Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jun 8, 2016 at 9:30 AM
    #801
    UberDingu
    UberDingu Well-Known Member
    CT
    21 Off-Road AC 4x4 V6
    "I have no clue, you guys do all of my services, must have been one of your techs :D"
    craigbaill likes this.
  2. Jun 8, 2016 at 9:35 AM
    #802
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    :cheers:
  3. Jun 8, 2016 at 10:51 AM
    #803
    mtnfox
    mtnfox Well-Known Member
    Dave
    1991 4x4 p/u, 2016 Quicksand TRD Off-Road 4x4 DCLB
    Before I took delivery of my truck in April I had asked the dealer to do this (among other things). When I purchased they assured me they had, although I never had any proof. Today I figured I better get under there and do it myself just in case (about 1300 miles on my truck). Well it appeared that they did listen to me, as 4 out of the 5 zerks only took about 2 or 3 pumps max, paint was rubbed off the zerks already and a few had globs of grease covering them. That difficult one under the heat shield however, was a different story. It appeared untouched and took 11 pumps (removed the heat shield - probably could've fought it a bit and managed without doing that, but it was much easier just to get that thing out of the way). I don't know if they just missed that zerk or were lazy and didn't want to deal with that one, but I'm glad I checked. They also said they checked the transmission fluid but now I'm not real sure (I have no transmission issues as of yet). I do have the engine chirp that sounds like a pulley but is probably the high pressure fuel pump (look for the thread) and I'm going to have my local dealer check that out as soon as I get a chance. Maybe I can talk them into checking the ATF at the same time...
  4. Jun 8, 2016 at 11:41 AM
    #804
    I'mTheDude
    I'mTheDude Well-Known Member
    Hickory, NC
    2016 DCSB TRD O/R 4X4
  5. Jun 8, 2016 at 11:48 AM
    #805
    KevC
    KevC Well-Known Member
    So I'm screwed either way? o_O
    Has anyone with a 2wd have any issues with the U joints?
  6. Jun 8, 2016 at 3:07 PM
    #806
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    None reported here.
    I haven't heard of anyone dropping the shaft to check u- joints; 2WD or 4WD. I've seen a few around here playing with the operating angles without dropping the shaft; can't recall If they were 2WD OR 4WD.
    Who knows...
    :fingerscrossed:
  7. Jun 8, 2016 at 3:16 PM
    #807
    splitbolt
    NW Arkansas
    I try not to be a grease snob, but....
    JT6 is what I'm using.
    -Spicer recommended
    -cheap
    -available
    -new grease goes in red, old purged grease comes out black; makes it easier to recognize a purged seal
    I'mTheDude[QUOTED] likes this.
  8. Jun 8, 2016 at 5:21 PM
    #808
    Elmo
    Elmo Well-Known Member
    Harvey
    Cramerton, N.C.
    2016 OR AC TRD
    Rigid 20 LED Light Bar Weather Tech mats Toyota Mudguards
    You can perform your own service and not void warranty.
  9. Jun 8, 2016 at 6:42 PM
    #809
    toyota3.5
    toyota3.5 Well-Known Member
    *l
    Ontario Canada
    2016 TRD Sport DCSB MT
    I just traded my 05 Tundra for a DCSB trd MT and my U joints appear dry but in 11 yrs that I had my Tundra the U joints were never greased and no issues so not sure why everyone is so worried?
  10. Jun 8, 2016 at 7:02 PM
    #810
    splitbolt
    NW Arkansas
    Did your 2WD Tundra have greaseable u-joints?
  11. Jun 8, 2016 at 7:15 PM
    #811
    toyota3.5
    *l
    Ontario Canada
    No zerks, you're right but the factory grease in the new Tacos should be good for at least a year.
  12. Jun 8, 2016 at 7:48 PM
    #812
    splitbolt
    NW Arkansas
    Maybe, if they were filled with the proper amount of service grease and not an insufficient amount of assembly grease.
    Toyotacare doesn't cover it until 15,000 miles/18 mo.
  13. Jun 9, 2016 at 6:59 AM
    #813
    I'mTheDude
    Hickory, NC
    Should grease purge evenly from around the blue boots in the joints? I greased all of mine last night and grease was only purging from a small point on each one? Sorry guys, first time with a grease gun....:cheers:
    [​IMG]Zerks by Jordan Garren, on Flickr
  14. Jun 9, 2016 at 7:12 AM
    #814
    splitbolt
    NW Arkansas
    Yep, as long as it's new grease coming out.
  15. Jun 9, 2016 at 7:25 AM
    #815
    UberDingu
    CT
    That's something I wanted to ask as well... we grease until new grease comes out or old grease? I stopped at old grease because I figured it's not actually old, just low. If it was part of a service then obviously I'd want to purge completely.
  16. Jun 9, 2016 at 7:28 AM
    #816
    splitbolt
    NW Arkansas
    Yep. It's more a flush and fill procedure; not just a top-off.
  17. Jun 9, 2016 at 7:29 AM
    #817
    UberDingu
    CT
    We'll damn, guess I'm getting back under there :(
  18. Jun 9, 2016 at 7:39 AM
    #818
    splitbolt
    NW Arkansas
  19. Jun 9, 2016 at 1:42 PM
    #819
    02TacoBro
    02TacoBro Well-Known Member
    Houston, TX
    2012 TRD SPORT 4WD, 6 SPD Manual, 3DR
    1.5" Suspension Lift Android Auto / Sound System GettaGrip Shifter
    Is it okay if I'm doing this at 12k miles? Am I going to have damage? I've already been off-roading a lot.
  20. Jun 9, 2016 at 1:50 PM
    #820
    topdec
    topdec Well-Known Member
    Are you asking if you're going to have a problem 'cause you didn't grease the ujoint right after purchasing the truck?
