Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Aug 10, 2018 at 8:07 PM
    #1341
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Ok, maybe they deleted them on the front now as well. They are right in the middle of the spider on only one side.
    tonered likes this.
  2. Aug 10, 2018 at 8:13 PM
    #1342
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    My 2018 has them up front. None in the rear. I greased them as soon as I got the truck. Would have to crawl back under to remember exactly where they are.
  3. Aug 10, 2018 at 8:14 PM
    #1343
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Then they have been deleted. That’s the first place I looked.
  4. Aug 10, 2018 at 8:15 PM
    #1344
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is a little shield bolted on that blocks the ones on the front driveshaft.
    Arianna likes this.
  5. Aug 10, 2018 at 8:24 PM
    #1345
    Flash1034
    N/W Montana
    Ok. I’ll crawl back under there again tomorrow and look under the shield for the front ones...again.
    shakerhood likes this.
  6. Aug 10, 2018 at 8:27 PM
    #1346
    Stocklocker
    17TRDORDCSBAT
    In 2wd you can rotate the front shaft by hand. They are hard to see tucked inside the joint like they are. Not obvious at a passing glance.
    tonered and shakerhood like this.
  7. Aug 11, 2018 at 8:00 AM
    #1347
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Some I think said theirs were black not silver and therefore hard to see.
    over60 likes this.
  8. Aug 11, 2018 at 1:38 PM
    #1348
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Yes, they are black..... right from the factory.... Scrape that paint off the end of them prior to filling them up. They will only have factory installation grease in them, not filled properly.
    Good luck... The rear one, on the front shaft, (under that little shield) is best seen and accessed with the gun from the 7:00 position (looking from the rear).
    I think the front one is best from about 5:00....
  9. Aug 11, 2018 at 3:38 PM
    #1349
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    That's correct. There is a forum discussion on that. If you want to install the greaseable ones, and you should, here is the Toyota part number: 04371-0K082. The Spicer part number is: 5-13301X.
    Don't buy from the dealer. Go to Dallas Toyota or TRDShop.com, otherwise you'll pay $80 or more for each one - you need three.
  10. Aug 11, 2018 at 3:40 PM
    #1350
    shackley
    The shield to to prevent grease from getting on the exhaust and flaming out someday on the freeway or off road somewhere.
    over60 likes this.
  11. Aug 11, 2018 at 3:43 PM
    #1351
    shackley
    Cool video. When I was in tracked vehicle mechanics school in the Marines, they had a video just like that, probably was Spicer. I've always pumped until I can see new grease from each cup.
    TRDSport10 and over60 like this.
  12. Aug 11, 2018 at 3:44 PM
    #1352
    shackley
    That's what Toyota corporate told me too. Do you want to take a chance and lose a rear driveshaft miles off road? A pound of prevention...
  13. Aug 11, 2018 at 3:46 PM
    #1353
    shackley
    I imagine that's why Toyota engineering quit putting greaseable ujoints in, since the dealers never do it. I grease at each oil change, or 5000 miles whichever comes first, and since it's 10,000 now, between each oil change.
  14. Aug 11, 2018 at 3:53 PM
    #1354
    shackley
    Years ago I was driving on the 405 in LA and saw a Datsun pick-up get jacked-up and caused a massive pile-up when the front of his driveshaft broke at the ujoints. His truck flipped to one side. I know because I was the first one at the accident. Luckily no one was hurt. The driver didn't know what a ujoint was. Live and learn.
  15. Aug 11, 2018 at 3:55 PM
    #1355
    shackley
    I think you and I discussed this a couple of months ago too, splitbolt.
  16. Aug 11, 2018 at 4:02 PM
    #1356
    Arianna
    Arianna Well-Known Member
    Arianna
    Oregon, Washington
    2017 Magnetic Grey Tacoma SR5 Crew Cab
    The shield has 2 bolts that can be tricky to remove. I used a ratchet and a medium length 10mm fitting.
  17. Aug 11, 2018 at 4:13 PM
    #1357
    tAcomaPueblo
    tAcomaPueblo Well-Known Member
    Virginia Beach, VA
    2017 Tacoma TRD OffRoad 4x4 DCSB
    Great post. Have a 2017 OR 4x4 DCSB with zerks in front only and each took about 4 pumps. Never done it before but always happy to do something that makes me feel like I'm taking care of my truck.
  18. Aug 11, 2018 at 9:25 PM
    #1358
    Flash1034
    N/W Montana
    I found the two front shaft zerks and put more grease in them today. Couldn’t find any grease points on the rear...
    Stocklocker likes this.
  19. Aug 12, 2018 at 7:12 PM
    #1359
    tacoscott16
    tacoscott16 Well-Known Member
    scott
    2018 TRD pro
    2018 had 2 zerks.
  20. Aug 12, 2018 at 7:22 PM
    #1360
    Flash1034
    N/W Montana
    Yep. I found em. Thanks!
