Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Feb 22, 2016 at 1:28 PM
    #461
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It is a calcium sulfonate...which is what Spicer grease is.
    I'd say good to go; just make sure you purge any old grease completely, for compatibility's sake.
    I ended up going with Mystik JT6 #2.
  2. Feb 22, 2016 at 1:33 PM
    #462
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Regular or hi-temp JT-6?
  3. Feb 22, 2016 at 1:38 PM
    #463
    splitbolt
    NW Arkansas
    Hi-temp...
    NLGI Certified GC-LB
    These high temperature Lithium Complex greases combine excellent multi-purpose properties with
    a high dropping point to give them application over a wide temperature range. Mystik JT-6 Hi-Temp
    greases exhibit a high Timken OK Load in addition to providing excellent Four-Ball Wear and EP
    performance. They provide superior protection to lubricate a wide variety of automotive, agricultural,
    trucking, mining, construction, and industrial equipment. They provide outstanding shock load
    protection. JT-6 Hi-Temp No. 2 is an extremely versatile performer that is highly recommended for
    disc brake wheel bearings and is specifically approved for use in Rockwell and Spicer universal
    joints. This grease provides excellent protection for heavily loaded industrial, mining, and construction
    applications. JT-6 Hi-Temp No. 1 was developed for applications where service conditions dictate
    a grease of softer consistency. Both meet the highest performance categories of ASTM D-4950
    Automotive Grease Classification System, GC for wheel bearing service and LB for chassis service.
    • Mystik JT-6 Hi-Temp Greases provide excellent protection in severe service requirements such as
    disc brake wheel bearings, backhoe hinge pins, and conveyor bearings
    • Mining operations, sand/gravel plants, and construction equipment where shock loads are placed
    on bearings benefit from the use of Mystik JT-6 Hi-Temp Greases
    Dana Corporation
    Spicer Universal/Joint Division
    M-2006-J (#2)
    Registered NLGI GC-LB
    Weatherford Artificial Lift (#2)
    NSF H2 (125250)
  4. Feb 22, 2016 at 1:42 PM
    #464
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    That sounds great, will switch over to that from the valvoline multi-purpose when I hit 5000. Thanks.
  5. Feb 22, 2016 at 1:53 PM
    #465
    splitbolt
    NW Arkansas
    I found it at O'Reilly's.
    I think Citgo is the parent company.
  6. Feb 22, 2016 at 2:18 PM
    #466
    Duc Tec
    Duc Tec New Member
    Phoenix AZ
    2016 QuickSand Tacoma TRD Sport
    I greased my zerk fitting at 1300 miles and it took 3-4 pumps until i saw grease coming out, fyi.
  7. Feb 23, 2016 at 1:43 PM
    #467
    rtgreene10
    rtgreene10 Well-Known Member
    Fl cracker
    4x4 turd
    I see people on here always talking about replacing U-joints.... How do you Know if they're bad? Besides a vibration feeling?
    Is there something I can put my hands on and check?
    Edit. Just saw this is 3rd gen. But question still stands
  8. Feb 24, 2016 at 8:13 AM
    #468
    Doug007
    Doug007 Well-Known Member
    Doug
    Houston, TX
    '16 TRD Off-Road M/T
    I greased mine last night. I have only 220 miles on my TRD Off-Road M/T.
    The front driveshaft zerks had a red grease purge out of them after a few pumps.
    The three rear driveshaft zerks had no discernible grease purge until the grease I was adding appeared! I'm glad I did this after seeing that on the rear driveshaft!
    Also had to give the U bolts about 1/2 a turn to get to 52 ft-lbs.
  9. Feb 26, 2016 at 7:04 AM
    #469
    SteveS197
    SteveS197 Well-Known Member
    I didn't know U-Joints have grease fitting any more. My 2012 and 2014 MusTang GT didn't have grease fittings on the U-Joints from the factory or front end. Good to know. When My Truck arrives that will be one of the things I will check.
  10. Feb 26, 2016 at 7:21 AM
    #470
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    some do some dont...Me personally I like the ones with fittings so I can grease them. Otherwise you end up having to change them at some point...depending on driving conditions...
  11. Feb 26, 2016 at 7:26 AM
    #471
    splitbolt
    NW Arkansas
    Spicer Service Manual PDF
    http://www2.dana.com/pdf/DSSM-3264.pdf
  12. Feb 26, 2016 at 8:09 AM
    #472
    Doug007
    Doug
    Houston, TX
    Great stuff @splitbolt
    Do you know the torque value and which bolts the owner's manuals are talking about when they discuss torquing the propeller shaft bolts?
    The maintenance log language is "Re-torque propeller shaft bolt."
  13. Feb 27, 2016 at 12:14 PM
    #473
    bpp1015
    bpp1015 Member
    2016 White Limited Double Cab Taco
    Factory Stock
    Obviously I missed the comment somewhere. I crawled under mine and no zerks. Not 4WD. 16 DCL 2x4.
  14. Mar 1, 2016 at 1:26 PM
    #474
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
    Mine were bone dry took 6 to 8 pumps, grease that came out was the new stuff.
  15. Mar 1, 2016 at 2:06 PM
    #475
    splitbolt
    NW Arkansas
    Sorry; don't have the numbers for 3rd gen.
    2nd gen was 65 ft/lbs.
  16. Mar 1, 2016 at 2:15 PM
    #476
    nafoo
    nafoo Well-Known Member
    Houston
    '10 TRD Off road
    My used 2010 TRD OR had to have the driveshaft replaced at 106,000 miles due to the "U-Bolts coming loose." Not sure if that was due to a lack of grease or not, but this thread makes me think it was. Luckily I purchased the extended warranty when I bought the truck at 89,000 miles.
  17. Mar 1, 2016 at 2:31 PM
    #477
    splitbolt
    NW Arkansas
    U-bolts or U-joints?
    What was it doing?
  18. Mar 1, 2016 at 3:15 PM
    #478
    nafoo
    Houston
    '10 TRD Off road
    I heard the service advisor say u-bolts, but maybe he meant u-joints? Not sure. My truck was vibrating when accelerating.
  19. Mar 1, 2016 at 3:27 PM
    #479
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I would've eaten that guy alive for a comment like that. As a shop foreman, he should be the first to know that 4x4 Tacos have u-joints that can/must be greased...... or maybe he could't care less about his career and customers. :rolleyes:
  20. Mar 1, 2016 at 3:28 PM
    #480
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    sure he was a foreman? and not just some service writer or lubie
