Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 6, 2016 at 10:46 AM
    #561
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    ah good to know, thanks
  2. Mar 6, 2016 at 10:48 AM
    #562
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    Where can I get a Lincoln coupler and gun without buying online?
  3. Mar 6, 2016 at 10:56 AM
    #563
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Check various auto-parts or hardware stores. I saw Lincoln guns at my O'Reily.
    YotaLife406[QUOTED] likes this.
  4. Mar 6, 2016 at 11:20 AM
    #564
    the taco crna
    the taco crna Well-Known Member
    Tim
    South Texas
    2016 Quicksand TRD OR 4x4 AC
    I got mine at O'Reillys for like $3.50, they also carry several choices of guns and the lube you'll need. Looking inside at the two different couplers I used, the Lincoln coupler not only has the three internal "prongs" (don't know what they're called?) but it creates a more round sleeve to accept the zerk. The old coupler I was using had four prongs that created more of a square and I'm convinced it was the difference in not being able to attach it to the zerk. By all means, check the coupler to be sure it has only three "prongs".
  5. Mar 6, 2016 at 11:58 AM
    #565
    TRDTacoma626
    TRDTacoma626 Well-Known Member
    dang mine came shipped with the 4 prong, i hope it doesnt stop me from pumping my juice in
  6. Mar 6, 2016 at 12:39 PM
    #566
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    it wont, mine are 4 prong, the front two zerks need to be at the correct angle then it pops in place with no issues.
  7. Mar 6, 2016 at 2:06 PM
    #567
    the taco crna
    Tim
    South Texas
    Don't get me wrong sir, I had no difficulty at all with the other joints. It was the rear zerk of the front shaft that gave me a fit. I'd say give it a go and if you have difficulty making the connection, then pick up a Lincoln "three prong" coupler. After going through several options and several days of frustration, it was for me the only variable that changed and allowed me to connect to and purge that joint. I'm sure there are others who have had no issues but I sure did.
    eldedo likes this.
  8. Mar 6, 2016 at 3:59 PM
    #568
    YotaLife406
    16 DCSB OR M/T
    Do you have to take off the front skid plate to access the front driveshaft on the TRD OR? And what about his heat shield? Can some explain removal?
  9. Mar 7, 2016 at 10:29 PM
    #569
    MVMike
    MVMike Well-Known Member
    2016 White Tacoma TRD OffRoad Double Cab
    So happy to see Toyota still uses serviceable U-Joints. My last two Yukons did not have Zerks though I have to say both went over 100K mi. without needing replacement. I'll roll under the new Tacoma tomorrow to see.
  10. Mar 8, 2016 at 7:18 AM
    #570
    MariettaTaco
    MariettaTaco Well-Known Member
    Scott
    Marietta, GA
    2013 Superwhite 4x4 Dblcb
    If it's this hard to get to the front two zerks, what are the chances that the mechanic at your local dealership changing your oil and doing a 'multi point inspection' is greasing them? I suspect they only hit them if you specifically ask for it.
  11. Mar 8, 2016 at 12:18 PM
    #571
    StreetTiresJay
    StreetTiresJay Well-Known Member
    Jay
    British Columbia Canada
    '16 Taco TRD Sport DBLcab Alpine White 6M
    Wife in passenger seat, not driver seat :)
    Not sure if this has been mentioned yet, but I was experiencing a clunk while shifting my MT and took it to Toyota. Told them to lube the joints and torque the prop shaft. They did all this and problem solved. This is the email I got back today from Toyota since my request for this service was not mentioned in my service ticket. It reads as follows:
    Good morning Mr. Bolen,
    Service indicates that your advisor Jimmy verbally asked the tech to lube and re-torque the prop shaft. It seems that as you mention, this has resolved the clunk. This work was not mentioned on the work order it was only a verbal communication. We have made a note of it on your file so that there is a record of it.
    For the 1,000km these are the checks that they do:
    1. Under hood inspection for fluids
    2. Tire pressure check
    3. Undercarriage inspection
    4. Wash + vac.
    There is no physical check list for this particular service unlike the safety inspection where there would be a printout available. If you have additional questions, our Senior Service Advisor Ammar Ahmed would be able to help you at 604-465-9146 ext 117.
    Please let me know if I may be of additional assistance.
    Sincerely,
    West Coast Toyota
    Linda Leo
    Customer Relations Manager
    604-465-9146 ext 121
    SO... If it hasn't been resolved in your truck yet, get your stuff checked. The dealership should also not charge you a dime for this service. Just a thought as well... But this MAY affect the automatic trans as well... Guys with auto's should look into this some more, maybe low AT fluid is not the only issue
    tweedle likes this.
  12. Mar 8, 2016 at 6:07 PM
    #572
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    is this just for 4WD? i did not read all 30 pages of this thread but my 2WD does not have Zerk fittings. 2 piece drive shaft.
  13. Mar 8, 2016 at 7:45 PM
    #573
    flesheatingvirus
    ABQ, NM
    Tech Package
    Then you do not need to worry about it. :thumbsup:
  14. Mar 9, 2016 at 10:33 AM
    #574
    Tedward
    Tedward Well-Known Member
    DMV/N. VA
    2016 DCSB TRD Sport 4x4
    Too many to list...
    Did all 5 fittings on Sunday. 3,500 mi, each one needed 4-5 pumps. I reached all of them using the Lincoln 1134 gun (bought through Amazon prime for $41). I got to the troublesome zerk under the heat shield without removing the shield using this gun and the standard hose/coupler, no needle. Not too much issue, just patience.
    Notice a slight reduction in frequency and severity of clunking on downshifts when slowing to a stop (mainly 2nd and 1st gears). Glad it's done.
  15. Mar 9, 2016 at 10:34 AM
    #575
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
  16. Mar 9, 2016 at 1:28 PM
    #576
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    so far I got 4 out of 5 greased up. each one took about 5 pumps for all the caps to purge. I couldnt reach the last one with my mini gun as the tube isnt long enough. So I have to get a longer hose it only has a 4" steel rod on it
  17. Mar 9, 2016 at 1:52 PM
    #577
    Macvsog
    Macvsog Member
    Took my DCSB AT Limited w/1600 miles in to my private mechanic. Changed oil just because that's always been my SOP for new vehicles. While he was at it, he checked driveline and found that all of them were bone dry. Also checked AT fluid keel...it was full. I can sleep well now!!
  18. Mar 9, 2016 at 1:56 PM
    #578
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Did he do the procedure correctly...?? It's not as simple as pulling a plug to check..!!... there are lots of info on here on how to do it correctly..!
    Cheers
  19. Mar 9, 2016 at 2:00 PM
    #579
    Macvsog
    Macvsog Member
    He downloaded a 10 page set of instructions for the fluid level that I saw posted on this site, so I'm thinking he did the job correctly.
  20. Mar 9, 2016 at 2:10 PM
    #580
    over60
    Muskoka, Ontario
    Good stuff... !!
