Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 12, 2016 at 8:40 AM
    #601
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    nightcrawler likes this.
  2. Mar 12, 2016 at 8:51 AM
    #602
    3doghouse
    3doghouse New Member
    Jack
    2016 MGM DCSB TRD OR
    Just greased all five on mine. Each of them took between five and seven pumps. Many thanks to everyone who contributed to this important tip!
  3. Mar 12, 2016 at 9:05 AM
    #603
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    checked at my 5k checkup, paperwork states all fine.
  4. Mar 12, 2016 at 10:40 AM
    #604
    AZVern
    AZVern Well-Known Member
    Vern
    Phoenix, AZ
    2016 Tacoma TRD OR DCLB
    Not enough
    Removed heat shield. 4-7 pumps each to fill. Heard the air squeeze out right before visible grease.
  5. Mar 12, 2016 at 12:38 PM
    #605
    baywingdb
    baywingdb Active Member
    PNW
    2016 DCLB OR 4x4 white/gunmetal
    All 5 had nothing but assembly lube in them. Most took 5-6 pumps but the back u-joint took 10. Thanks to the OP for the heads-up.
  6. Mar 12, 2016 at 2:26 PM
    #606
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Really you think a sales person cares???? You get your vehicle and check forums and hope they are up to date Your truck know it inside out!!! You love your truck don't you?Thank god for tacomaworld....
    175908 likes this.
  7. Mar 12, 2016 at 3:30 PM
    #607
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    To blue bear Damn rite next!!!!!!!Sales persons sell that's it hey what do they drive????
    175908 likes this.
  8. Mar 12, 2016 at 3:54 PM
    #608
    TRDTacoma626
    TRDTacoma626 Well-Known Member
    So I got to this today
    Of my 5 zerks all had paint still on them
    I was only able to pump 3-4 good pumps into them however.
    Black stuff spewed out so I assume there was grease in it already.
    How much of it am I suppose to pump in? Just until it spews out ?
    As for the heat shield I was able to get to it by turning it and not having to remove it.
    Oh and thanks for making this thread! Mine wasn't bone dry but now I know for sure they aren't!
  9. Mar 12, 2016 at 4:04 PM
    #609
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Until you see new grease coming out all 4 seals
    PrisonerOfDoom has a good pic here. Wipe off the excess.
    .https://www.tacomaworld.com/threads/check-your-u-joints.409042/page-24#post-11857808
  10. Mar 12, 2016 at 4:07 PM
    #610
    TRDTacoma626
  11. Mar 12, 2016 at 4:12 PM
    #611
    splitbolt
    NW Arkansas
    Think of it as a flush and refill procedure.
    TRDTacoma626[QUOTED] likes this.
  12. Mar 12, 2016 at 4:36 PM
    #612
    Hot Tacoma Blown
    NewYork
    05 4×4 tacoma
    Again to all.It is Your Truck free oil change at dealer No greasing on my wife's 2013 I greased it every time.No such thing as too much grease.Hit them when you can I am Anal I do it every month...Just like someone said there is a place where they make grease all Da Long.
  13. Mar 12, 2016 at 4:50 PM
    #613
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    I would pony up for a grease gun and 1 tube of grease(less than 50 bucks). It literally takes 10 minutes to grease and you don't even have to jack up your truck(I am 5'10" and 245lbs, if I can fit most people can) Someone else said the dealership said it was "ok" and they had to pump em up as well. Just saying "peace of mind" is worth it's weight in gold.
    175908 likes this.
  14. Mar 12, 2016 at 4:54 PM
    #614
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    they dont care at all...all they expect is to bring you their broken vehicle to fix at the dealership....when preventative maintenance can help and sometimes eliminate you even going to the dealership...
  15. Mar 12, 2016 at 4:54 PM
    #615
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    lol, one member had a person at the dealership tell him there is no zerks.
  16. Mar 12, 2016 at 4:58 PM
    #616
    wilcam47
    Will
    Bourbon state
    There are u-joints that dont have zerks..
  17. Mar 12, 2016 at 4:58 PM
    #617
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    not on 4wd units
  18. Mar 12, 2016 at 5:18 PM
    #618
    TRDTacoma626
    anways i went back out there and pumped my shaft until it spewed ;)
    one question, when cleaning it all up does it have to be spic and span? If left over grease gets flung around down there will it do it anything? MY neck was starting to hurt so i gave up trying to clean it
  19. Mar 12, 2016 at 5:26 PM
    #619
    splitbolt
    NW Arkansas
    Just the excess.
    It'll fling out no matter what. If a big glob is left to fling on the exhaust, you might notice a smell; won't hurt anything.
    I run a microfiber through them; grabs the grease and carries it away, instead of spreading it around.
  20. Mar 12, 2016 at 5:35 PM
    #620
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Excess grease flung around will cause metal NOT to rust where it sticks.
    I aways figured if I could see grease spatter located around greasable joints, they were greased and if someone did that, they tended to take better care of a vehicle then one that had zero signs of joints with zerks being greased.
