Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 1, 2016 at 5:42 PM
    #481
    WIDGIN9
    WIDGIN9 Well-Known Member
    Earth, I think.
    2016 MGM 4x4 Limited, 2001 Black 4x4 SR5 Doublecab
    NRA Life Member Sticker, Body Armor 4x4 Step Rail, Leer Trilogy Bed Cover
    Mine only took 3-4 pumps with my minigun so they had sufficient grease in them from factory. Still, was easy to check.
  2. Mar 1, 2016 at 7:57 PM
    #482
    Toneloc
    Toneloc Well-Known Member
    Northwest PA
    2016 DCSB 4x4 TRD OR
    My 4x4 OR has about 3300 miles. Took a good 10 pumps from my pistol grip.
  3. Mar 1, 2016 at 9:34 PM
    #483
    old-timer
    old-timer Well-Known Member
    South Central Texas
    2016 Silver SR5, V6, 2WD, AT, DC, SB w/Tow
    Crawling around under my (less than a week old) 2WD Tacoma, found several balancing weights on the two drive shafts, but no zerks.
    Will try again, with better light and less sleepiness.
    We may have some kind of "only the dealer can fix" U-joints, made of semiprecious plastic or something.
  4. Mar 1, 2016 at 10:20 PM
    #484
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    2wd have sealed, non-greaseable u-joints.
    You can still inspect them once in a while if you want.
    Check for:
    -play
    -seals
    -retainer clips
    -thrown weights
    old-timer[QUOTED] likes this.
  5. Mar 3, 2016 at 4:32 PM
    #485
    the taco crna
    the taco crna Well-Known Member
    Tim
    South Texas
    2016 Quicksand TRD OR 4x4 AC
    Me too! same truck, same mileage, and I may have lost count at 10! After the second night under the truck, I am still unable to get a coupler on the zerk under the heat shield. I've tried everything including grinding down the coupler and trying a needle and have let the frustration win out for now. Its almost like the relief cut in the yoke is not big enough on mine to allow a coupler access. The seals look the same as all the others did leading me to believe it too has not been purged and is basically bone dry.
  6. Mar 3, 2016 at 4:45 PM
    #486
    retired mech
    retired mech Well-Known Member
    Tom
    St louis,Mo.
    2016 sr5 double cab v6 4wd
    Have never seen a zerk you can't reach with a needle. If it's that tight you couldn't even see it. Did you remove the heat shield?
  7. Mar 3, 2016 at 5:10 PM
    #487
    the taco crna
    Tim
    South Texas
    Yes sir, heat shield removed. I had to bend the needle slightly to make contact, felt it depress the ball in the zerk but grease still came out and not in. I put a 3/8 wrench to the zerk to align it with the relief cut of the yoke and it seems tight. I think I will try the Lincoln you recommended earlier as I was using the cheaper bevel cut needle which was all they had at AutoZone. Its a slow and steady squeeze right? Again, the yoke seems to be in the way (as well as other things) despite the shallow relief cut. Willing to try any recommendations you may have sir. Thanks
  8. Mar 3, 2016 at 5:20 PM
    #488
    retired mech
    Tom
    St louis,Mo.
    Yes slow steady pressure when using the needle. I would try changing the zerk. The threads can vary a little letting you tighten it a different position. You might also try putting some teflon thread tape on the current zerks threads. This can lubricate the threads letting you tighten it a little more.
  9. Mar 3, 2016 at 5:22 PM
    #489
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    Greased mine at 800 and then again at 2600. Took several pumps both times.
  10. Mar 3, 2016 at 5:30 PM
    #490
    retired mech
    Tom
    St louis,Mo.
    The needle I suggested is the same as the one pictured below. It just has a spring retaining collar attached to the same needle making it a little easier to use. The actual needle part is the same.
  11. Mar 3, 2016 at 5:31 PM
    #491
    the taco crna
    Tim
    South Texas
    Honestly, I have no confidence in my abilities that I could even change that zerk as I don't believe I could get two finger in there. I was lucky to get an open end wrench to actually make a purchase on it from the backside. With the needle, is it expected that I may get some grease coming back but most is actually going in? I only applied about 3-4 pumps before removing it but I think some may have went in but I am not certain. Thanks
  12. Mar 3, 2016 at 5:37 PM
    #492
    retired mech
    Tom
    St louis,Mo.
    You might get some leakage. You have to keep pressure on the needle (push). This is hard to do with a hand gun. Maybe have another set of hands to help.
    the taco crna likes this.
  13. Mar 3, 2016 at 5:48 PM
    #493
    the taco crna
    Tim
    South Texas
    Thank you retired mech. I realize this particular zerk is a PITA for all but just don't understand why I can't even get a coupler to attach to it when others have. I can't imagine the relief cut on the yoke of mine isn't the same as every other truck but again, it just doesn't have enough room to make a straight on connection. It's frustrating
  14. Mar 3, 2016 at 5:52 PM
    #494
    Aussiek2000
    2016 Offroad AC
    i just reach over the exhaust and have the zerk straight up
  15. Mar 3, 2016 at 5:54 PM
    #495
    retired mech
    Tom
    St louis,Mo.
    I assume you turned the drive in different positions to see which gives you the most clearance.
  16. Mar 3, 2016 at 5:59 PM
    #496
    the taco crna
    Tim
    South Texas
    Yes sir I have, but regardless of the position of the drive the yoke and zerk remain in the same plane. You're probably right, replacement of the zerk might be the best remedy, I can't imagine the angle of the zerk being off a fraction but I really don't have any explantation why I cannot attach a small coupler to it.
  17. Mar 3, 2016 at 6:05 PM
    #497
    retired mech
    Tom
    St louis,Mo.
    Maybe you could loosen it a 1/4 turn and the retighten when your done, or have the dealer fix it.
  18. Mar 3, 2016 at 6:33 PM
    #498
    the taco crna
    Tim
    South Texas
    So you rotate the drive to have the zerk at 12 o'clock and come down on it from above? I'm on my back under the truck so I have the zerk pointed at roughly 7-8 o'clock which is the best approach to visualize it that I've found.
  19. Mar 3, 2016 at 7:14 PM
    #499
    desantim
    desantim Well-Known Member
    Mario
    Oregon
    I highly highly recommend doing this. I have 760 miles on my AC 6spd sport and was a little unhappy with the drive train noise when shifting. I'd get some clunking down there as things bound and unbound. All 5 zerks took 5+ pumps. Upon driving the truck this evening to test her out things are considerably quieter and smoother under the truck. I really don't think it's my imagination. It honestly feels like a different truck to me.
    My advice get the tools and do it took me 20 minutes, I had never done this before.
    splitbolt[OP] likes this.
  20. Mar 3, 2016 at 8:18 PM
    #500
    pocketsmcaaron
    pocketsmcaaron Well-Known Member
    Oregon
    '16 OR MT DCSB WHT Prior:'15 MT ,'94 MT
    Snugtop Rebel,TRD Pro Bilsteins,2" Block rear,SR Grill,TRD Beadlocks,Toyo AT 2s,Focal Experts,Kicker AmP & 10" Sub
    Got around to doing mine at 3800 miles. Bone dry, all zerks took between 13-16 pumps. Thanks for a great thread Splitbolt(OP).
