Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 27, 2017 at 4:43 PM
    #1141
    Naumoff42
    Naumoff42 Well-Known Member
    Ohio
    2015 TRD Offroad
    Just greased my u-joints today on my 2015. Well all but the very front one, I couldn't get the zerk fitting to fit into that tight of a spot. I'll grind it down at some point.
    It appeared that they had all been greased before assembly but the actual channels of the zerk were never pumped full. Took about 7-8 pumps before I was purging fresh grease.
    shakerhood and Vbpiper like this.
  2. Mar 27, 2017 at 5:36 PM
    #1142
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Yes, the joints have "assembly" grease in them and the manufacturer tells Toyota to grease them after they are installed into the driveshaft. You obviously cannot do it before or the end caps would pop off under the pressure. Mine had some white and red grease in it, but took 7-8 pumps to have them all purge fresh grease out each ot the 4 seals per joint..!!
    File a bit off the sides of yer tip and it'll work...
    shakerhood likes this.
  3. Mar 27, 2017 at 6:15 PM
    #1143
    Naumoff42
    Ohio
    2015 TRD Offroad
    White? Shoot I only have 20,000 on it and that grease was black. :bananadead:
  4. Mar 28, 2017 at 11:30 AM
    #1144
    over60
    Muskoka, Ontario
    I guess it would be black after 20,000K... I did mine at 100Kms.... hehe..
  5. Apr 7, 2017 at 2:34 PM
    #1145
    Squanto
    Squanto Well-Known Member
    Oahu
    2016 DCLB 4x4 Tacoma SR5
    Does anyone know if the sr5 trim have zerk fittings or are they sealed?
  6. Apr 7, 2017 at 3:18 PM
    #1146
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    If it's 4x4 it will have zerk fittings. If it's 4x2 it will not have them.
  7. Apr 7, 2017 at 3:22 PM
    #1147
    Squanto
    Oahu
    Had my 5k service today, asked them to grease the u joints, they just called saying that the joints are sealed and can't grease them. It's a 4x4
  8. Apr 7, 2017 at 3:30 PM
    #1148
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Interesting. I have seen several comments on this forum where people were told by the service dept that their truck does not have zerks. When they checked for themselves, sure enough, there are the zerks. I'm not positive but I was under the impression that all 4x4s have zerks.
  9. Apr 7, 2017 at 3:42 PM
    #1149
    CenCal805
    CenCal805 Well-Known Member
    California
    2016 Tacoma TRD OR AC
    I was told the same thing by the service department. So, I went and bought a grease gun and came home and greased them myself. Not sure why they tell us that or why they believe that… Could be they're just lazy.
    Mine all needed between 2-5 pumps to get the grease to purge.
  10. Apr 7, 2017 at 4:24 PM
    #1150
    over60
    Muskoka, Ontario
    It's because they are F'n stupid... How can it be anything else??
  11. Apr 7, 2017 at 4:30 PM
    #1151
    CenCal805
    California
    ^ This made me laugh.. so true!
  12. Apr 7, 2017 at 5:29 PM
    #1152
    th365thli
    th365thli Well-Known Member
    Jerry
    Bay Area
    2019 Ram 1500 Big Horn Quad Cab
    I didn't read the previous pages, but I for the life of me could not find the rear shaft zerks. Poked and prodded and looked all around. I have an off road 4x4 2017.
  13. Apr 7, 2017 at 5:37 PM
    #1153
    CenCal805
    California
    Did you read post # 5? I probably wouldn't of been able to find them on my own had I not seen those pictures. They are great pictures and show you exactly where they are, you shouldn't have trouble after seeing those.
    Check 'em out.
  14. Apr 7, 2017 at 5:39 PM
    #1154
    th365thli
    Jerry
    Bay Area
    I swear to you I looked at the pictures and then my truck for 15 minutes. Maybe I'm just tired an going crazy, will check again later. These are zerks 3, 4, and 5 that I can't find.
  15. Apr 7, 2017 at 5:43 PM
    #1155
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    They changed to non-greasable u-joints in the rear driveshaft around June/July of 2016.
    You will only have 1 and 2.
  16. Apr 7, 2017 at 5:44 PM
    #1156
    th365thli
    Jerry
    Bay Area
    That explains it. So I'll have to put faith those will be good to go? For what's it's worth, zerks 1 and 2 seemed to be fine. Two pumps and it was already leaking grease like crazy.
  17. Apr 7, 2017 at 5:46 PM
    #1157
    CenCal805
    California
    Shoot, man... The only thing I can think of is that the driveshaft (I think that's what it is, I'm so not mechanically inclined)had to be rotated some before I could reach four and five. I had to look real hard to find them and then noticed that I had to just pull forward a little bit and could access them. Yeah, check them out later after you gotten some rest. If I can do it, you can do it. I barely know how to put gas in my truck... lol.
  18. Apr 7, 2017 at 5:46 PM
    #1158
    CenCal805
    California
    Never mind.... sounds like you're all set!
  19. Apr 7, 2017 at 6:16 PM
    #1159
    Squanto
    Oahu
  20. Apr 7, 2017 at 6:31 PM
    #1160
    splitbolt
    NW Arkansas
    Longevity is affected by;
    -proper assembly
    -operating angle
    -operating conditions
    -maintenance, or lack thereof
    Some get more miles out of them than others, no matter the type.
    Which u-joint is best suited to you, depends on your usage and adherence to proper maintenance.
    -If your good about maintenance and it's prone to contamination, it's nice to be able to purge them with grease.
    -If your bad about maintenance and it operates somewhat contamination-free, the sealed might be better choice.
