Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 9, 2016 at 2:20 PM
    #581
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Sorry my 2 cents grease it every month.Drive shafts spin fast yes fast.Grease is forced out.Hit it .they move when the truck moves nonstop.Pump tie rods ball joints every 3000. But the shafts once a month grease cheap changing u joints a bit of time and money...my 2 cents sorry....
  2. Mar 9, 2016 at 5:09 PM
    #582
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    2014 dcsb, took 4-5 full strokes to purge all the joints. They must assemble these shafts with just the u-joint manufacturers assembly lube. Cheap SOB's
  3. Mar 9, 2016 at 5:38 PM
    #583
    jpb2
    jpb2 Well-Known Member
    Jeff
    Southeast Mo
    2021 DCSB TRD OR AT
    Stopped by my usual oil change place. ( dealer is 100 miles away and local dealer is less than desired ) about 2 pumps each. Mine were fine but glad I know for sure
  4. Mar 9, 2016 at 6:13 PM
    #584
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    There should be 5 along the drive shaft. (1 at the rear diff, 1 where the rear shaft meets the middle, 1 where the middle connects to the front, 1 from the t-case for 4wd [hiddden by a cheap skid plate that uses 2 14mm bolts i think], and 1 that goes into the front diff area).
    Im sure there is a thread on here that has pics of each (ive seen it sometime)
    175908 likes this.
  5. Mar 9, 2016 at 6:33 PM
    #585
    Skootter14
    Jeremy
    yea the ones on the 4wd shaft can be difficult at first to find, but you can spin that shaft while the truck is sitting there so its not too bad. glad ya got it.
    I just did mine 2 days ago so thats the only reason I knew where all 5 were haha, good timing
    175908 likes this.
  6. Mar 10, 2016 at 9:56 AM
    #586
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    Hey do you have to take the skid plate off on the ORs to get to any of the zerk?
  7. Mar 10, 2016 at 10:05 AM
    #587
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    No.
    There is however, a shield under the rear zerk on the front driveshaft
    A handful of guys have been able to do it with the shield in place.
    I recommend you remove it; makes it so much easier to access and inspect.
    YotaLife406[QUOTED] likes this.
  8. Mar 10, 2016 at 7:59 PM
    #588
    YotaLife406
    16 DCSB OR M/T
    Thank you
  9. Mar 10, 2016 at 8:31 PM
    #589
    desantim
    desantim Well-Known Member
    Mario
    Oregon
    2 12mm bolts save yourself and remove the shield. Will save you 10 minutes of headache trying to hit the nipper
  10. Mar 11, 2016 at 3:53 PM
    #590
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Wasn't that hard to reach with a flex hose greaser. [it would have been easier if Toyota had put a 1'' hole that would line up with the zerk though.] From front to rear, 3, 4, 4, 3, 3 pumps.
  11. Mar 11, 2016 at 3:57 PM
    #591
    xdrcsub
    xdrcsub Member
    Rob
    Pittsburgh, PA
    2016 Blazing Blue Pearl SR5 DCLB
    Husky Liner Weather Beaters Trico Neoform Wipers
    Did my Sr5 LB this morning, man does it shift smoothly now! 6 pumps in each
  12. Mar 11, 2016 at 4:43 PM
    #592
    VaGlock
    Kevin
    central virginia
    I believe 4. Will have to see if I can find #5.
  13. Mar 11, 2016 at 4:45 PM
    #593
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You missed one..!!
  14. Mar 11, 2016 at 6:27 PM
    #594
    robster6180
    robster6180 Member
    I recentlly took delivery on a 2016 TRD OR crew cab with tow package. I told the sales person that I wanted the service department to make sure the U-Joints were lubed and the transmission fluid level was verified based on numerous comments posted on this forum from other buyers. The sales person assured me that both of these items were checked when I picked up the truck. I got under the truck and checked all the zerks when I got home and they looked untouched. I greased all 5 zerks, and they took between 6-8 pumps before they began to purge grease. I have ~450 miles on the truck so far and the transmission feels like its beginning to smooth out. This seems to be in line with with what others have been saying that the transmission learns your driiving habits over time. I have noticed intermitent behavior that indicates possible low transmission fluid (low speed surges, slips when shifiting from reverse to drive in cold temperature), so I plan to perform the transmission fluid level check procedure posted on the forum.
    My experience relative to the U-Joints and transmissin fluid level seems to be in line with many others on this forum. It still amazes me that Toyota hasn't taken action in their manufacture process to address these deficiencies.
    Thanks to all on this site. There is a weath of informtion here!
  15. Mar 11, 2016 at 8:48 PM
    #595
    2016/7544G
    2016/7544G Well-Known Member
    Doug
    Bluegene, Or
    '16 Inferno TRD Off Road
    Stock (got it Sunday)
    All these dry u-joints! Has anybody heard of any failures?????? Most '16 owners don't read this. Dry u-joints would fail soon, where the hell are they all??????? Those u-joints are not dry, they just do not have the cross drilled grease channels full of grease. The bearings themselves have grease! This thread is ridiculous.
  16. Mar 11, 2016 at 8:50 PM
    #596
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Shouldn't they be full of grease though?
  17. Mar 11, 2016 at 9:11 PM
    #597
    VaGlock
    Kevin
    central virginia
    I read something that makes me want to disagree.
    "Lube Procedures Spicer® greasable U-joint kits contain only enough grease to provide needle bearing protection during storage." -
  18. Mar 11, 2016 at 10:17 PM
    #598
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    if you feel its adequate then don't grease em.
    exactly correct, Toyota (factory or dealership) failed to follow recommendations.
  19. Mar 12, 2016 at 5:22 AM
    #599
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    here is something that might surprise you. Not every person who buys a tacoma joins a forum. So you may not even hear about the ones failing. The ones who post here already read this most likely and have solved the grease issue for their truck. I bought my first tacoma in 2000 and was my first truck and was unaware there were grease fittings on the driveshaft and at around 6000 miles I had to have the driveshaft replaced by toyota because it was sounding like a squealing pig. Honestly I think the salesman should be telling each buyer the driveshaft has grease able fittings so someone who may not be aware of them know they need serviced
  20. Mar 12, 2016 at 8:38 AM
    #600
    the taco crna
    the taco crna Well-Known Member
    Tim
    South Texas
    2016 Quicksand TRD OR 4x4 AC
    Honestly, The only thing I find ridiculous to this thread are your contributions to it.
    wilcam47 and 175908 like this.
