Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Apr 7, 2017 at 7:17 PM
    #1161
    Squanto
    Squanto Well-Known Member
    Oahu
    2016 DCLB 4x4 Tacoma SR5
    Just crawled under my truck no zerks on the rear driveshaft, not even going to check the front.
  2. Apr 7, 2017 at 7:19 PM
    #1162
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There will be Zerks on the Front.
  3. Apr 7, 2017 at 9:30 PM
    #1163
    th365thli
    th365thli Well-Known Member
    Jerry
    Bay Area
    2019 Ram 1500 Big Horn Quad Cab
    Ehh it's out of my hands. Just gonna enjoy the Truck and drive. It's hard not to get TacomaWorld syndrome aka paranoia about everything. Pretty happy today. Local mechanic helped check my transmission fluid. Not that I had any reason to but I thought eh why not. G2g. Tightened ubolts and made sure my front zerks were properly greased. Truck has been amazing trouble free *knock on wood*. First tacoma, likely not the last.
  4. Apr 8, 2017 at 10:13 AM
    #1164
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Why not grease the only 2 zerks you have..?? On the front shaft..!! :confused::confused::confused::confused::confused:
    Vbpiper and shakerhood like this.
  5. Apr 8, 2017 at 11:40 AM
    #1165
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Yep.
    Glad this thread is still alive. I grease all of my zerks every coupla thousand km, helps with the clanks/clunks too.
    :cheers:
    shakerhood likes this.
  6. Apr 8, 2017 at 1:54 PM
    #1166
    MOC221_
    Frank
    And if you don't want to remove the guard, you can access that zerk by turning the driveshaft until it's up on a diagonal towards the driver's side (IIRC ). I didn't figure this out, but I can tell u it works.
    Well, with my grease gun anyway - it's the cheapo lumax.
    Frank
    Vbpiper likes this.
  7. May 19, 2017 at 5:54 AM
    #1167
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Any other areas that should need intermittent greasing (that we have access to?) such as CVs, etc.,?
  8. May 19, 2017 at 1:19 PM
    #1168
    bshammer0
    Brandon
    Nashville, TN
    Just checked mine at 10,000 miles... the only 2 I have (in the front) were bone dry as well. All I could hear was air escaping as it took 8-9 pumps each to purge.
    Doesn't make one feel very confident in the ones that are sealed on my July '17 OR....
  9. May 20, 2017 at 10:12 AM
    #1169
    2016/7544G
    2016/7544G Well-Known Member
    Doug
    Bluegene, Or
    '16 Inferno TRD Off Road
    Stock (got it Sunday)
    So........ has anybody ever had any u-jount failures on a 3rd gen????
  10. May 20, 2017 at 11:12 AM
    #1170
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    2nd gens took about 60,000 miles for failures to start showing.
  11. May 20, 2017 at 11:16 AM
    #1171
    2016/7544G
    Doug
    Bluegene, Or
    No dry u-joint will run 60,000 miles.
  12. May 20, 2017 at 11:27 AM
    #1172
    splitbolt
    NW Arkansas
    There is "dry"; then there is "inadequate"...
    over60 likes this.
  13. May 20, 2017 at 11:51 AM
    #1173
    2016/7544G
    Doug
    Bluegene, Or
    You and a lot of others have been saying dry. So now it is"inadequate". So an inadequate lubricated u-joint will run 60,000 miles or more? Do you have a link of 2nd generation u-joint failures at 60,00 miles? And..... are these failures on lifted trucks with more severe angles running big tires etc.?? There is just no evidence any u-joints on these trucks are shipped with inadequate lubrication just because the factory chooses not to waste grease filling grease channel voids with grease that will never see a bearing until it is pressured to the bearing by grease gun forcing. Oh, I believe in maintenance alright but to have every new owner thinking something so basic that has been used for over a hundred years escapes the attention of one of the largest and most reputable auto makers.
    69others likes this.
  14. May 20, 2017 at 2:28 PM
    #1174
    2016/7544G
    Doug
    Bluegene, Or
    An by the way; this is the kind of stuff that causes manufacturers to leave zerk fittings off, take away the ability to check transmission oil levels by owners, etc. To much dumb stuff by people who know so little about their vehicles that maintenance service is designed out of owners ability to keep them from screwing up their vehicles, aggravating warranty problems and damaging the reputation of the brand needlessly.
  15. May 20, 2017 at 3:09 PM
    #1175
    splitbolt
    NW Arkansas
    Guess we're lucky I didn't start a transmission thread...:jerkoff:
  16. May 20, 2017 at 8:49 PM
    #1176
    2016/7544G
    Doug
    Bluegene, Or
    So because of the complaints and updates of the transmission we have u-joints they don't bother to grease that never-the-less go 60,000 miles without failure. I'm not a 3rd gen fanboy but the the u-joints are fine and your thread is a farce.
    :jerkoff::jerkoff: back
  17. May 20, 2017 at 11:19 PM
    #1177
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    So an inadequately lube ujoint will run 60k, how long will a "properly lubed" one run? I think the more important question is why they are not properly lubed, period, and a more properly lubed one will run smoother.
  18. May 21, 2017 at 4:25 PM
    #1178
    over60
    Muskoka, Ontario
    Damn.!!! I musta over greased my Zerks.... I hope I didn't busy 'em..!!
  19. May 21, 2017 at 4:29 PM
    #1179
    over60
    Muskoka, Ontario
    Check out what the manufacturer tells Toyota..... "the joints come from the factory with only assembly grease. Grease them thouroughly once installed in the drive shaft"...(IE: purge the air and fill the joint)..
    If I were you, I'd try to see if I could suck what little grease is in yours and see if you can get 60,000 miles... "Let us know how that works for ya" (as Sara Palin would say)..
    IronPeak likes this.
  20. Jun 4, 2017 at 8:56 AM
    #1180
    MagGrayGuy
    MagGrayGuy New Member
    TRD Sport Access cab LB
    ARE hard tonneau,
    Mine was tagged manufactured 3/16 and it has no zerks on the rear u-joints.
