Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 4, 2017 at 4:45 PM
    #1081
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    They did away with most of the grease zerks for 2017. The only 2 left are on the front drive shaft.
    shakerhood and venezian[QUOTED] like this.
  2. Mar 4, 2017 at 4:54 PM
    #1082
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    Are you all using general purpose lithium grease? Or is there some automotive grade?
  3. Mar 4, 2017 at 5:03 PM
    #1083
    mustangwilly
  4. Mar 4, 2017 at 5:51 PM
    #1084
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    If I were you, I'd sell it NOW..!! That amount of rust is excessive. Especially for Los Angeles...!!
    1bad2k likes this.
  5. Mar 4, 2017 at 6:52 PM
    #1085
    J.M Taco
    J.M Taco Well-Known Member
    Central California
    '17 Tacoma Quicksand DCSB TRD OR 4x4
    InfernoTonka[QUOTED] likes this.
  6. Mar 5, 2017 at 8:06 AM
    #1086
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    maybe dumb question but why cant i turn the drive shaft when in neutral so i can reach the flange bolts ?? :(
  7. Mar 5, 2017 at 8:13 AM
    #1087
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    Your tires are still in contact with the ground. :facepalm:
  8. Mar 5, 2017 at 8:18 AM
    #1088
    InfernoTonka
    Is this rust or some sort of deposit from salt or hard water?
  9. Mar 5, 2017 at 10:38 AM
    #1089
    lawrenccar1
    good answer !!
    SargeBSA[QUOTED] likes this.
  10. Mar 5, 2017 at 10:44 AM
    #1090
    weefek
    weefek Well-Known Member
    J
    2017 OR ACLB
    NLGI NO 2 PEOPLE.....
    Did mine last weekend, there were only 2 on the front shaft (rears were sealed) took about 6-7 pumps , just like everyone else. There WAS some grease already in the joint but not enough I fear.
    Sharky50 likes this.
  11. Mar 5, 2017 at 12:12 PM
    #1091
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Dannyblues likes this.
  12. Mar 5, 2017 at 1:10 PM
    #1092
    J.M Taco
    Central California
  13. Mar 5, 2017 at 2:07 PM
    #1093
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    I bought my sr 4x4 friday checked my zerks today and they were 3-4 pumps low.
    Also it was my first time with a grease gun/ pump so I had no clue how to use it. at first i thought everything was suppose to be tight on the pump and you just put the tip directly on the zerk and it auto fastens. just like using air tools. i was wrong but through trial and error and grease everywhere I found out how it works.
    So Just in case there are any other newbies... once you have your grease loaded there is the tip piece. I unscrewed it a little to be able to fit over the zerk. then you have to tighten the fitting to make a good seal on the tip. then pump away.
    InfernoTonka and Dannyblues like this.
  14. Mar 5, 2017 at 2:13 PM
    #1094
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    This is only on offroad models?
  15. Mar 5, 2017 at 2:22 PM
    #1095
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    For 3rd gen; 4x4 models up to June/July of 2016.
    Toyota apparently eliminated the greasable u-joints on the rear driveshafts at that time. The front driveshaft should still have them.
  16. Mar 5, 2017 at 3:00 PM
    #1096
    Hagendazsss
    San Diego, CA
    Mine is a sr and had to grease them. mine only had zerks in the front driveshaft.
  17. Mar 22, 2017 at 9:18 AM
    #1097
    Dannyblues
    Dannyblues Well-Known Member
    Danny
    New Milford Connecticut
    2016 Tacoma TRD sport 4x4 double cab black
    weather tech mats, mud flaps, black side rail step, cargo bed liner, roll up cargo bed cover, wheel locks towing package
    Thanks I'm sure from many of us for posting such great photos!!! Really appreciated. I read the cover on one is easily removed. Has four 12 mm bolts to gain access as shown on the #2 front driveshaft u joint Dannyblues
    InfernoTonka and shakerhood like this.
  18. Mar 22, 2017 at 9:20 AM
    #1098
    Dannyblues
    Danny
    Great information. Thanks. Dannyblues
  19. Mar 22, 2017 at 9:27 AM
    #1099
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes, correct. use threaded gun tips...
    mostly it doesn't matter how tight it is when attaching to a zerk
    they go on with a hard push.
    it is taking it off
    which is a knuckle buster if you don't have a threaded barrel,
    but it will yank off, as it is spring loaded...
    so, unscrew it to get it off easy and don't have to yank very much at all
  20. Mar 22, 2017 at 9:28 AM
    #1100
    Dannyblues
    Danny
    According to the owners manual on my 2016 TRD 4x4 it says to libricate propeller shaft. The dealer shop foreman, their master mechanic told me he didn't know of any specs for greasing universal joints or how many there were on my 2016 TRD 4x4. Then told me there were no differences in grease. Of course I told him white lithium as well as others vary considerably for each application.
    Anyway at 11,300 I asked the shop to grease my driveshaft. Mechanic said there were only 3 zerks. Other two were factory sealed.
    When it warms up I'll crawl under with my flex hose grease gun and do it right myself. Dannyblues
    Meant to add lubricate propeller shaft at 15,000 miles in owners manual under maintenance interval services.
    vuTron[QUOTED] likes this.
