 05 Toyota reg
    All stock... NAVI, bluetooth, Siruis, TRD wheels.
    All my grease fittings were bone dry!
  13. Feb 2, 2016 at 7:48 PM
    #373
    Gutt Pile
    Gutt Pile Well-Known Member
    2016 Blazing Blue TRD Offroad
    Any pattern to these like all Texas or Baja? Friday afternoon shift trucks?
  14. Feb 2, 2016 at 7:49 PM
    #374
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Yes, there is a pattern. All of them! :rofl:
  15. Feb 2, 2016 at 7:57 PM
    #375
    Gutt Pile
    SO much for the mythical total quality management crap that they are supposed to do on the line.
  16. Feb 2, 2016 at 8:18 PM
    #376
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Yea, I guess they assume the dealers will lube them
  17. Feb 2, 2016 at 8:22 PM
    #377
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    Is an issue like this something Toyota's sent out a TSB for in the past?
  18. Feb 2, 2016 at 8:36 PM
    #378
    splitbolt
    NW Arkansas
    There is relationship between quantity and quality in manufacturing.
    Toyota did add 3rd shifts at both plants to increase production.
    Good, fast, cheap; pick two, I reckon.
    Be a shame if it was SOP.
    Yours were gtg from the factory?
  19. Feb 2, 2016 at 8:39 PM
    #379
    splitbolt
    NW Arkansas
  20. Feb 2, 2016 at 9:00 PM
    #380
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I'll let you know later this week when I check them. I know the front end needs grease
