Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jul 31, 2016 at 6:16 PM
    #881
    Steelhead Taco
    Steelhead Taco Oncorhynchus mykiss
    Fred
    2016 OR DC SB MT
    That's a nice armchair point of view, but there is a reason zerk fittings are equipped. And a term "preventative maintenance" comes to mind. If you think assembly grease is all it needs more power to you. Give us "zerk greasing fanboys" a little time in the sun.
    :bananadance::angrygirl::bananadance:
    Mush Mouse likes this.
  2. Jul 31, 2016 at 6:34 PM
    #882
    2016/7544G
    2016/7544G Well-Known Member
    Doug
    Bluegene, Or
    '16 Inferno TRD Off Road
    Stock (got it Sunday)
    So answer the question, do you believe the non-zerk u-joints are assembled with more grease then those equipped with zerks?
  3. Jul 31, 2016 at 6:44 PM
    #883
    Steelhead Taco
    Fred
    2016 OR DC SB MT
    Has you mention empty channels can draw away grease from the needle roller bearings with heat expansion. Reducing set lubricant present. I feel better knowing I'm doing my best to reduce friction. And keeping the engineered film of lubricant where it's needs to be. And yes I've had my share of driveline failures, but not in toyotas mostly in WW2 Dodge powereagons
  4. Jul 31, 2016 at 8:13 PM
    #884
    djginji
    djginji Active Member
    Bay area
    2016 White DCLB OR Tacoma TRD 4x4
    I got my taco OR DCLB 4x4. It only two of them got zerks out of 5. I purchased my car on 7/16
    Sixgun CO[QUOTED] likes this.
  5. Jul 31, 2016 at 8:58 PM
    #885
    Sixgun CO
    Sixgun CO Well-Known Member
    16 Tocoma TRD off-road
    Brand new 07-28
    Not worried either way. It's an easy replacement with good ones when they originals fail. It'll give me something to do in 20 years. Lol
    djginji likes this.
  6. Jul 31, 2016 at 8:59 PM
    #886
    Sixgun CO
    Brand new 07-28
    Weird!
  7. Aug 1, 2016 at 2:04 PM
    #887
    Showtime
    Showtime Well-Known Member
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    Glad I stumbled across this thread. I was able to grease all the zerks but one. The front 90° is on too much of an angle to get at. Tried turning with a wrench but couldn't get it to turn. What can I do?
  8. Aug 1, 2016 at 2:20 PM
    #888
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    It's part of the 15k maintenance shedule, so at intervals greasing the propeller shaft is something the dealership does when you bring in your truck. Doing it before the 15k just makes sense, especially if there is only a light amount of grease on the needle bearings. U joints eventually fail on these trucks, greasing them before the 15k might make them last longer, and its cheap. From the manual, 15k interval service:
    • Inspect cabin air filter
      (if applicable)
    • Lubricate propeller shaft
      (where applicable)
    • Inspect fuel lines and charcoal canister
    Steelhead Taco likes this.
  9. Aug 1, 2016 at 2:32 PM
    #889
    Steelhead Taco
    Fred
    2016 OR DC SB MT
    Showtime, I had to tighten mine to get a good bite with the grease gun. Maybe you have to loosen yours a bit. BTW it's an 3/8" American size hex at the base of the zerk, you might have to turn the drive shaft and access it from the opposite side of the grease fitting to turn it. ( this is the furthest forward grease fitting I'm refuring to )
    Fred
  10. Aug 1, 2016 at 2:36 PM
    #890
    TacoMA36
    TacoMA36 Member
    2016 TRD OR 4x4 AT DCLB
    Interesting, my same OR DCLB 4x4 manufactured 3/16 has the 5 zerks. They were all dry when I greased them.
  11. Aug 1, 2016 at 2:46 PM
    #891
    Showtime
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    I did that and it took grease and the rear 3 took grease as well. I'm referring to the very 1st zerk closest to the engine
  12. Aug 1, 2016 at 2:49 PM
    #892
    Showtime
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    I tired tightening and nothing. If I loosen it will it take grease or just ooze out of the threads?
  13. Aug 1, 2016 at 2:50 PM
    #893
    Steelhead Taco
    Fred
    2016 OR DC SB MT
    There's still enough thread contact to prevent any grease to escape.
  14. Aug 1, 2016 at 2:51 PM
    #894
    Showtime
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    Well I'm going to give it a try and report back:fingerscrossed:
  15. Aug 1, 2016 at 2:56 PM
    #895
    Usfive
    Usfive Well-Known Member
    NH
    2016 Tacoma Access Cab TRD Sport
    I had to loosen mine slightly and all was good.
  16. Aug 1, 2016 at 3:13 PM
    #896
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I know non-sealed u-joints thus far do not have ufficient grease from the factory.
    Sealed u-joints ship with the correct amount of grease from Spicer.
    The assembly grease shipped in non- sealed u-joints is just that; assembly lube. They only need enough assembly lube to protect the needles during shipping and storage.
    They require purging after assembly to get the correct amount of grease.
    This is all per Spicer.
    I don't know Toyota's procedure for assembling sealed u-joints.
    But, let's say for the sake of argument, ol' Jeb takes all the caps off but doesn't pay attention to the order when installing. Do you think you have sufficient grease?
    Let's say ol' Jeb dropped a journal on the shop floor...don't worry, he wiped all the greasy dirt off before assembling it in the driveshaft. Do you think you have sufficient grease?
    Sealed u-joints are not fool-proof; hope you enjoy yours.
  17. Aug 1, 2016 at 3:24 PM
    #897
    Showtime
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    Well I got to take grease. The front 2 took about 8 pumps and the rear 3, 3-4 pumps.
  18. Aug 1, 2016 at 4:25 PM
    #898
    Steelhead Taco
    Fred
    2016 OR DC SB MT
  19. Aug 1, 2016 at 9:44 PM
    #899
    2016/7544G
    Doug
    Bluegene, Or
    And you know this how? Do you think Toyota u-joints are manually greased? If you do, well... I won't say it. Toyota does not use spicer U-joints. And where are all the failures????? This whole thread is full of so much BS. People pushing grease past the seals and claiming it is contaminated grease because it is black. It is black because it is high moly grease. They are pushing out the good grease and replacing it with inferior grease with no moly. Do you believe you know more about u-joints and their maintenance then Toyota? This whole thread is a fecking joke and this is the last post I will make in it.
    btripptrd likes this.
  20. Aug 1, 2016 at 9:52 PM
    #900
    IronPeak
    AuggieX
    Back to Back
    As I posted earlier, toyota calls for greasing the propeller shaft ( the zerks on the driveshaft ) at 15k intervals. This thread just suggests that you do it sooner, as they are shipping with minimal grease on the needle bearings. No more posts from you ? Good , and I think we all agree to that , thanks, bye felicia..
    Steelhead Taco and Floridahunter like this.
