Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jan 9, 2018 at 6:11 PM
    #1261
    lightgrenade
    lightgrenade Well-Known Member
    2017 TRD OR
    About time to get back under there and check again. Thanks for the posts.
  2. Jan 21, 2018 at 11:52 AM
    #1262
    Zoop
    Zoop Well-Known Member
    Found zero zerk fittings on front or rear, 2017 OR purchased Sept. 2016.
    Son of a bitch! I wouldn't have bought the gun/grease!
    Anyone know why there aren't any fittings at all?
    4x4 2017 OR, MFG 08/2016 in US
  3. Jan 21, 2018 at 12:11 PM
    #1263
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Look closer on the front drive shaft.... there are 2 of them. They are tucked into the "crotch" of the joint....!!
    shakerhood likes this.
  4. Jan 22, 2018 at 6:59 AM
    #1264
    Zoop
    I plan on looking again, me and a buddy looked up/down/inside/outside and didn't see nary a one!
  5. Jan 22, 2018 at 9:02 AM
    #1265
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    I believe Toyota did away with grease-able u-joints after 2016
  6. Jan 22, 2018 at 9:14 AM
    #1266
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Maybe late 2017? My June 2017 build has them on the front shaft only.
  7. Jan 22, 2018 at 9:26 AM
    #1267
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    June-July 2016
    Omar RVA and tonered[QUOTED] like this.
  8. Jan 22, 2018 at 12:23 PM
    #1268
    over60
    Muskoka, Ontario
    I believe that was when they got rid of the rear 3 zerks, but the front should still have 2 more..??
    If it's a 4x4..
  9. Jan 22, 2018 at 12:58 PM
    #1269
    Zoop
    I thought it should have had the 2 at least in the front! It its an OR 4x4, Looks like my pops will be putting me and the gun to work on his 02' lol
  10. Jan 22, 2018 at 1:23 PM
    #1270
    over60
    Muskoka, Ontario
    Check out post #1 on this thread.... you'll see how those front 2 zerks are well hidden in the crotch :eek: of the joint...!!
    Good luck..."Zerk hunting"..... PS.. The front one is the hardest to get a gun on...there is a little "cut-out" in the joint and if you turn the joint to 7 o'clock, you should be able to get on it.....(that's driver's side...looking from the rear).
    I had to grind my tip a bit to get in there.... (my tip was just too big)...!! :rofl::rofl::rofl:
    sparker likes this.
  11. Jan 27, 2018 at 11:02 AM
    #1271
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    2018 SR5 DCLB with 1,050 miles. Below is what I found:
    The one closest to the engine took 4 full pumps before I saw some assembly grease. By pump 8 I could see some of my new grease. I did 10 pumps total before my grease came out of every spot.
    The other u-joint took almost 4 full pumps before I saw some assembly grease. By pump 7 I could see some of my grease. I did 9 pumps total before my grease came out of every spot.
    sparker and over60 like this.
  12. Jan 28, 2018 at 2:46 PM
    #1272
    jrain904
    jrain904 Well-Known Member
    So I went to walmart and bought red tacky grease but I had trouble getting the coupler on my gun to attach to the zerk. I am unsure if the zerks are a different size (larger) than my gun's coupler or if the angle is giving me the trouble.
  13. Jan 28, 2018 at 3:45 PM
    #1273
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The front Zerks are at a weird angle, I ended up grinding some material off of my grease gun fitting and it goes on and off much easier.
    Vbpiper and jrain904[QUOTED] like this.
  14. Jan 28, 2018 at 3:49 PM
    #1274
    shakerhood
    Southern Ohio
    Those 2 fittings are there on the front shaft, they are just hiding from you.
    Vbpiper likes this.
  15. Jan 28, 2018 at 3:57 PM
    #1275
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Just pop the little shield off for the front u joint, spin it by hand untill it's pointing down and grease it up. Personally I never pump more than 3 times, too much grease can blow out the seals, cause excessive heat build up and makes a mess. I just pump untill I see the seals slightly puff up. Usually about 3 pumps or less.
    Tacos4ever15, Vbpiper and shakerhood like this.
  16. Jan 28, 2018 at 4:16 PM
    #1276
    shakerhood
    Southern Ohio
    I like to remove that little metal shield also to get in there easier.
    FFBlack[QUOTED] and Vbpiper like this.
  17. Jan 28, 2018 at 7:24 PM
    #1277
    FFBlack
    2019 TRD OFF ROAD
    Nice video, only thing is it's a little misleading because that u joint is huge and completely dry. And it gives the impression of you have to pump that much grease. On a greased u joint of our trucks size I'd say 3 pumps worth of grease is more than you think. Thanks though it is a great vid. Now if only there was one showing the sealed lifetime units there using now. I've changed some on Ford's before and the used a nylon collar where the seals are and we would torch em to get them hot so the nylon melted and put in regular style greasable joints. My experience the lifetime sealed u joints lasted between 45,000 to 55,000 miles but those were on fords.YMMV
    Vbpiper likes this.
  18. Jan 29, 2018 at 10:43 AM
    #1278
    Zoop
    You guys were all correct, found the lil' bastards hiding in the crotch of the u-joints!
    over60, shakerhood and Vbpiper like this.
  19. Jan 29, 2018 at 6:17 PM
    #1279
    jrain904
    Just a tip for those that are new to these things, the shaft/ujoints can be rotated in order to facilitate accessing the zerk fitting. Once I figured this out I was able to get the coupler to attach and grease them up. I had to purge air on both before the dirty grease came out. There was definitely grease in there but neither was full. This was two days after my 15K service that the dealership was supposed to grease these fittings per the standard maintenance program, do not trust the dealer to do this for you.
    Vbpiper likes this.
  20. Jan 29, 2018 at 6:29 PM
    #1280
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    Just did mine today, I was a bit surprised that there were no Zerks on the slip joints. At any rate, it was easy to access all the Zerks that were present. The front shaft U joints purged out a strange, thin red and somewhat runny grease, while the grease in the rear shaft U joints was black lithium grease as I would have expected. Not sure if anyone else has purged out that red runny stuff from the front shafts.
    Of course, got inspired to do both of my Jeeps, much harder tasks w double cardan shafts all around, and had to remove them all to be able to grease adequately. It was a grease fest here in the driveway today. The Tacoma was way way easier to do, like a 20 minute task which included "flossing" around the cups to make sure purged grease didn't go flinging everywhere when I drove and then stink on the hot exhaust pipe or cat.
