Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 4, 2019 at 4:33 PM
    #1421
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    You are right, I am sure it was a clever innovation, and it must have worked. I will try it myself next opportunity just to increase my flexibility in options for greasing zerks. Thank you for your followup comment, and I hope I didn't sound like the A-hole I really never wanted to be.
  2. Mar 4, 2019 at 4:51 PM
    #1422
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    No offence taken, my friend.
    I once had a relatively close friend call me out on the possibility getting a tire / rim bead-lock with ether and a cigarette lighter. This was pre internet, he'd never seen it happen and couldn't wrap his head around the possibility. No monies were exchanged, but he insisted on seeing it for himself.
    cheers.
    :cheers:
  3. Apr 5, 2019 at 5:05 PM
    #1423
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Just found this and about to go verify my grease and if it's good to go I'm going to check mine out. Like 38k miles on my 2017 4x4 and never knew to check it, just had new suspension followed by a regear and with an empty bed I have vibrations but with a couple hundred pounds in bed most vibrations go away. However I now have a whining noise at higher speeds and when decelerating which is louder at higher speeds.Idk what to even do but i'm desperate at this point. It really all feels ok but the whine just doesn't seem it should be there. East coast gear supply and a local well known mechanic says that aftermarket gears will just be louder and that things should be fine as long as everything seems normal other than the whine and it doesn't get worse. At lower speeds like 50 or below its almost non existent. Im assuming this is like any other gear grease fitting....just fill it until you see grease? What signs would it give if it were dry?
  4. Apr 5, 2019 at 5:24 PM
    #1424
    Mack411
    Ok,well I am laying under my 2017 TRD or 4x4 auto and do not have the grease fittings.edit...... found them both, greasing them now
  5. Apr 5, 2019 at 5:25 PM
    #1425
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Your 2017 most likely lacks a greaseable rear driveshaft.
    Keep pumping until you see grease come out all 4 seals. It's a purge and replace procedure; not a top-it-off one.
    It's not very scientific, but;
    -zerks are pristine
    -takes a large amount of grease to purge all 4 seals; I'd say anything more than 5-7 pumps
    -can hear air migrating through the joint as grease is applied
    If to far gone, they usually give off a high pitch squeal before failure.
  6. Apr 5, 2019 at 5:26 PM
    #1426
    splitbolt
    NW Arkansas
    See; first post, EDIT No. 2
  7. Apr 5, 2019 at 5:35 PM
    #1427
    Mack411
    Correct I got that on the rear so if they were too be bad what would that cause? So just pump the old out until I see new clean grease right?it was probably about 10 pumps each u joint. Also I tried to clean up some of the old black grease but wan't really able to get to it.
    I did I'm speaking of the front, is it possible one doesn't have greasable fronts?bc I sure ain't seeing them anywhere at all??..
  8. Apr 5, 2019 at 5:39 PM
    #1428
    Mack411
    Ok nm found the one, but not the one under the plate
  9. Apr 8, 2019 at 1:40 PM
    #1429
    jardoo
    jardoo Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    Hey guys, I have a 2016 TRDOR DC, trying to locate the two front drive shafts, i have RCI front, transmission, and T case skid plates. which one do i need to remove to access them? thanks.
  10. Apr 8, 2019 at 1:49 PM
    #1430
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I just have front and trans skid plates and can still reach the nipple when the shaft is rotated correctly.
  11. Apr 8, 2019 at 1:50 PM
    #1431
    jardoo
    Beirut, Lebanon
    both nipples? aren't there two up front? i can get at them from the sides?
    TacoRD16[QUOTED] likes this.
  12. Apr 8, 2019 at 3:55 PM
    #1432
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    over60 likes this.
  13. Apr 9, 2019 at 7:18 AM
    #1433
    TacoRD16
    Houston, TX
    Yes both nipples.
  14. Apr 22, 2019 at 9:27 AM
    #1434
    scifidelity
    scifidelity Well-Known Member
    Hey. I have a 2016 TRD OR DCSB. I used to grease the zirks on my old land cruiser with every oil change so I'm familiar with it. I found great pics in this thread of the counts and location of the fittings on the shafts and u joints, but in terms of procedure, in case something changed in the design of these since 1996, does one still add grease to the u joints until a touch of the old grease comes out? Then for the shafts, just add a couple of pumps? On the land cruiser, greasing the two shafts was super tricky because they were a slip yokes so if you added to much grease, it extended/ pushed back too much and could wear out the needle bearings. I always just did 3 pumps to avoid this. Is this still how it works?
    Thanks for the help!
  15. Apr 23, 2019 at 9:21 AM
    #1435
    Sonic Boom
    Sonic Boom Well-Known Member
    Did a lot of reading and I just want to confirm that I understand this correctly...
    The 2017 and 2018 Tacomas have 2 zerks that need to be greased on the front and the rear are NOT designed to be greased. Is this correct?
    Also, are dealerships really greasing these? I spent a few years working at a dealership back in the day and cannot recall a single time the techs would lubricate anything.
    sierra141 likes this.
  16. Apr 23, 2019 at 9:42 AM
    #1436
    splitbolt
    NW Arkansas
    Correct.
    Dealerships are likely not lubing it...
    I'd be surprised if dealerships even have grease or a grease gun on premises.
  17. Apr 23, 2019 at 9:49 AM
    #1437
    scifidelity
    Is this different for the 2016?
  18. Apr 23, 2019 at 9:56 AM
    #1438
    scifidelity
    That’s what I noticed on mine. Wondering if what the other gentleman said is accurate in that I should not be lubing some of them?
    Vbpiper likes this.
  19. Apr 23, 2019 at 10:10 AM
    #1439
    Sonic Boom
    Thank you! Is this grease gun adequate enough? https://www.lowes.com/pd/STP-Mini-M...H_Ml&cjevent=61b9dc2165ea11e9809d03bf0a24060b
    Or would you recommend something like this? https://www.amazon.com/Lincoln-Lubr...rue&ref_=ox_sc_act_title_2&smid=ATVPDKIKX0DER
  20. Apr 23, 2019 at 10:13 AM
    #1440
    splitbolt
    NW Arkansas
